AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #1)
"Official" Audyssey thread (FAQ in post #1) - Page 1226
post #36751 of 62191
Originally Posted by markus767 View Post
That's the wrong kind of pink noise for level calibration with a SPL meter. Don't use it. Use band-limited pink noise 500Hz-2kHz for the satellites and 20-80Hz for the subwoofer.
You are correct. A real good test one CD to invest in is the AIX
post #36752 of 62191
Originally Posted by Markiz7777 View Post
... Yes, it is with the receiver's test tones.
What would you suggest to use as far as external test tones? ...
I would stay with the receiver's test tones, as they bypass the Audyssey processing and the crossover setting, giving you a predictable comparison, and its pink noise band limits are close to what Audyssey is said to use.
If you use an external test disk, you have to worry about what band limits it uses for its pink noise -- not all disks are the same. Some include a setting for Dolby dialog normalization, some don't. You can spend more time verifying exactly how the test disk is constructed than you do checking the levels.
If yours are all equal, you can leave them as they are. Or, if you trust your RS meter more than you do the Audyssey mic and its built-in calibration file, you can adjust all yours up the same amount, thus keeping them equal.
post #36753 of 62191
Originally Posted by svbp007 View Post
The bottomline: Is there any specific measurement technique that will help reduce the "harshness"...
Searching through archives, found this statement by a member: "So here's my take on what's happening: I believe that the rolloff of high frequencies in the Audyssey setting is causing the mid-range frequencies to sound more forward (relatively speaking), and this is creating a harsh midrange presence in my environment. Once I add the high frequencies back to the mix, the mid range frequencies recede nicely."
I will do some more critical listening but Flat setting is helping a bit already but am not used to these high frequencies anymore - ...i.e. Audyssey flat has much more sharpness (not harshness) in the higher frequencies than Bypass L/R.
I don't think that there has been any correlation discovered between the results being too this or too that and a different way of measuring that changes that. But beyond the recent "my mic is wrong" situation, I don't think that there has been many situations where there really was something wrong with the results other than an expectation that was incorrect going in.
post #36754 of 62191
quick question. When running Audyssey, I have always run my sub with gain at 1/2, and crossover all the way up. In the past the crossover usually maxed out at 120hz. My new subs have a max of 180hz. I never really took into consideration that I should set it at 80hz. I always did this after audyssey ran, and I set my speakers and subs to 80hz. Should I run audyssey with the crossover on the sub turned to 80hz or just turn it all the way up?
post #36755 of 62191
I will reconfirm the mic situation. I do see posts here and there talking about how certain speakers are very sensitive to the mic placement and wanted to get some input. I will keep trying other stuff but at this point the Dyn Eq is giving great results for me (along with byp L/R) that I am Ok for now. The main area that I clearly see that I am missing out by using bypass L/R is the bass response. The bass response on audyssey is much more tight and "controlled" than what I get with bypass L/R. For the mid range, clearly I am not getting what I want. It is simply harsh (to my ears)...and is causing listening fatigue.
post #36756 of 62191
After Audyssey calibration I have the following crossover configuration:
Fronts - 40Hz
Center - 40Hz
Surrounds - 80Hz
Back surrounds - 120Hz
Should I go with:
Fronts - 80Hz
Center - 80Hz
Surrounds - 80Hz
or:
Fronts - 80Hz
Center - 90Hz
Surrounds - 100Hz
I will appreciate your suggestions
Mark
post #36757 of 62191
Originally Posted by Kal Rubinson View Post
Assuming the 885 is fairly identical to the 9.8 I have, I can say that updating the firmware is relatively easy if one can follow instructions carefully and is moderately comfortable with a PC. Same for using the Pro kit.
I wonder why the fellow at Audyssey said it was not worth the bother.
I have firmware 1.07. Is that ok for the kit?
post #36758 of 62191
Originally Posted by mphfrom77 View Post
Hey guys this thread is so large and I am having trouble finding the answer to this simple question.
I do not have a subwoofer, nor do I have an avr.
As one goes up the Audyssey food chain, will a subwoofer sound more musical?
For example one of the knocks on the BIC F12 is that it is not musical.
I know the filter resolutions are different when looking at both MultEQ and MultEQ XT with 128 filters, versus 512 filters for MultEQ XT32. I just don't understand what it means though. So I guess I can only ask what does it mean, and how much better can it make a subwoofer sound. Mainly, though, I am asking how much better can it make a subwoofer sound (I am thinking along the lines of someone running 2 BIC F12's, for example. Then maybe getting nicer subwoofers in the future.)
How would what XT32 can do, with calibrating the subwoofers separately and then pinging them together, affect the musicality of subs like two BIC F12's when comparing this to MultEQ / MultEQ XT? Are MultEQ and MultEQ XT the exact same as far as the subwoofer goes (basing my presumption on the # of subwoofer filters), or am I missing an aspect there?
If there are any links that you guys would rather provide, I'm sure that would be helpful as well. I guess that's it for now. Thanks.
Edit- Do the different Audyssey's change from year to year. Example: is this years MultEQ XT the same as last years, which will be the same as next years?
I never did get a response to this. So in light of the recent bass responses, I thought I would post it again. (The bic f12 has been getting knocked around lately for not being musical. So, I am asking in general, and maybe even specifically to bic f12's if I could.)
post #36759 of 62191
I just got a new pair of Polk Monitor 60s. I really love them but I am noticing a ringing in my afters after listening to them at reference levels. The highs seem a little harsh and really seem to cut right into my eardrums. This is worrisome to me. Is it possible to adjust the EQ somehow to cut down the frequency that's causing the issue? I'm running a Denon 1611. Any help would really be appreciated as I've searched for a while now and can't find the answers I'm looking for. I have heard ridiculous statements like "try different speaker wire" to "you need a tube amp." Some real suggestions would help.
post #36760 of 62191
Originally Posted by SoundofMind View Post
^Or I spose they might want the sub Audyssey EQ'd in stereo mode 2.1, or all speakers except their "very capable" FR/L EQ'd for MC. I disable this bizarre option as well, Bill.
SoundofMind; I enable front L/R bypass for 2CH analog and MCH SACD over HDMI, as well as DVD-A and HT. My FL/FR are flat down to 45hz! Audyssey sets my fronts to 100hz. I get better response setting the fronts to 60hz crossover, and set the Audyssey to "bypass FL/FR". My OPPO sends DSD to my Denon receiver, so I still get bass management this way, better than sending PCM to the receiver just for OPPO bass management. My F/C/R are all rated down to 40hz. Surrounds are rated down to around 50hz. I let Audyssey have its way, except for the fronts. Audyssey sets the center at 40hz, and it is very capable there. The surround L/R Audyssey is set to 60hz, and the SBL/SBR to 40hz. After fighting the 80hz crossover limitation in the OPPO for some time, I gave in to the Audyssey settings, and I am not going back to the OPPO crossovers. With the 60hz crossover and L/R bypass for the fronts, my Antimode 8033 and Audyssey L/R bypass tames the room modes for a wonderful blend with the fronts. With a DSD capable AVR, SACD sounds best letting the AVR do the bass mangement, and a more limited use of Audyssey.
One thing I might add, using the non Audyssey 60hz crossover setting and bypass L/R, I lose the bloated sounding mid's from 60hz up, vs the Audyssey 100hz setting. Good bass traps have allowed this, before the Antimode and bass traps, not so good!
post #36761 of 62191
Turn the crossover on the sub itself all the way up. This gets it up out of the way of the AVRs crossover.
post #36762 of 62191
Note that Audyssey does NOT set the crossover. It finds your speakers' actual in-room -3 dB point and reports that to your AVR's bass management setup, which then assigns a crossover frequency.
post #36763 of 62191
You can't expect a meaningful answer because "musicality" is not a property of a technical device.
I haven't seen any data that indicates SubEQ HT has any advantages over MultEQ applied to two subs connected via a y-cable. MultEQ is an averaging approach. It doesn't reduce seat to seat variations.
post #36764 of 62191
But yet as technical specs improve, i.e. the faithfulness in reproduction, so does the "musicality."
Only in that Sub EQ HT implicitly brings a much higher resolution than "MultEQ." But then it is Audyssey's data and *no one* has seen it.
Jeff
post #36765 of 62191
Jeff
Is higher resolution needed? Two subwoofer could be used to reduce seat to seat differences. MultEQ isn't designed to do that. Bummer.
P.S. We've seen a lot of data lately. There's also the Holman paper ("First Results from a Large-Scale Measurement Program for Home Theaters", AES Convention Paper 8310) proving exactly what I've said about seat to seat variance before and after MultEQ.
post #36766 of 62191
Good point. I guess I should fininsh reading Tom's paper.
post #36767 of 62191
I have a Epik Empire sub and want to use it for a center channel stand.The sub is located under my Plasma in front of the room centered in the middle of the room.I was going to use a center stand but the sub is much higher and the center speaker sits much higher so the sound is coming at a better height.Will the center channel speaker sitting on the Subwoofer have an effect on the Audyssey settings when it does the sweep of the speakers? Will the Subwoofer change the sound of the center channel?
post #36768 of 62191
Just look at the graphs on page 15 and 16. MultEQ does a wonderful job at EQing the response so the (calculated!) AVERAGE of all responses is close to the target curve but do you have 6 or 32 ears precisely located at the same locations where the Audyssey mic was located in order to hear the average response?
This leads us to another question: after optimization has been applied, the averaged frequency response from all data points that have been sent to MultEQ is closer to the target curve. Is this also true for all other locations within the optimized "bubble"?
post #36769 of 62191
...For me, bypass L/R is not at all a bizzare option...especially if what is said on Audyssey website is correct (i.e. it will make all the rest of speakers 'behave' like the L/R). It is best of both worlds almost for me because Audyssey EQ itself is making the sound a bit too harsh....
... I let Audyssey have its way, except for the fronts... With a DSD capable AVR, SACD sounds best letting the AVR do the bass mangement, and a more limited use of Audyssey...
bizarre=grossly unconventional or unusual-this seems to me to be a very apt descriptor of the Bypass L/R option. This is in no way meant to dismiss what you are hearing, your preferences, and your efforts to obtain better SQ from your gear and room. Simply put, I think it's odd if disabling Audyssey filters on the FR/L speakers makes your system sound better to you.
post #36770 of 62191
That's a bit harsh, Markus I think most of us have a good idea what he means by "musicality". I'd suggest he is referring to the properties that make his system sound like real music - timing, presence, good transient behaviour and so on. Often these words like "musicality" sound airy-fairy (do you have that expression in the States of does it mean something way different? ) but it's not easy to use words to describe sounds. HST, I can't give him any sort of answer, meaningful or not
Kind Regards,
Keith
post #36771 of 62191
I don't know about seat to seat variance but I can say for sure that XT32 made a fantastic difference to the bass in my room, with nothing else changed at all other than inserting the AS-EQ1 and thus getting the benefit of the much higher filter resolution as compared with my 5007's plain XT. The difference is astounding.
You seem to be saying, or this is how I am reading it, which may not be the same thing, that XT32 doesn't have many more benefits than XT and I'm sure that very few would agree with that if they have experienced both.
Kind Regards,
Keith
post #36772 of 62191
How high does EQ go for the subs in Audyssey ?
Can I set my xovers to 100 and know Audyssey has EQ 'd the subs above that?
post #36773 of 62191
Well from what I have gathered some subs are more for HT and others are more for music. I just basically wondered if the avr's equipped with the newest audyssey, xt32, helped the subs, more geared toward ht duties, in producing better sound with music reproduction moreso than an avr without it. And if it did improve in this scenario what kind of results would one expect. (Or would would this answer be more correct http://www.avsforum.com/avs-vb/showp...postcount=1922 which was a response I received when I asked basically the same question when referring to 2 bic f12's and xt32.)
http://www.avsforum.com/avs-vb/showt...116093&page=65 1921 1922
Are those papers you mentioned only available by purchasing them?
post #36774 of 62191
I don't know the upper limit of eq on the sub, but it certainly eq's up to 120hz which is the highest you want to set your Low Pass Filter in order to receive the full LFE range of frequencies.
post #36775 of 62191
Kind Regards,
Keith
The probelm is that any of these terms are subjective terms and might have different meanings depending on who you ask. In any case they are not suited to describe any specific property of a sound reproduction system.
post #36776 of 62191
You mean the EQ setting on the sub itself? You should use the bypass switch to defeat the sub EQ (if you have one) before running Audyssey. If your sub doesn't have a XO bypass switch, set the XO control to its maximum.
Kind Regards,
Keith
post #36777 of 62191
This is a very good point. The fact that all his speakers are equal is the important thing, IMO.
post #36778 of 62191
I agree. But they are the only terms we have if we are trying to use language to communicate about sounds. Most people interested in music would know what 'rhythm' and 'timing' mean I would imagine. 'Presence' is harder to define but I'd expect a system with good transient attack reproduction to have 'presence' too. If I said "my bass captures the rhythm and timing of the music well" I think most people would know what I was trying to say. The danger of course, is that it is so easy to stray into the area of the $5,000 interconnect and talk about "deep pools of inky black velvet between each note". There, I agree 100% with you, it's gibberish.
Kind Regards,
Keith
post #36779 of 62191
It doesn't really matter if a sub is for music or home theater. It even doesn't matter if it's a monopole, a ported design, dipole, unipol or whatever. It all depends on what your SPL requirements are and how your room behaves. Everything else is way less important. Most manufacturers try to make you believe it would be the other way around but that's simply not true.
You could also ask someone that has the paper to "lend" it to you.
post #36780 of 62191
I understood what he meant .
As this is the Audyssey thread .
You are coming off as a word cop now .
(not to inflame you)
,but that statement I just made is not suited to describe any specific area of expertise
(agin this is not to inflame you ,just making a point )
