AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #1)
"Official" Audyssey thread (FAQ in post #1) - Page 839
post #25141 of 62230
I've been living with 11.1 DSX for a couple of weeks now and thought I'd share a few comments. Disclaimer: Adding the 4 extra speakers, in my particular case, was expensive and time consuming. First, my NHT VT/VR/VC-3's aren't made anymore so finding 4 more matching speakers was a challenge. I found two used VR-3's for the Heights and wound up making the Wides and a new Center from kits. (The build was quite an adventure by itself.) Second, I had to purchase a Denon 4810. Third, running wires to the new locations was a pain and hanging 40 lb. Heights was interesting. So I suppose after all that it could be argued that I'm going to like DSX no matter what.
The listening position reference for Audyssey was screen center at 14.5 feet. My speaker positions are:
Front: 24 Degrees
Heights: 35 Degrees, 18 Degrees up from ear level, 4 feet above mains.
Wides: 60 Degrees
Surrounds: 95 Degrees
Surrounds B: 155 Degrees
My Fronts and Heights placement are not optimum. I'm not sure how the 45 Degrees up elevation recommendation would be accomplished in most home theaters. I would think it would have to be some sort of ceiling speaker. My room is probably a little wider than most dedicated theater rooms allowing 10 feet as measured from the main LP to the Wides. All my listening has been with both the Wides and Heights engaged as well as PLIIx. All the movies have been Blu Ray with lossless audio. I'm using the Denon's amp for the Wides and Heights, an Outlaw 7x200 amp for the other channels.
The first movie I watched was Watchmen. It's raining in most of the early scenes in the movie so the Heights got a good workout. The first thing I noticed was the soundstage seemed larger, more enveloping and seamless. Whereas before when I heard a particular sound or effect, especially from the surrounds, it was obvious where the sound was coming from. Now I'll hear a sound to the left, right, front right, etc, but the speaker's location seems to disappear. The other thing I noticed is it appears that the sound field has more depth to the left and right of the listener. There is a scene in Watchmen where their flying machine Archie comes at you and passes off to the left. I actually caught my head flinching to the right. That was a first. Master and Commander was another nice DSX experience. During one of the later scenes in the bowels of the ship, you really get the sense that the ship is above and all around.
I will say that all movies are not created equal and therefore the effects of DSX are not equal in all movies. But, so far, I have not watched a movie where I thought DSX actually hurt the experience. By that I mean I have not heard anything yet that actually drew me away from just watching the movie because the sound effect, dialog, etc., was so out of place.
I should also say something about the SVS AS-EQ1 and Audyssey. I have two HSU 3.3 subs in a room that could use some acoustic help. Concentrating Audyssey to calibrate the area around the two front middle seats has greatly improved the lower frequency response in that area. The bloat, boominess, etc. is gone. Also, I did not lose any base output as has been reported by others.
Anyway, hadn't seen too many posts on 11.1 DSX systems so thought I'd share. Summing up I guess you could say that 11.1 DSX and calibrating using Audyssey MultEQ and SubEQ has been a positive addition to my theater. Attached are some pics. Colors are a little off, but you get the idea.
John
post #25142 of 62230
John,
Very nice theater.
"I’m not sure how the 45 Degrees up elevation recommendation would be accomplished in most home theaters. "
You would slide yours directly forward until they're at 45 deg.
post #25143 of 62230
John,
Very nice theater.
"I'm not sure how the 45 Degrees up elevation recommendation would be accomplished in most home theaters. "
Moving your speakers towards the listening position (on the ceiling) will increase the angle closer to 45 degrees; move them as close as needed. Not sure why people seem to think the speakers must be placed in the corner (or near the corner) of the room. You would need to have an extremely high ceiling.
post #25144 of 62230
Hi
I've set-up my new Denon AVR-1910 and KEF 2005.2 speaker system over the weekend. The first time I ran Audussey the crossover was:
FL: 150Hz
C: 150Hz (not sure on this one, could even have been 200Hz)
FR: 100Hz
SB: 80Hz
Since then I've 'fixed' the speakers to their new permanent location (same location as before, I've just secured them on a shelf). I've also moved the sub a few feet.
But since I re-ran the Audyssey set-up I'm stuck with the following crossover(s):
FL/R: 200Hz
C: 250Hz
SB: 150Hz
This seems excessively high! Am I doing something wrong? (I've gone through the 'official' guide) Also I'm using Qed Silver Anniversary XT cables (no plugs).
Any thoughts will be helpful!
post #25145 of 62230
why does my system sound better when im turning audyssey off ? Shouldnt it be the other way ??? Voices are much better with no audyssey . I think this should be explained .
My system is a onkyo 607 and the kef 2005.3 btw .
post #25146 of 62230
Not sure who you think owes you an explanation, but because very few people here can hear what your system sounds like from remote locations or read your mind some additional information about what aspects of the sound you find disappointing might help folks help you, if help is what you seek.
That said, maybe there are anomalies in your room/setup that impact the way you should run Audyssey. Read the guide if it's not too much trouble, and maybe you can determine for yourself a way to improve the situation.
Other typical alternative explanations are that it's possible that with Audyssey on your system is defaulting to dynamic volume, which, especially in stronger settings, will affect overall sound. Make sure it is off. Or perhaps what you're reacting to is the Audyssey curve, which rolls off highs fairly gently. Especially if your speakers are bright inherently, that might be a fairly jarring difference to your ears. It is my understanding that there is a way to get to the Audyssey flat curve on at least some Onkyos but I do not know what it is. Others may chime in. Finally, it's possible you're acclimated to the particular frequency response imperfections of your speakers in your room and a more correct frequency response sounds worse to you. Your system, so you get to chose how to run it.
post #25147 of 62230
Take and post a pic or two of the front of your room and tell us more about the room, e.g. floor, wall and ceiling composition/covering.
post #25148 of 62230
John,
Very nice theater.
Thanks Noah.
Moving your speakers toward the listening position (on the ceiling) will increase the angle closer to 45 degrees; move them as close as needed. Not sure why people seem to think the speakers must be placed in the corner (or near the corner) of the room.
I understand the geometry, I guess I'm thinking in terms of my speakers where moving them forward on the ceiling wouldn't work. Because my speakers are 2 ft in length sight lines would be blocked and even when angled downward, I know I'd wind up with speaker imprints on my forehead.
Having said all that, I guess I'm thinking too much in terms of my speakers. Smaller speakers would not have these issues. I felt it was important to match all the speakers so I'm stuck with behemoth Heights. I don't want to give the impression that adding Heights was a waste. Even at my angle I think they work.....maybe just not as well as they could.
John
post #25149 of 62230
I'm currently running a five speaker setup without a sub. Audyssey set my two fronts to large, and my center and surrounds to small. Shouldn't everything be set to large without a sub? Should I change this manually?
FYI per the specs, the lowest my speakers are rated for are as follows:
Fronts: 38Hz
Center: 55Hz
Surrounds: 55Hz
post #25150 of 62230
Originally Posted by gosparky View Post
I’m currently running a five speaker setup without a sub. Audyssey set my two fronts to large, and my center and surrounds to small. Shouldn’t everything be set to large without a sub? Should I change this manually?
Fronts: 38Hz
Center: 55Hz
Surrounds: 55Hz
Bass management - not Audyssey - is routing all content below the crossovers of the center and surround channels to the left and right front channels. The LFE channel is also being sent to the front left and right. It would be better if you had a subwoofer, but this is where you are right now and everything seems correct for this configuration.
What are the center and surround crossover points? And, how does it sound?
Jeff
post #25151 of 62230
Originally Posted by jgreyling View Post
Hi
FL: 150Hz
FR: 100Hz
SB: 80Hz
FL/R: 200Hz
C: 250Hz
SB: 150Hz
Guys can it be because of the 'furniture' I'm using? I've got the Front and Centre speakers mounted on an 5cm think MDF shelf about 80cm off the ground. It's also located in the corner of the room (no way to move it out unfortunately) if someone thinks that it might contribute to the 'problem'.
post #25152 of 62230
Ummm .. only if you consider those KEFs as "furniture" ....
post #25153 of 62230
Originally Posted by pepar View Post
Split the difference in the distance from the screen between the ears in the first row and the ears in the second row, and angle the front left and right speakers so that their 0° line intersects with the centerline of the screen/center channel speaker at that point.
Jeff
I did what you recommended here as well as turned the sub amp all the way down to about 9:00 (25%) and re-ran audyssey. The sub level came back at -3 so I went ahead and made the other recommended adjustments to crossovers and LPF. We watched the epic tale, Princess and the Frog with my 3 year old daughter and the sound was really good. The dialog seemed much better. Hopefully other movies with more dynamic sound will be improved as well.
Thanks again for the help everybody!
post #25154 of 62230
He he, my kids has already started to use the sub as a platform to stand on! I'm thinking of unscrewing the front speakers (from the shelf) and re-running Audyssey to see if that makes a difference.
Doesn't sound like there is any other advice on this topic, so I'll just have to do it the hard way...listen!
post #25155 of 62230
The speakers are too small to be detected as "supporting" lower crossover frequencies. Keep in mind that manufacturers' specs are made under, er ... optimal conditions and are not indicative of real world performance.
I'll be surprised if there is anything you can do .. short of replacing them .. to achieve much lower crossover points. Sorry but that is my advice.
post #25156 of 62230
Cool! Let us know how other things sound. You have probably gotten is as good as it can sound without acoustical treatments.
Jeff
post #25157 of 62230
Jeff
I plan on watching Master and Commander tonight so I will let you know how that sounds. I appreciate all of your input and knowledge, guys like you are what make these forums tick.
More room treatments will be added sooner or later but right now I just want to enjoy what I have for awhile!
post #25158 of 62230
I need some help guys. One of the receivers I am looking at buying is the Denon 4310 which has Audyssey MultiEQ XT. For those of you that have a lot of expertise with Audyssey, I need to know if the Audyssey correction system will help improve the sound in my room for which I have included the pics below. I do not have optimal set up conditions and I can't change the way the room is set up. The first pic is looking at my front and center speakers from directly across the room. I know the center speaker is high, but I don't have another option. The second pic is of the subwoofer, which is off to the right of the right front speaker. The third pic is of my seating. As you can see, I do not have optimum seating with center seating positions. My seating is off to either side. Usually I am in the recliner on the left side and my wife is on the couch on the right side, or vice versa. I have looked at the Pioneer receivers with the MCACC room correction, but I don't think they will work at all since MCACC must be based on having only one listening position. At least Audyssey takes into account more than one listening position to some degree to try and make everyone happy in the general listening area. So what do you all think? If Audyssey won't work well here, maybe I should look for a cheaper receiver option that doesn't include room correction. Thanks for any help!
post #25159 of 62230
Jeff
The center crossover is at 40Hz, surrounds are at 60Hz. I don't have any complaints about the sound, I'm just trying to get the best setup for more discerning listeners that come over... I'm just happy to be rid of using TV speakers!
post #25160 of 62230
People,
People, after experimenting with various mic positions, Audyssey measuments and crossover settings I think I finally got a keeper setting within my system but yesterday I was thinking about something I have not found an answer to.
My theater is basically used by me only so when creating the "acoustic buble" from Audyssey would the mic positions still be the same? that is, where I sit and around me or where I sit and very close positions around me? What are the general thoughts about this?
My receiver is a Denon 4308CI which only amplifies the surrounds and my theater is built around my stereo system which has the best quality components in relation to the whole system and my room is very well treated for stereo so Audyssey is very helpful in this respect (for surround sound) but I have discovered that for Audyssey to deliver its best, mic positioning is imperious.
Any thoughts?
Michael
post #25161 of 62230
Originally Posted by SoundMike View Post
People,
Any thoughts?
Michael
Experimenting , Why do you need to experiment, I though Audyssey takes what you have and works the Audyssey magic and presto magic its sounds perfect and balanced in every mode of listening. I was told that Audyssey doesn't need any user help, just run as per the instructions and enjoy, no experimenting needed. Tell us more of what was needed of you, to make it all work for you.
post #25162 of 62230
s u b w o o f e r
post #25163 of 62230
Front: 24 Degrees
Wides: 60 Degrees
John
that is an incredible room
kudos to your hard work!!!!
I would love to watch a good movie in it!
post #25164 of 62230
Hi Michael,
MultEQ needs information from several spatially separated locations in order to capture the acoustical problems in the room. This is especially important for low frequency problems. The mic positions do not necessarily correspond to seating locations. For example, extreme off axis seats near the side walls or the back wall should be avoided. But, the pattern of measurements is the same whether you have one listener or more. Please take a look here for a diagram showing the recommended placement and some more discussion.
post #25165 of 62230
a question for you pros.how does audessy compare to software like HOLMImpulse and ARTA and doing these kind of measuements?
thanks
post #25166 of 62230
Audyssey does work its magic but for it to do so it has be fed data about your room and that data is collected thru mic placement. Depending where you place the mic Audyssey will perform differently. Right now my system is sounding good and calibrated I was just wondering about different mic placements for only one HT user.
all the best,
Michael
post #25167 of 62230
all the best,
Michael
Originally Posted by audyssey View Post
Hi Michael,
I've done it and you are 100% right, with experimenting with many mic positions, eventually you will find the combo that works with your room that your ears can agree with.
post #25168 of 62230
Hi Michael,
Then I problably already got it right because everything is sounding good with the flat option (my room is small and has a lot of acoustic treatments) and the mic positioning I did.
But does the first measurment also get acoustic info or is it just about distance and level? If so, should we place one of the following measurements at the main seating location again?
Michael
post #25169 of 62230
s u b w o o f e r
Your powers are amazing. I just checked my email and it's supposed to be delivered today! (It was supposed to be backordered for another month).
Can't wait to rerun Audyssey!
post #25170 of 62230
Your adding a sub to your set up for the first time?
GOOD LUCK
