Originally Posted by Picasso Moon
I currently have dual subs and an AVR (used as pre/pro) with Audyssesy XT but only a single sub channel. In the near future I would like to upgrade to a dedicated pre/pro and see some of the processors (Denon AVP, new Onkyo PR-SC887 etc) have multiple sub outs. Currently, I manually balance the output of each sub so match each other pretty closely. I then run Audyssey which treats the dual subs as one.
My question. Are the subs treated independently by Audyssey in the units that have multiple sub outputs? In other words does Audyssey ping each sub independently and set up a filter for each one? If this is indeed the case, is it a significant upgrade over the single channel setup I currently have?
Thanks for any input you might have.
Originally Posted by audyssey
Hi,
The Denon AVP definitely treats the three subs individually and so MultEQ will apply separate correction to each one. Not very many other AVRs and Prepros treat subs separately so it's best to check with each manufacturer directly to make sure. Audyssey will correct subs separately if that capability is given to it in the AVR.
Hi,
Hi,
It would appear that sometimes its better to ping the two subwoofers simultaneously and establish a single combined correction filter even if each subwoofer can be corrected individually. Below are Chris' remarks with regard to the SVS AS-EQ1 sub EQ, which is an add-on device designed to equalize two subwoofers.
We gave users a choice to avoid raising a fuss...You have two options:
1) Dual discrete. Each sub response is measured individually and a different room correction filter is created for each one.
2) One In to Two Out. Each sub is measured individually first to find the time and level differences between them. Then the system applies delay and level adjustments to align the two subs to each other. Then it pings them together as *one* and creates a single room correction filter for the combined sum.
We found that #2 gives better results and made it the default option when you run the software. But, when you get to that screen you have the choice to select Dual Discrete before proceeding.
So if your subwoofers are symetrically placed with respect to the primary listening location, having a single subwoofer output might not be an issue to be concerned about.
Larry
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
But like it only took me a couple minutes to find that the refurb was messed up, I discovered almost as quickly that the lowest-end 590 works flawlessly with MultEQ as it should! I was gradual checking it.
, but here's the other 2 for
The 590's Audyssey set the speakers 4-5dB lower than any 1909 run, and the sub 10dB lower.
), I replied to the e-mail again asking if they even reproduced the problem (didn't say), are they going to do anything to fix it, I shouldn't have to pay to ship it again for the same problem that they didn't even fix or bother to check the refurb for, etc. Response:
