Originally Posted by streetsmart88
Chris,
First of all, let me congratulate you again on your product. I believe in it and I love it.
Having said that, I am curious about 2 seemingly contradictory statements (I am sure there is a perfectly rational explanation):
1. You have stated that it is totally unreliable to set the subwoofer level using a typical Radio Shack SPL meter at a single listening position.
2. On the other hand, you have stated that Audyssey determines all speaker levels (including the subwoofer) from a single postion - the first mic position.
How do we reconcile these 2 statements?
Chris,
The problem with the single position subwoofer level using the RS meter is that the RS meter uses an RMS detector that doesn't know about frequency response. MultEQ uses a spectral (frequency response) method that looks at the total energy from the subwoofer in a particular frequency range and compares it to the total energy in the satellite speaker in a higher frequency range. So, it's not as sensitive to the standing wave problems that occur at individual frequencies when measuring with an SPL meter at a single position.
Chris
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
??? I think the loudness gene must be firmly attached to the male chromosome...
