The diagram for the DSX speaker configuration says the angle of elevation for the height channels should be 45 degrees. If I'm understanding that correctly, you need a HUGE room for that. If for example the angle is relative to ear height (~36"), and you are sitting 10' away from the front wall, that would mean the the speakers would have to go 13' high! Even if the angle was relative to the floor, that would mean the speakers would have to go 10' high.
post #19171 of 62748
9/30/09 at 11:06am
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
, only knew there was a definite difference between the 2 models.
But we don't know what Chris used...
I don't know how much sound hardware supports this (DTS has a version too), but it's cool to avoid using the board's multi-channel analog output and lose the AVR's digital processing, etc. Its audio control panel can even apply PLII processing to 2-channel stuff, so the proper audio comes out of the center speaker when sent out over the 5.1 carrier. However, it looks like QuickTime screws up trailers with plain stereo, still sending out 5.1 when configured for it, with sound only in the L/R channels...
Oh well, on rare "trailers on the TV" occasions, I just wouldn't enable the Dolby Digital Live, and get 2-ch PCM.
Dolby Digital Live is probably using the max 640kbps, and I'd have liked to measure this way if I had "discovered" it a week sooner.
