AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #1)
"Official" Audyssey thread (FAQ in post #1) - Page 769
post #23041 of 62191
Originally Posted by terminal33 View Post
There was never a time that I heard a loud clank or snap. I first heard it with WOTW when the pods were emerging and it just sounded like the crackling of a firework. When I lower the volume, then it's gone.
Might be that the surround (or spider) got pulled loose. Surrounds can make quite a racket if they are flopping in the wind.
post #23042 of 62191
Well I got home and played the cannon scene from TIH and set my volume at -20 and I heard the pops. I then looked on the screen of my AVR and noticed that it read "Audyssey Dynamic EQ." I then turned Dynamic EQ off and played the scene again. This time I was able to listen at -15 WITHOUT any popping. For some reason Dynamic EQ was on, but I thought I turned it off when I first calibrated my system.
I then watched the end battle scene at -15 and I heard a quick noise on my sub (which is corner loaded). It came in the beginning of the final fight when the Hulk uses the police car as brass knuckles and hits the bad guy multiple times. He then gets on the bad guy and punches him more. There's one bass burst right as the Hulk lifts his arm that caused a chuffing sound. It was less of a pop and more of a chuff this time.
I then changed the subsonic filter to 20Hz while leaving it tuned at 15Hz. (This is OK to do, based on the manual.) I replayed the same scene and I still heard the chuff, but it was softer and more brief. So it seemed that changing the SF to 20Hz DID help a bit. I even changed my sub trim level from -4.5 to -5.0 and turned down my gain by a hair, but I still heard a brief chuff on that part. I then went back to the cannon scene and was able to listen to it at -13 without any pop from the sub. I didn't go louder than -13.
So it seems now that the only part from TIH that causes my sub to make a funny noise is the end battle scene described above. The noise happens so quick that if you weren't listening for it, you probably wouldn't notice it.
My conclusion is that setting the SF to 20Hz did give me a tad more headroom, therefore I will leave it at that. Thanks for the suggestion. Also, I realized that for TIH, listening to it at -15 is not bad at all. I usually watch movies at -12 and so that has become my magical number to set all movies to. But even at -15, I was happy with the sound of TIH. Perhaps other movies will not provide the same level of sound at -15 and so I'll have to turn it up. Then there are those movies like, The Dark Knight and Ironman, where I can watch it at -12 and hear no chuffing/popping on my sub at all. I guess TIH just has that much more potent bass than TDK or Ironman.
Still, "9" seems to have the heaviest bass of all because I heard popping in multiple scenes and had to watch it at -20 to eliminate them. But then again, I was watching "9" with Dynamic EQ on, which SVS told me to turn off today. Unfortunately I mailed "9" back to Netflix already so I don't have it to test out.
Does anyone know more about when or why or IF Audyssey does apply a boost to some movies, or whether it's only below a certain frequency that it applies a boost? Do you think "9" was getting a boost applied? Or does it just have that much more powerful and lower LFE?
Thanks for all of your feedback! I'd appreciate any more help. But for now, I'll just enjoy the movies that I can at -12, and decrease the volume for the small amount of movies that make my sub pop at -12.
Your description of the sound makes me think of the "DTS-MA bomb". It can sound very much as you describe. If you have a couple year old Onkyo receiver and are playing DTS-MA sound then you may need a firmware update. If that is not your situation, then this is not the issue.
post #23043 of 62191
never mind
post #23044 of 62191
Originally Posted by deepstang View Post
Ok, I have read the FAQ on Audyssey dual sub set-up but wanted to know if I could get any more tips or advice.
I have dual subs; however, they are on opposite sides of the room and NOT symmetrical to each other or the listening positions. I already have them level matched via a SPL meter at the main listening/measuring point.
I have an Onkyo 605 with Audyssey 2EQ, which only really sets the distance of the subs...and does not apply any sub filters
My plan is to have them both on and run Audyssey. Any advice would greatly be appreciated!!
Originally Posted by streetsmart88 View Post
A big problem with 2 subs that are not co-located is that they may be at different distances from the main listening position. This means that their sound output will arrive at different times. To solve that problem, you can either buy a device which will introduce a delay to the nearer sub or you can buy an SVS AS-EQ1. I would suggest getting the AS-EQ1. Not only does it solve the problem of varying distances, it also provides an Audyssey filter with twice the resolution as MultEQ XT and the capability to do 32 measuring points.
Mark
Thanks Mark. I don't know if I can justify to the wife to drop another $750 on the SMS AS-EQ1 after spending $1550 on my subs. I should have a Behringer DSP1124P on the way, and was hoping that would help.
That is a REALLY good point in that with the dual subs at different distances, I need to some how incorporate the appropriate delays. Is there a cheaper way for me to do this than something like the SMS? I know I can put in-line delays; however, I would not know how much of a delay to apply.
post #23045 of 62191
Originally Posted by jmcomp124 View Post
One thing I did notice about the surround rear is that now I hear more overhead sounds. I tried the star wars Pod race and gladiator. The rear stage is different and I think I like it better because there is more presence overhead and I seem to enjoy that more than behind the head.
Hi Jai,
You are experiencing the Surround Envelopment Processing that is turned on with DSX. It tries to solve the problem of unwanted imaging caused by the matrixing of content into the surrounds and back surrounds. The result is a much more diffuse surround field. There is also some "secret" perceptual processing going on that helps blend the surround and front stages better.
post #23046 of 62191
Hi Chris,
Now that you have me captivated by DSX, I am wondering about adding heights sometime soon. It is going to be a big investment as I have to upgrade from the Integra 40.1 to the 80.1, ..
Hi Jai,
The rule-of-thumb for the Heights is "as high as possible". In most rooms the recommended 45° angle is not possible given the ceiling height. So, with in-room speakers you should try to place them on the front wall as high up as possible and near the upper corners. MultEQ will take care of response issues. Try mounting them so they can be pointed down to the listening area. Alternatively, some use in-ceiling speakers that should be placed in the ceiling near the front wall.
Keep in mind that as of today only one product, the Denon 4810, allows both DSX Wides and Heights at the same time. With the others, you have to select between Wides or Heights. We hope to see more 11 channel DSX products in the coming year...
post #23047 of 62191
Someone should offer a service to upgrade firmware or walk you through it, damn dongle confusion. Or make a killing selling those dongles if they could make them.
post #23048 of 62191
Glad to hear things have improved. If you get some time, I have another suggestion. With sub tuned at 15Hz (one port blocked) and the subsonic filter at 20Hz, which is your current configuration. Turn up the volume/gain on the subwoofer from 11 O clock to 1 O clock. Rerun Audyssey and try to ensure there is no background noise. Let us know what the result is.
Good luck,
-Jai
One more thing...
Before you go through the trouble of redoing Audyssey what I suggested, can you try 20Hz tuning (all ports open) and 20Hz subsonic filter setting. I also have a suspicion about port chuffing. The higher velocity wind through those pipes (2 for 15hz) maybe a chuffing source. If it is, then the 20Hz tuning with 3 pipes (all ports open) may reduce chuffing. SVS should have designed the subs to avoid such chuffing but with the kind of material you are listening to, you maybe reaching the limits.
I will try both suggestions when I get home today and post the results. Thanks.
post #23049 of 62191
I have the Onkyo 707 so I don't think it's the bomb. Besides, wasn't the bomb only with bitstream audio? I'm using the non-slim PS3 without bitstream capabilities for DTS-MA.
post #23050 of 62191
Yes, the bomb issue was only during bitstreaming and if you are sending LPCM you can lay that worry to rest. However, you will find that the LPCM will be about 3dB lower than the bitstreamed audio at least with the PS3. Also check the PS3 to make sure that the internal gain is at 0 as accidentaly or intentionally raising the internal volume of the PS3 can create distortion.
post #23051 of 62191
Originally Posted by roufen View Post
I had a Denon 1909 ,same sub ,same position ,never had that kind of problem ,during measurement sub's sound was normal ,after measurement sub was at -7db ,playing BD Spiderman 3 ,the scene were convict becomes Sandman ,i could fell the floor shake
Onkyo 807 ,same sub(tried a friends 12inch also) same spot ,first 2 Audyssey measurements ,no difference from Denon during and after measurment ,sub set to -12db ,same BD scene from Spiderman3 same feeling
I didn't like the -12 db thing so i tried another one(Audyssey) same Sub's position ,lower sub volume (from12o'clock to 10) ,sub sounds lower during measurement and stays that way after i am done ,sub level -9db ,same BD Spiderman3 same scene ,sub is low and stays low even when i manually increase sub's volume .
I set Audyssey OFF , same BD scene ,sub is back again giving the same feeling
Reading 807's thread and also asking there , i have also tried turning Loudness OFF / Preserve THX settings OFF = nothing ,the solution came when i did hard reset(restore ) ,lost all of my settings and started all over again ,First measurement all OK ,sub works fine ,if i try a second one i have the same problem again
Sub's position is the same for all measurements since problem came up
Never had that problem with Denon 1909 ,even after 10 Audyssey measurements
This makes no sense at all.
If I understand what you are saying, when you ran Audyssey the first time (or 2) with the Onkyo, you had the sub level control set at 12 o'clock and Audyssey set a trim level of -12 db. If lowering the sub level control from 12 o'clock to 10 o'clock results in an Audyssey trim level of -9 dB, then you turned the sub down by about 3 dB (with the sub level control) and Audyssey compensated by raising the trim level 3 dB (from -12 dB to -9 dB). The result should be the same overall loudness level for the sub in your room. But you are claiming that it is quieter now.
Have you actually measured the speaker levels using a SPL meter and the internal test tones after running Audyssey? It would be a worthwhile exercise to see where things actually are.
post #23052 of 62191
Seems like it is time for you to upgrade from your old 605 to a new AVR that is able to actually correct and utilize your dual subs. With no time/distance correction or sub filter creation capability for 2EQ, you may go to a lot of trouble setting things up and then be thoroughly dissappointed with the results.
post #23053 of 62191
People,
I have run the setup of Audyssey following the Guide. I put the microfone on 8 differente positions following guide's suggestion but the center speaker has come up with about 6.5db lower than it should. I do not think that is room response because sitting on the main position the lowered volume may be noticed by anyone with a non impaired hearing. It is not subtle. Does anyone have a suggestion? Does this mess up the room correction or should I just adjust the level and let it be?
Michael.
post #23054 of 62191
Originally Posted by SoundMike View Post
People,
Michael.
Where is the center located? Is it aimed at the listener's ears? How do you know it is 6.5 dB lower than it should be? Did you measure it with a SPL meter?
post #23055 of 62191
Asside from sounding low, I measured with an SPL Meter. The center speaker is right in front of me on a pedestal with a slight upper inclination towards my head.
post #23056 of 62191
... Does this mess up the room correction or should I just adjust the level and let it be? ...
No, Michael, changing the levels does not affect the room correction. Chris has indicated before that Audyssey calculates its equalization formulas, then the trim.
... I do not think that is room response because sitting on the main position the lowered volume may be noticed by anyone with a non impaired hearing. ...
You are likely seeing a room response issue, assuming you placed the Audyssey microphone at ear level and observed all the other cautions about mic placement: away from back walls and reflective surfaces, not sitting in the chair but above it on a boom, etc. It is amazing what differences can appear when one measures at different points around the primary listening position.
Chris has indicated that Audyssey calculates its trim adjustment based on the results at all the measured positions. So perhaps it has set a level that seems low to you at your primary listening position, to avoid setting the level too high at some of the other listening positions. Of course, this is only one hypothesis, among several possible.
post #23057 of 62191
Thank you. I totally agree that it is time for me to upgrade to a new AVR; however, although a 707/807 may have Audyssey MultEQ with sub filters, it can not address my exact situation.
From what I understand, the time/distance correction for dual subs that are not equi-distant (symmetrical) can only be done by high end AVRs like the $1200 Onkyo NR1007. The other AVRs with MultEQ....or MultEQ XT still consider the sub as one entity with one single time/distance correction. Right??
post #23058 of 62191
My Room is Small. Maybe that is the issue. I'll reduce the quantity of measuring points and check what result that yields. Maybe using only lateral and back positions in relation to the main listening position.
Michael
post #23059 of 62191
Hi, was the distance of the center speaker equal or very close to the physical distance? Can you check and report? For bonus points you may check the distances of all of your speakers, including Sub.
post #23060 of 62191
Michael
Hold it Mike, don't reduce the number of measurements but make use of all 8 so as to let Audyssey have as much information of your room as it can (even if it's small) to make the proper calculations.
post #23061 of 62191
Good Point. I'll check but I remeber seeing very close distances between front/right and center. It looked accurate but I did not measure.
Michael
post #23062 of 62191
Well, then I guess it is positon planning time
Michael
post #23063 of 62191
Michael
Mike, you don't really need to do planning but follow the Guide mechanically. Well, unless otherwise, you have a peculiar setup in your room, i.e. Main Listening Position (MLP) off-axis, or the like.
And one more point to consider: following the Guide is not enough, it should be strictly followed, word by word.
Good luck to Ya!
post #23064 of 62191
Good luck to Ya!
I'll do the procedure again following the guide more strictly and check back.
thanks,
Michael
post #23065 of 62191
Perhaps -12 is the limit of your AVR's sub control, so that, before you turned it down, the sub needed, say, -20, but could only get to -12 so it was too loud. Then when you adjusted the sub, you got a setup that was within the Onkyo's maximum range, and sub was set right. You may be used to a "hot" sub setting, in other words.
Audyssey and your AVR have no magical powers. They are electronic devices residing inside the receiver. So after you do your setup, if you manually turn up the subwoofer, the AVR, lacking eyes, cannot see that you have made a change, so it will continue to send a signal at the same level it was sending it before. Maybe you did not adjust enough to be noticeable (generally 3 dB is considered "one notch" louder or quieter by most folks.
So if nothing happened when you changed the volume control on your sub, something may be wrong with the volume knob on your sub.
In addition to the location of the sub, the locations of the measurement positions are critical to establishing the data that Audyssey has to work with. You may simply want to re-run Audyssey and see if you get a more satisfactory result with different mic posigions (stay out of the center of the roonm, for example - - it's normally going to be a giant bass null).
Finally, if you take a moment to look over these pages, you'll find almost daily somebody saying its absolutely necessary to turn up their subs from where Audyssey and the AVR set them, and somebody else saying their system doesn't sound right unless they turn down the sub from where Audyssey and the AVR set it (that's my case). None of these people have been struck by lightning for using a sub level adjustment different from what comes out of the auto setup routine. (Best to do it in the AVR so you know what your preferred offset is and you can repeat it after anoter run, rearranging the room, or getting anew sub). So if you don't like the results, feel free to adopt your preferred setting. It's your system after all.
But I'd suggest you need to take a dep breath if you think your AVR is adjusting its output somehow when you change the sub's level after running setup. Simply not possible. Once your system is set up, changing the level on your sub should change the output of the sub, unless something's wrong with the sub. Contrary results indicate potential listener bias. Please don't be offended. I've been led astray by my own biases in the past, and likely will be in the future. It's part of being a human being.
post #23066 of 62191
Bought a used DTR-6.8 recently and just got it set up. I have a well-treated basement room, very quiet, and I switched off the HVAC system so the Audyssey calibration ran flawlessly.
Source is a new Oppo BDP-83, and I noted some buzzing between cuts when I first listened to the new setup. I presumed it was the sub (Hsu VTF-3), but when I disconnected both the power and the signal from the sub, I could still hear it. Not a 60 Hz hum, not a "white-noise-ish" hiss, but a buzz that was modulated and kept repeating a quick pattern, maybe 5-10 times per second.
Before running the Audyssey setup, I did a reset on the receiver to clear out the former owner's settings, and as soon as I hooked it up, I made sure that I powered it up and turned up the volume to 0 to +4 dB and only heard a bit of hiss with my ear close to the front speakers. This was definitely something that I didn't hear before running the Audyssey calibration.
It is definitely audible from my listening position at ~10 ft when no source material is playing with the volume set at -10 dB, which I find surprising given that I had to run the volume up substantially higher and listen within a foot of the front speakers to pick up any noise before Audyssey was enabled.
Went through disconnecting and reconnecting everything a few times, couldn't get rid of the noise. Mistakenly hit the "direct" button on the remote, and it went away...and I recalled that direct mode disables Audyssey. Switched back and forth between "stereo" and "direct", or "surround" and "direct"....in each case, when the Audyssey indicator on the display went out, the noise went away.
Just to confirm, the same thing happens when I go into the EQ page in setup menus and set the EQ to none or manual--in either case, no noise. Each time I enable Audyssey, the noise returns.
The noise is not unlike what I have heard at times from bad on-board audio on a PC. It's not simple hum, hiss, or static, it has a definite pattern that repeats, varies a bit, and then repeats again.
All components are on the same large surge surpressor on the same 20A circuit. The noise occurs simply because Audyssey is enabled, regardless of other settings, or which components are connected to the receiver.
Any ideas? Anyone know if the DTR-6.8 suffered from any of the issues with bad boards that plagued some other Onkyo units?
post #23067 of 62191
Hi Chris,
So is it even better to have the Heights 45 deg to the side and 90 deg (as opposed to 45) up?
post #23068 of 62191
It is definitely audible from my listening position at ~10 ft when no source material is playing with the volume set at -10 dB, which I find surprising given that I had to run the volume up substantially higher and listen within a foot of the front speakers to pick up any noise.
All components are on the same large surge surpressor on the same 20A circuit. The noise occurs simply because Audyssey is enabled, regardless of other settings, or what components are connected to the receiver.
Very nice elaborate explanation. Just one more question, does it come from all speakers or specific channels?
post #23069 of 62191
Hi Chris,
90 would be directly overhead, I think Chris meant as high as possible 45 being max. Let's hope he chimes in.
Noah,
Have you tried wides or heights? How do you like it?
post #23070 of 62191
This sounds like an electronics problem with the board that holds the DSP chip on which Audyssey (and other algorithms) run. I highly recommend that you contact Integra service to have them look at it. It is not a software issue. Could be as simple as a grounding problem or as complicated as a faulty board in your box.
