AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #1)
"Official" Audyssey thread (FAQ in post #1) - Page 1188
post #35611 of 62743
Originally Posted by Gary J View Post
All the way up to 1k in fact. What then explains the difference we hear? There is just not that much under 1k in typical content or correcting above 1k is more important?
No, something's wrong. We should see a drastic difference at lower frequencies befor and after optimization. I hope that I did something wrong but removing measuring equipment and setting it all up again showed the very same results.
post #35612 of 62743
markus767, is this a couch shown on the measuring diagram? How big is it? Is it possible that it acts as a bass trap and the mic is not getting the bass properly because of that?
post #35613 of 62743
Originally Posted by Patrick Murphy View Post
...Chris never mentioned this very obvious difference.
But that may only apply to Japanese models and not US.
I had honestly forgotten that the ACM-1 had gold plugs It's been 3 years since the last ACM-1 was made so it wasn't something we keep seeing every day.
post #35614 of 62743
You would need a very big couch to get a significant effect. The graphs show no loss in low frequencies. So even if the couch is contributing to absorption, we should see MultEQ trying to reduce the peaks below 100 Hz.
post #35615 of 62743
Whoops! Well, I'm just glad that we finally have this straightened out and can rest assured that most of us have the correct mic even though some of the boxes are mislabeled.
Thanks for all your investigative efforts and the free mic that Onkyo sent me yesterday.
I now have 3 mic's so it could be possible that one of them would give you a more pleasing calibration considering the slight variance in the manufacturing tolerances, right?
And do you think that it's a good idea for those that do a lot of tests, to reset the AVR to clear out the memory, so it's not overly fuzzy?
post #35616 of 62743
Originally Posted by markus767 View Post
What make and model?
A Denon model but don't recall the model number; an Onkyo 885 and now the Integra 80.2.
Were your (after) measurements from a single position or were they averaged over some number of positions?
post #35617 of 62743
Markus....
what processor are you testing...is it a 4311?
Does the processor you are using allow you to look at what it thinks the result eq is after calibrating audyssey? If yes, does it show correction being applied?
Graphs look very strange.....
post #35618 of 62743
Each of the first 4 graphs show 6 measurements taken at the same locations from where Audyssey has been calibration. The last 4 graphs show the averaged reponses.
post #35619 of 62743
Onkyo TX-NR708.
No but I'll measure the preamp out tomorrow.
post #35620 of 62743
Originally Posted by rickardl View Post
But it doesn't explain why the people who now have replaced their original ACM1H microphone, which was wrongly marked ACM1, with another ACM1H microphone are reporting anything but subtle improvements.
As others have said, there could be numerous reasons - mic positioning comes readily to mind.
But what I think it really shows is how useless subjective assessments of sound are, especially when made with quite long time periods between assessments, as is necessary with Audyssey because of the protracted setup procedure.
Time and again, objective critics, such as www.theaudiocritic.com, have proved that unless you can level match to +/- 0.5dB and double blind test, objective assessments show that people can't tell the difference between systems using different amplifiers for example. If that is the case then it's not surprising that people 'remember' their sound differently when they rerun the Audyssey setup using the SAME mic more than once, as appears to have happened here. If the volume is a dB or two different (or the mic placements were different), then the sound will be perceived as different, and in many cases as "better" or "worse" (usually more SPL is perceived as "better"). Also, there is some psychology coming into play where some people may have genuinely believed that they were using a "superior" (correctly calibrated) mic or an "inferior" (wrongly calibrated) mic and this belief may have deceived them into "hearing a difference" that is in line with their prejudices.
Unless anyone believes that there is some sort of conspiracy going on, or that people are deliberately being economical with the truth for commercial reasons ( and I would 100% discount Chris from Audyssey from that as my belief and understanding is that he is a person of unimpeachable integrity, which belief has been reinforced by his actions since this whole issue came up) then it seems to me that this matter is effectively closed. Onkyo users had the correct mic all the time (other than the few who had *defective* mics, which is a different issue entirely) and any perceived differences after running Audyssey with two different, but both correct, mics can be attributed to the reasons above.
Just my two penn'orth as we say in England
Kind Regards,
Keith
post #35621 of 62743
And I always thought it was a tuppence.
post #35622 of 62743
Just don't start singing the chimney sweep song . . . or the feed the birds song, and everything'll be okay
post #35623 of 62743
Anybody with the Pro software having problems loading measurements onto the Audyssey website?The measurement file loads up real slow and then just stops and eventually Google gives me a time out error.It's been happening to me for the last 2 days.
Just wondering if it's just on my end or if anybody else has had this issue.
post #35624 of 62743
Re-ran MultEQ with the following mic locations:
Left speaker (mic location near Audyssey data points) - MultEQ off:
Left speaker (mic location near Audyssey data points) - MultEQ on:
Right speaker (mic location near Audyssey data points) - MultEQ off:
Right speaker (mic location near Audyssey data points) - MultEQ on:
Looks like MultEQ in my TX-NR708 (firmware 1041-0800-0010-2103) is doing nothing at lower frequencies!?
Markus, just to clarify, were these full-range measures of the Left/Right as Large/Full-range? Or did they include the sub?
If they were of the front speakers as full-range, that would explain much of what you see. I know when I upgraded to a MultEQ XT receiver with pre-outs, I found that Audyssey only had enough filter capacity to do very broad changes in the front speakers at the lower frequencies, say below 300Hz. The MultEQ version in your TX-NR708 has even fewer filters. This is one reason for the excitement around MultEQ XT32, but I've not yet seen anyone's room measurements comparing an XT32 receiver with an earlier Audyssey-enabled model.
Bill
post #35625 of 62743
If the mic gods align with your preference, then yes...
post #35626 of 62743
Originally Posted by gurkey View Post
I am unsure if the whole "truth" really has been told by whoever it concerns.
May be, they just wanted to avoid an expensive replacement / recall... or other cost intensive measures.
Those "after" comments don't sound like placebo effects taking place, but who really knows...
mine was NO placebo effect that ACM1 mic borked both my 707 & 807 AVR's settings even the Wife could tell the difference ... But I have the Correct mic's now & I'm happy
Thank You Chris !
post #35627 of 62743
Thank You Chris !
Let me get this straight: you are actually thanking me for making your wife happy I don't know if I'm comfortable with that
Hey, it's Friday....
post #35628 of 62743
She's in Menopause Soo Anything OR Anyone who makes her happy makes me happy !
post #35629 of 62743
TMI I'm sorry I said anything
post #35630 of 62743
Guys,
how is the level in dB of each speaker determined by Audissey? Is it calculated based on the aveage response across pre-established frequency ranges or just one specific frequency?
post #35631 of 62743
hey,
i her give a Hard Time about the Phase all the time soooo It's Cool !
post #35632 of 62743
Looking forward to getting my 5008 & XT32 ... can't wait !
couldn't wait on the Outlaw
post #35633 of 62743
Originally Posted by shumi_9 View Post
Guys,
Well, I would presume that your speaker should be approaching a flat in-room response after running Audyssey, so it shouldn't matter (much) at which part of the spectrum the it measures as they should all be about the same...
post #35634 of 62743
Chris, would you care to share any specifics or guidance on Dynamic Volume? In particular I'm curious about the targeted dynamic range for each setting (light, medium, heavy).
The light setting is a bit aggressive for my tastes, and I briefly switched to heavy but didn't really hear much of a difference, so it got me curious.
post #35635 of 62743
Light does the least dynamic range containing--I wouldn't think it would be aggressive at all. You may not hear it on most content except for the very loud. Heavy is the most extreme and is intended for late night listening. In all settings, it uses dialog as the reference. Set the volume where you want normal dialog to be and then it makes sure that nothing gets too loud or too soft.
post #35636 of 62743
Chris I saw you mention high humidity damaging the mic. I live in louisiana, what do I need to do.
post #35637 of 62743
I hear Phoenix is pretty dry . I didn't mean humidity in your house. More like a mic that got wet accidentally. It was just speculation to try to interpret the symptoms: excessively rolled off high frequency response in the mic
post #35638 of 62743
Thank you Chris for investigating and solving the issue of Onkyo mics!
I sent an e-mail to Onkyo USA about 4 days ago and they sent a new mic via FedEx up to Canada already! Guess I didn't need the mic after all, but I think I will try it. Overall very happy with my 906 and the results after Audyssey calibration.
Thanks again for your time and effort to solve this mystery!
post #35639 of 62743
They include the sub.
"Left speaker" is left speaker and sub.
"Right speaker" is right speaker and sub.
High/low pass in AVR is 150 Hz.
post #35640 of 62743
Here's sub and left channel preamp out with MultEQ (red) and without (green):
Did Onkyo license only MutEQ? Seriously, why don't we see anything substantial happening in the frequency response below 1kHz? Am I looking at the wrong graphs?
