AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #1)
"Official" Audyssey thread (FAQ in post #1) - Page 1267
post #37981 of 62282
Originally Posted by pepar View Post
My observations are the exact opposite, not that it doesn't do well in untreated rooms, but that it ices the performance of a system in a well-designed room. For the issue of LF response, it does seem to depend somewhat on where measurements are taken. But it has always improved even already good response and subs/mains integration.
Jeff
I would add this for clarification. Measuring low frequencies (below 50 hz and especially 30hz and below) is very problematic in small rooms. The fact that Audyssey is not perfect in this regard is to be expected. It is an automatic system, and even expensive and complex solutions can have problems in this area I describe. Playing around with sub gain and measurement positions can help. Sometimes a higher gain on the sub amp causes Audyssey to be more accurate down low with the before graphs (could be signal to noise ratio, I don't know). That is where the pro kit shines, you can play around and wait until you get a goog looking before graph.
Right now I have a great calibration, but Audyssye is boosting a touch from 20hz to 25 hz. So I can just goi in and create a custom filter edit, apply it, and bingo. I find that listening to a frequency sweep with Audyssey off and then on (graphs in hand) is very informative.
Other than that, Audyysey does a nice job with the bass (at least to my ears when I audition scenes with it on and off). Dynamic EQ doesn't hurt! Louder is better!
post #37982 of 62282
Originally Posted by gamelover360 View Post
Great filter resolution, but can have difficulties measuring really low frequencies in certain rroms (small etc.). Not just an Audyssey problem BTW:
Plese elaborate on what those problems might be.
post #37983 of 62282
Jeff
You've seen the data so what makes you believe the opposite is true?
post #37984 of 62282
Originally Posted by turk 182 View Post
I am sorry but could you elaborate on adequately protected.
A sub needs thermal or excursion protection in the face of high energy subsonic content. My sub model recently got a protection tweak because HTTYD was prematurely triggering amplifier protection if the "rumble" filter was disabled.
I tend to think of my room as small (<1,500 cf) although it opens into a somewhat larger room. In my case Audyssey brings the sub down a few dB to the "right" level. This is true of both XT32 and the Pro Kit.
post #37985 of 62282
Allow me to revise and clarify; my experience has been the opposite. I can't say categorically that it always improves LF response/performance, only that it has for my system and the other three or four I've worked with.
Jeff
post #37986 of 62282
Jeff
But you don't have any measurements besides the calculated response graphs from MultEQ to verify, right?
post #37987 of 62282
A few pages back, Craig posted some XTZ graphs that showed substantially reduced modal ringing. But beyond that, it was all judged by ear.
post #37988 of 62282
I have REW data showing MultEQ improvement for my "well treated" room at home on my personal laptop. Can post later if anyone's interested.
post #37989 of 62282
So you know what his graphs show? I'm still missing some important additional information.
Looks like you forgot to mention that minor detail in your original post. Probably just by accident.
post #37990 of 62282
I am.
post #37991 of 62282
Found that I had an older measurement on my work pc (below). These results aren't current, but I do believe current does have similar "overall smoothing" which I'll post later. One other caveat on this graph....I mistakenly ran the EQ on measurement with DynEQ enabled. Biggest diff that I recall with newer measurement was that the hump at 18-23Hz range was diminished.
post #37992 of 62282
Is there some way for you to choose other colors? I cannot distinguish the two you have now.
post #37993 of 62282
Do you have any measurements without Dynamic EQ engaged? If not then it would be best to remeasure everything.
post #37994 of 62282
Do you suffer from red-green blindness? Fascinating. What color do you perceive when looking at the graphs?
post #37995 of 62282
Indeed, I do. They both look pale blue to me. Not identical but not ascribable to the labels indicated.
post #37996 of 62282
The XTZ "waterfall/RT60" measurements like those are all single sweeps. How does it matter whether they are made with one speaker or all speakers?
Not an accident, just not used to having to support my every "observation" with charts, or include what charts might have been used.
Jeff
post #37997 of 62282
I too am red-green colour deficient, but what I see is purple and green lines...
post #37998 of 62282
Maybe it's your monitor Kal...these show fine on mine as purple and blue. To help distinguish the two, the line with the larger null at 80Hz is "without EQ".
Yes I do...at home on my personal laptop. That's the stuff I said I'd have to post later.
post #37999 of 62282
Just a note here, when someone says that they have a color-blindness, it is their eyes and not their monitor.
post #38000 of 62282
Hi drterb,
A couple of observations:
1) You should sit closer to the screen
2) Nearly all of your speakers aren't placed correctly
3) If possible you should turn everything by 180°
4) The screen is probably too big for the room
This is what it should look like (viewing angle 36° which is min. THX viewing distance):
Markus, thanks for the info and the time you put into this. Unfortunately, the doors are important so I can't flip it 180°.
I had pushed back the MLP about a year ago for a party and never moved it back up. I now have the MLP at 13.5 feet and that's about as close as I can get since my projector lives underneath the coffee table that sits in front of the MLP. This puts my SL & SR at about 95°.
I pulled the trigger on an Onkyo TX-NR5008 yesterday so I'll be able to mess around with Audyssey in a few days. I'll move my fronts farther to the left and right of the screen and then try out some speakers for the heights/wides to see which sounds better.
Thanks for everyone's help and if you have any further suggestions, let me know.
post #38001 of 62282
OK Kal....just for you.
post #38002 of 62282
Interesting reply Jeff, I have always found it interesting that when someone finds out that I see things differently (visually that is! ) they say "that must be weird..." I usually reply, it has always been the same for me, and I point out that the name for a colour is somewhat subjective, just look at what the car companies or house paint companies call the various colours they use.
Still, even my wife uses this as the excuse that I make questionable choices for colours when it comes to cars, decorating or the like!
(BTW, I know that this is totally different the setting colours for a display, or painting a wall, but the truth is as long as I can match the colour on the screen or wall to a known standard, I will "see" what is expected. Whether I like it or not is another matter entirely.)
At least I think that my hearing is still OK.
post #38003 of 62282
Because what we perceive at low frequencies is not the response from a single speaker but all speakers emitting the low frequency signal.
Jeff
You don't need to support your observation with data as long as you don't present your opinion as absolute facts.
post #38004 of 62282
It depends on the ratios of long and medium wavelength receptors. Not all of us R/G deficiency sufferers suffer equally.
post #38005 of 62282
post #38006 of 62282
By the way, color blindness would make a good argument why any of our senses can't be used as a measuring device for calibrating a technical device.
post #38007 of 62282
For RT60/decay, which is what I mentioned (because it was the easiest to "see" in a graph), it makes a difference whether the room was energized with one speaker or multiple speakers?
That's a problem then because my opinion is always absolute fact.
post #38008 of 62282
When I posted that I had not yet seen his confirmation of it. The replies on this thread come faster than my wife can spend money.
post #38009 of 62282
There's an auditory analog to color-blindness?
Markus makes a good point about calibration relying on any of our senses, unfortunately there are a lot of folks who mistake these adjustments to sound and colour as 'calibration' when in fact it it is just personal preferences...
Nothing wrong with preferences, but they are not calibrations.
post #38010 of 62282
Al et al .. lol
I have made .5dB tweaks to the Pro target curve that I could not "see" on system response measurements, but yet were audible to myself and the two other chaps that were helping. One could argue that it could have been measured with more sophisticated gear, but then my reply would be that who besides a pro acoustician would have such gear?
