AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #1)
"Official" Audyssey thread (FAQ in post #1) - Page 1062
post #31831 of 62262
Yes I was hoping it would add general ambience. Your answer clearly indicates that my rear ceiling speakers need be used for rear.
Joel
post #31832 of 62262
Originally Posted by batpig View Post
1) Yes, the "wide" speakers connect to the "wide" speaker terminals. see the diagram on pg 50 of the manual.
2) DSX is not an EQ process, it's a surround expansion processing (like PLIIx). Audyssey MultEQ does the EQ'ing. Setup is easy: Hook up the speakers. Go to AUTO SETUP start screen, make sure AMP ASSIGN = NORMAL (which it already would be for standard 7.1), and then use the "Channel Select" menu to tell Audyssey which "extra" speakers to measure (in your case surround back + front wide). see pg 53 of your manual. Re-run Audyssey and go to it!
3) Wide speakers are no different than any other speakers in this sense. If you want to use a wireless speaker for ANY channel, it's possible. But wireless speakers generally suck, which is why you wouldn't use them
4) The "A-DSX" button on your remote turns on DSX processing, which will automatically shut off the rear surrounds. Hitting the "Standard" button should re-engage PLIIx, which will shut off the DSX speakers.
5) Of course, you have two subwoofer outputs! Have you looked at the back of your receiver? You would have to re-run Audyssey at that point, instructions for dual subwoofer setup are in the Audyssey Setup Guide.
6) Correct, the "wide" speakers are an extension of the front soundstage so they should be in line with the center and left/right main speakers. I don't even understand your second question.
I finally got around to setup DSX on my 3311 (based on help from batpig's post) and I went with wides (so I have 7.1 but added wide). Here are all the values that I got after MultEQ XT calibration in 8 positions:
Speaker Config Check:
Front - Large
Centre - Small
Subwoofer - Yes
Surround - Small
S.Back - Small (2spkrs)
F.Wide - Small
Distance check:
Front L - 12.5ft
Front R -13.0ft
Center - 11.9ft
Subwoofer - 15.7ft (located outside front right speaker)
F.Wide L - 9.5ft
F.Wide R - 9.2
Surround L - 8.0ft
Surrond R - 7.1ft
S. Back L - 4.3ft
S.Back R - 2.6ft
Channel Level check:
Front L - +2.0dB
Front R - +1.0dB
Centre - -4.5dB
Subwoofer - +2.0dB
F.Wide L - +2.0dB
F.Wide R - +2.5dB
Surround L - -5.0dB
Surround R - -5.5dB
S.Back L - +1.0dB
S.Back R - -2.5dB
Crossover Check:
Front - Full Band
Center - 120Hz
Surround - 150Hz
S. Back - 150Hz
F. Wide - 200Hz
Perhaps some of you experts (Chris or others) can help me out in validating this. I am not sure if these are correct though, as I read that all the speakers should be set SMALL but as you can see from the above values, my Fronts were set by Audyssey to FullBand/LARGE. Is that a problem ? And if so should I correct any of these values on individual speaker basis or would I need to rerun all the measurements again ? I am sorry I am asking silly questions, I am just not sure if these are the right values ??? But then once again , I am not sure what are the right values versus wrong/incorrect - perhaps these are correct ???? When I was doing the measurements, I forgot to close the window and a few cars went by during the process, would that impact anything ? The cars were not extra noisy but I could hear them driving by. Perhaps that skewed the measurements a bit ? Or maybe they are right, I just don't know.
Please help
Thanks in advance.
Nikonowski
post #31833 of 62262
Cars or no cars, I would set the fronts to an 80Hz crossover.
Have you listened to your system since setting up Audyssey?
Jeff
post #31834 of 62262
This question may already be answered within this thread if so sorry.
I have an Antimode 8033 I use in my existing setup with 3 DIY subs. I just ordered an Integra DHC-80.2 with XT-32.
Is it worth even keeping the Antimode if using Audyssey? I think I may sell my antimode? Any help would be greatly appreciated.
post #31835 of 62262
Jeff
More importantly, perhpas, have you read the Audyssey setup guide in Pepar's signature? All is revealed there.
post #31836 of 62262
Ahhh, did you ask that on an Anti-Mode thread, too?
Many have not felt the need for their SMS-1/Antimode/parametric EQ once they moved to a receiver/processor with Audyssey. Some have kept theirs, but I am not convinced that they have a sound, logical reason.
You could try it with and without and see what you think.
Jeff
post #31837 of 62262
Audyssey and Anti-Mode 8033 represent two very different approaches. The latter tries to optimize a single seat while the former tries to optimize several seats.
Has anybody tried to use Audyssey in a single seat setup and can provide some data?
post #31838 of 62262
Yes, there have been those who have taken the minimum measurements clustered around the location of their .. head. I don't recall what degree of success they had, but I also don't recall if they ever posted the results or if I purposely forgot because it seemed such a low bar. I can say that Audyssey has dramatically improved my main listening position even though I ran Pro and measured 13 places scattered around my listening area.
Jeff
post #31839 of 62262
"low bar"?
post #31840 of 62262
"low bar"?
Equalizing for only one seat.
Jeff
post #31841 of 62262
The 8033 also has the possibility of averaging readings over a number of positions, a feature I routinely use.
post #31842 of 62262
...Has anybody tried to use Audyssey in a single seat setup and can provide some data?
I don't think you mean take only 1 measurement, or even all measurements in one spot, which is surely not recommended. But lots of folks, including myself, do a "single seat setup" in a sense. For my living room HT, I optimize for my seat alone, the zero-gravity leather recliner (see below). It may not appear so in the shot, but the recliner is centered on the screen, 9' equidistant from FR/FL/CC and slightly forward of the in-wall surrounds. My wife is typically reclined on the couch off to the side, closer to the right surround. She, like most guests, is not really a critical listener, but certainly can appreciate how much better it sounds with Audyssey.
I make mic pos #1 as close as I can to right between where my seated ears would be and then I take 5-6 more positions within about a 2 1/2-3' diameter arrayed to the front of #1. I stay within the angle the FR/L speaker tweeters create. Sometimes I take 1 or 2 samples slightly behind and to the side of #1, but I don't want to get too close to the back wall. None of my samples are "in", or even within 2' of, any couch seat. I basically use the typical array pattern for mic positions which you have probably noted in the Audyssey setup guide. BTW, this discussion has lots of additional clarification and helpful hints. As for data, I can only submit my subjective opinion (but based on sound experience, he-he): ni-ice!
post #31843 of 62262
The Anti-Mode 8033 can only use data from a single second measurement to do some averaging.
post #31844 of 62262
Why?
But lots of folks, ... ni-ice!
I'd like to see some data before jumping into conclusions. The ear is no measuring device and can't be used as such.
P.S. You should get rid of all that clutter between and around the speakers and a chair with such a high back. All of that causes diffraction and results in very early reflections. Those reflections can have a negative effect on summing localization.
post #31845 of 62262
Why?...
As to the first question, there are literally dozens of mentions and explanations on this thread about using the max # sample positions available (6-8 for non-Pro users) so Audyssey can obtain a better sampling of the sonic problems of the room/speakers for optimal filtering. Use "search this thread", advanced with "audyssey" in the name box and something like "mic positions" in the searchbox and you will get many pertinent hits such as this, this, this and this. I referred you as well to the "Ask Audyssey" section in which Chris addresses many of these issues, such as mic placement and high seatbacks. During measurements I simply cover the chair with a blanket and tilt the seat back to normal listening position, placing the mic about 8-10" off the surface. It seems to work quite well. As to your "clutter" comment, each of us finds his own compromises in regards to equipment, room, furniture, etc. There are pluses and minuses to a living room HT (and to a dedicated HT as well, for that matter). I have done what I feel are reasonable trade-offs. I moved the recliner away from the back wall and the entertainment center away from the front wall. I repositioned the CC off a low shelf and moved the FR/L closer to MLP arrayed into an equidistant semi-circle with the CC. With plant camoflage, this was all acceptable to the wife. The drivers in the FR tower fire above the nearby chair/ottoman. As for relacing the zero grav recliner, NO WAY. My back is very thankful and my ears are not complaining; quite the opposite in fact, they are delighted with MultEQXT. Though imperfect, they are really my ultimate "measuring device" as a musician (not an engineer). The goal, after all, is overall comfort and enjoyment of music and film, not a nice looking graph.
post #31846 of 62262
Two comments re one mic position...
Originally Posted by audyssey View Post
Originally Posted by saprano
Yea i was thinking of trying not moving the mic at all, i dont know, i've been hearing some people say they got good results that way.
I don't think so. We spent 10 years of research in the lab at USC proving that single position EQ does not work for many reasons. Don't confuse a single mic position with a single person position. A mic is about 1/2" wide and most of us have heads that are bigger than that. Some of us have heads that are way bigger...
The information captured at a single mic position is totally inadequate to create a room EQ solution. The space must be sampled at multiple points in order to understand the weighting of the problems and thus give the room correction algorithm enough information about what to do.
Furthermore, this problem can not be solved with bands. "Bands" implies some form of parametric EQ and that just applies gain or cut at a few frequencies. Shaping the response to undo the room issues requires hundreds (or thousands) of control points that allow you to "morph" it into what it needs to be to undo the room distortions. And that's just half the story. Bands only look at the frequency response. You have to also look at the time response to understand the contributions of the direct and reflected sound and how they are distributed in the listening area.
it's been discussed about a hundred times.
two questions:
1. is your head the size of the tip of the microphone (i.e. less than 1 cm wide)?
2. if yes, do you keep your tiny "pin" head locked in a vice when listening to movies or music?
If the answer is "yes" to both, than you might only need one measurement point
Add: 3. Do you have more than one ear?
Note: I think Kal's question should have been: "Do you have only one ear?" in order for the answer "yes" to make "sense" but I think you all get the idea anyway...
post #31847 of 62262
Rickardl: To make it absolutely clear I think that one ear should be on top of your head facing the ceiling!!
post #31848 of 62262
After everything is set up, it *is* the ear that is used to "measure" our audio systems. And if it is set up correctly, the measuring ceases and the enjoyment begins. If SoM says his system sounds nice, then I accept that that is the case, and that he is enjoying his theater.
I am not saying that measuring isn't necessary because it is, but the final measurement is our ears.
Jeff
post #31849 of 62262
Have you ever looked at data from real rooms? I measured a couple of rooms and I couldn't find large deviations when the data points were within the diameter of a human head (about 17cm = 7 inches). So a single data point can be sufficient for proper single seat optimization.
post #31850 of 62262
Jeff
No, the ear can't measure anything. You might perceive the sound as "good" or "real" but that's about it. This is just a subjective assessment and has virtually no meaning when talking about room optimization because 99.9% of all consumers don't know the original - the original is what was heard while mixing/mastering. Only measurements will guarantee best possible sound reproduction. That's exactly the kind of thinking Audyssey or the Anti-Mode 8033 stems from.
post #31851 of 62262
Hi Markus,
Single position EQ will, in most cases, create more problems than it solves. Especially for low frequencies, where a few inches can make the difference between having the mic on the peak or dip of a standing wave. I a few weeks, Tom Holman from Audyssey will be presenting a paper at AES that analyzes measurements from several hundred rooms (from our database of over one thousand). You will see that there are huge variations (10-15 dB) from position to position at low frequencies.
post #31852 of 62262
For the 8033 correcting only the lowest frequencies, I can see how a single measurement might be sufficient for a single listening position. Is that what you mean?
Not so for MultEQ, which is attempting to correct the whole impulse response. I think Chris and his team have measured a *lot* of rooms.
post #31853 of 62262
I'm not so sure that we are disagreeing, just placing emphasis in different places. You are on a thread of consumers who are more than likely to know what good sound is. We/They certainly have opinions on what that is.
All of the equipment selection, room treatments, optimization, etc., works toward one thing and that is the perception that the sound and picture are good and/or real.
Having said that, do you think that it is possible for two rooms/systems to measure the same and sound different?
Jeff
post #31854 of 62262
Some relevant data on number of measurement sampling points here:
http://www.aes.org/e-lib/browse.cfm?elib=14319
post #31855 of 62262
The only room I looked at is my own living room.
post #31856 of 62262
That doesn't answer my question. I know what Audyssey recommends but they never answered the "why" sufficiently. Do you know if Audysseys gates the impuls response it captures? If yes, then how long is it? And where is the psychoacoustic data that proves that they chose a meaningful gate time?
If sound reproduction is the priority then you made the wrong trade-offs. Just my 2c.
post #31857 of 62262
Hi Markus,
Hi Chris,
Yes, I was talking about low frequencies and my measurements didn't show such huge variations when looking at points withing the diameter of a human head. I was specifically talking about low frequency optimization because I believe that EQs don't work at frequencies above the Schröder frequency. Maybe they work to some extend around the Schröder frequency but I'm still waiting to see scientific data that would prove this to be true. Especially for multiple seats where the seat to seat variance is huge.
Looking forward to the Holman paper.
Best, Markus
post #31858 of 62262
Yes.
That's what I believe too but as I said before, there's no scientific data I know of that shows that digital room correction can be anything more than speaker frequency response correction. And even that is pretty hard to do when the measured data is contaminated with strong very early reflections, e.g. from high seat backs. In those cases the data would be unusable. An automated solution would need to be aware of that. Do you know what Audyssey is doing in those cases?
post #31859 of 62262
And I thought the word "science" in "AV Science Forum" would have a meaning
That's pretty meaningless if the target is unknown. Audio is still stuck in the stone ages compared to video. Most people successfully ignore Audio's Circle of Confusion.
Jeff
No unless you're doing the wrong measurements.
post #31860 of 62262
Thanks Kal, I'll have a look at it.
