Yes, it does.
)rigid clip style mic holder with a couple of turns of 1" diameter Velcro tape,similar to the Velcro ties that come with the cables except cut to length from a roll to fit the mic into the clip holder better.
I seem to remember this being asked and answered very recently ...
http://www.avsforum.com/avs-vb/showt...8#post19522788 |
I own the Energy Encore Home theater system. I love them but am forced to relocate the front speakers above the tv instead of under it. Because they are in a bookshelf configuration, I'm unable to use the center channel because of its width (with keeps it from being placed relatively centered above the set). I aquired an extra pair of sattelites thinking one would work as a center channel. However, when calibrating with Audissey (onkyo 705), it reports the crossover frequency as being 100-120hz for the front channels. Clearly the sattelites don't go as deep as the center channel did.
Here's my question, do any of the newer energy sattelites work will with the encores? I'd buy three for the front channels if they're still relatively small (less than 1 foot high)? Also for you encore owners who use audessey, do you get crossover frequencies that are high too? |
Originally Posted by mastermaybe
My XT-equipped Denon 3808 and Onkyo 805 set all trim levels post calib from -3 to to -8/9.
Originally Posted by audyssey
In that gear, MultEQ XT was setting the levels so that the speakers are all equal to each other. But, it wasn't setting absolute reference level. That started later when Dynamic EQ was introduced. So, it's expected that there would be differences in trim settings when you changed gear.
Chad T,
I seem to remember this being asked and answered very recently ... http://www.avsforum.com/avs-vb/showt...8#post19522788 |
So apparently I was actually listening to reference level when I had my 805 set to -5 on the volume knob. I actually watch some movies at -5 to -7 in my 18x11.5 listening room and I run subs 3 to 5db hot. I guess reference isn't as loud as I thought it was. And this makes me a bit concerned about my ears.
Isn't anybody reading?
![]() Translation: The 805 did not set levels to reference. Maybe it's your eyes? (Just kidding. )Jeff |
