The two lines do operate at different signal levels, but that might be accounted for elsewhere in the circuits. Sill, I would rerun setup.
Attached is a before-and-after graph of my Audyssey Pro calibration on the Denon 4311. Red is Audyssey off and Green is Audyssey on. This is only with 1/12th smoothing so you can really see what is going on (most graphs use 1/3 smoothing). This is without my Behringer BFD in the mix.
I think the graph speaks for itself. |
... I'm seriously thinking of Denon 3310 (last years model) or this years 3311...
Just curious of your thoughts on if listener will appreciate the MultEq XT, in the newer Denon 3311 (for $230 more), over just MultEq in the older 3310? |
Jeff, the 3311 can be had from authorized etailers for less than 850, see this post on the 3311 thread. The 3310 was an anomaly, overpriced and under-featured in terms of SQ for the 2809 which it replaced. The 3311 is unquestionably the better value, despite its lower MSRP. MultEQXT is audibly superior. Happy hunting.
I did A/B tests of the Denon AVR789 (MultEQ) vs 988 (MultEQXT) with my Polk Rt800i towers (MSRP $1200/pr) and heard significant improvements with XT. The caveat is that the 988 had several areas of better build quality (better DAC's, AL-24, etc) over the 789 in addition to the XT, which is not so much in your case of 3310/11. What I'm trying to get across is that for a critical listener with "good" speakers, the benefit would more likely be there to justify the cost. In your case, I would say the limiting factor is your current speakers.
