Originally Posted by Mactavish
All true, my Rythmik F12g sub is great for music, the reason I bought it, did not care how accurate a tank sounds, but I do watch BlueRays, like Dark Knight. Thankfully, my Onkyo 906 allows for the LFE level to be lowered, I use a -10 LFE setting, and now my subwoofer is under control, meaning it does not sound like or BLOW like, it did before, so it hopefully will NOT blow up. One simple setting made a world of difference.
Bingo. Here's part of the answer I got from Chris at Audyssey:
"The most likely reason for the bottoming out is that the LFE track is being incorrectly decoded and an additional 10 dB is being added. There is a setting in the 807 menu that allows you to turn down the LFE level by 10 dB. We have not been able to verify this, but it appears that the required 10 dB boost in the LFE track may be added twice in some player-AVR combinations and that could be causing the issue you are having."
I'm going to re-do the Audyssey set up then set the LFE to -10 on my 807's Blue Ray input and see what happens.
Bat pig, thanks for the second sub suggestion. I've considered that before but unless you're willing to pay for my divorce I think I'll look for other solutions. My room, by the way, is 14 x 18 with 3 doors which remain closed while watching movies.
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
Huh? DynEQ is cutting levels of what above reference 0dB, Larry?
