AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #1)
"Official" Audyssey thread (FAQ in post #1) - Page 1412
post #42331 of 62741
Originally Posted by randyc1 View Post
Just read the article "Minimal EQ"
Which Minimal EQ article are you referring to?
post #42332 of 62741
Written by Wayne A.P at the Hometheatershack
post #42333 of 62741
Just read the article "Minimal EQ", I don't know if you are familiar with this article, but it basically says, using the least amount of filters to correct low freq the better..... I just had a question regarding Audyssey XT32 . Just looked at the AUDYSSEY WEB SITE . ...Does'nt Audyssey potentially put Dozens , if not hundreds of filters on the Peaks and Nulls (which i thought was a no-no) on the FR to correct it .?? Is'nt this the complete opposite of MIN EQ ??
Hi Randy, I think you can't beat Audyssey for the number of filters, coz it uses only 1 filter per channel with 10s of thousands of correction coefficients. I also don't know what article you are referrning to, but I suppose its about PEQ (parametric eq) where I also tend to agree with the article.
post #42334 of 62741
Just read the article "Minimal EQ"... by Wayne A.P at the Hometheatershack
What's being discussed there is not quite applicable to Audyssey for various reasons. I suggest you try both approaches (or others) and see if you have a preference.
post #42335 of 62741
Originally Posted by defmoot View Post
By the way, mogorf
Sweeeeet set-up and such a nice space. Appeals to the industrial designer in me.
Thanks for your kind compliments, its the job of an interior desinger studio with close cooperation of myself and my better half. Fortunately its a symmetrical room good for HT purposes, and please also note all cables are successfully hidden!
post #42336 of 62741
Originally Posted by gurkey View Post
Flat means what the word implies: a straight line.
It implies a bit more than that - that the line neither rises nor falls.
A smoothly rising or falling response can also be drawn with a flat line.
post #42337 of 62741
Hi Noah.... A Pedant Writes: I think the common usage of 'flat' is something along the lines of 'horizontally level'. When one 'flat lines' in hospital, the trace on the scope is horizontal, for example. Similarly, the flat earth conceit was that the planet was horizontally level, not a gradual, but even, slope leading to the place where there be dragons... And a 'flat roof' is just that - i.e. not sloping... I could go on......
Forgive me, I've not been getting out much lately...
Kind Regards,
Keith
post #42338 of 62741
Originally Posted by rickardl View Post
This shows the roll off by THX Re-EQ and the roll off by Audyssey Reference (including midrange 2K dip), Audyssey Flat would be at 0dB.
Thanks for the graph! It seems to me that flat almost has less depth (Guess that is the word I am trying to use LOL) and it seems maybe less bass, almost like the higher frequency is drowning it out. The flat does have a pretty sharp sound but the audyssey curve seems to have more depth and sound. I was told that by using "Audyssey reference curve" I would be missing out on sound/detail particulary in the higher frequency range....guess that was the wrong info. I did prefer the flat curve on my 3311Ci with multXt...is there a difference on the MultX32?? It could also be I really never compared them since I was told flat was a LOT better LOL!!
post #42339 of 62741
Kind Regards,
Keith
Hi Noah and Keith,
Don't we use the word "flat" in a much broader context? Aren't our LCD monitors setup vertically on our desks that have a flat panel display? Isn't the business use of a "flat rate" an everyday example having no orientation properties out in the 3D world? Finally, how would you refer to this if not called flat, regardless of orientation!!!! Just wanted to write something!
post #42340 of 62741
It's the same 2 target curves with all flavors of MultEQ, but XT32 has more capability to bring you closer to those ideal curves. With Audyssey Pro, there are 3 curve choices and you have the capability to modify them within certain limits.
post #42341 of 62741
Originally Posted by mogorf View Post
Hi Noah and Keith,
Very good points. I myself have lately been wondering about flat irons. Does "flat" refer to the bottom surface of the iron or the clothes that it irons or the items it flattens due to its weight?
Mark
post #42342 of 62741
Thanks for your comments Rene. What I was having in mind was that Audyssey during the first measurement (at the MLP) takes care (among others) of time alignment of all speakers in the system ("time" is better word here than "phase"). But if there are fronts like the Jamo S606 that have drivers at different physical distances to the MLP I'm not sure the test will not be thrown off. S606 has the tweeter and mids up front while the woofer is side-mounted.
Rene, anyone?
Yes, Audyssey does distance correction and, yes, distance is a proxy for phase but, as you point out, it's relatively easy to imagine (and end up with) situations where distance is too simple to account for phase. That's probably a contributing reason for why everybody (serious?) stick with calling it 'distance'.
post #42343 of 62741
While we are at this subject, what's your (or others reading in) opinion 'bout speakers like the Jamo S606 with drivers "all over the place"? I looked into the spec sheet of this particular speaker and found that the internal cross-over of this box is rated at 150 Hz. This suggests to me that even with a cross-over set in the avr to 80 Hz there will be a range between 80 Hz and 150 Hz where this side-mounted woofer may cause unknown/unwanted phenomena for Audyssey of which acoustic results are hard to discribe/predict without hearing it, yet remains just a theoretical approach on my side needed to be further investigated.
post #42344 of 62741
Hi Noah and Keith,
I'll take that definition over my flat roof anyway.... you win!
Kind Regards,
Keith
post #42345 of 62741
While we are at this subject, what's your (or others reading in) opinion 'bout speakers like the Jamo S606 with drivers "all over the place"? I looked into the spec sheet of this particular speaker and found that the internal cross-over of this box is rated at 150 Hz. This suggests to me that even with a cross-over set in the avr to 80 Hz there will be a range between 80 Hz and 150 Hz where this side-mounted woofer may cause unknown/unwanted phenomena for Audyssey of which acoustic results are hard to discribe/predict without hearing it, yet remains just a theoretical approach on my side neede to be further investigated.
I'm afraid I have neither experience nor pertinent facts about this issue.
post #42346 of 62741
Kind Regards,
Keith
Kind regards to you as well, Keith!
post #42347 of 62741
Yes, that's common usage; I should have gone with my ignored impulse to preface with "Warning: geek attack".
But I'll point out that flat panel displays are flat whether they're level or not, as are all other flat surfaces.
Kind Regards,
Keith
post #42348 of 62741
I think it's time to move on
Anyway, Feri won this round with his superbly illustrated example
Kind Regards,
Keith
post #42349 of 62741
I have just run the Audyssey MultEQ/XT on my new Denon AVP-A1HDCI(A) and I am confused about some of the results that you can view after it has completed its 8 runs.
1. Why do I not get any crossover frequencies shown for any speaker?
2. Why are there no EQ curves for the subs (x2) but there are for the 9 main speakers?
3. After the EQ process is complete and I set all speakers to small why can I get a far smoother sub response (125HZ down to 15HZ) using my SMS-1 than I can ever get with the Audyssey alone?
4. Why does the center volume now seem about 3dB too low compared to the main L/R channels even though it measures correctly when checked with pink noise?
My main speakers are 5 Genelec 1038's LF/C/RF/LR/RR, 4 Genelec 8040's for surround and rears and two SVS PB12 NSD's. The two subs are at the very front of the room placed 1/4 width in from each side wall, the ONLY place I can fit them.
Any help or advice would be gratefully received as I am sure that I am doing something wrong.
post #42350 of 62741
Is it chirping the subs during setup? Your symptoms suggest that it thinks you have no subs.
After the EQ process is complete and you set all speakers to small, is the "Audyssey" light still illuminated on the front panel?
Jeff
post #42351 of 62741
Hi All,
Looking at newer recievers by Denon (4311ci) and Onkyo (3008). Both have XT32 in them. The Denon being the one with installer ready turned on and Onkyo not turned on. I called Audyssey to ask if maybe it was a typo and they said no it's inside the Onkyo but the company chose not to turn it on. I asked the question of. If Onkyo wanted to turn it on in an update could they? Audessey said yes they sure could. Well I'm not very hopefull on Onkyo doing that but the real question is should I go Audyssey Pro kit capable reciever (Denon) or do I really get enough resolution filter adjustments with either reciever with XT32 and AS-EQ1? I do want it to sound as true to the mixing stage as it can be, no more, no less. I'm old school and have done the fun of tweeking the Berrenger PEQ days with a mic and laptop software measuing tape in hand. I've setup the Outlaw audio crossover that I felt the home theater world needed years before in it as I used in the profession audio and car audio world. For me now I want to do more watching and enjoying movies/TV shows and set it and enjoy it. Thats why I bought the AS-EQ1 to begin with. To balance out the bass problems in a room with using 1 or multiple sub's. If I move things around in the room then sure run the setup again even if you recommend the Pro direction. I'm currently using a year 2004 Yamaha reciever that EQ's single location mic's the sweet spot that doesn't work so well with AS-EQ1 or the fact that I want each seat to hear as close to what another setting location hears true to the sound mixing stage, which has brought me to buying said reciever with Audyssey in it.
Thank you for your time...
post #42352 of 62741
Originally Posted by Chris Young View Post
... the real question is should I go Audyssey Pro kit capable reciever (Denon) or do I really get enough resolution filter adjustments with either reciever with XT32 and AS-EQ1? I do want it to sound as true to the mixing stage as it can be, no more, no less...
Hi, welcome. IMO XT32 is state of the art reasonably priced room correction with plenty of coefficients available for sufficient resolution in the filters and it handles 2 subs very very well. I highly recommend it for someone like you. And I highly recommend you get a model with Pro kit capability, especially with your stated goal. You'll love the refinements Pro brings to the SQ, and its tweakability. I'd say the chance of Onkyo offering a Pro upgrade in their 3008 is nil. The 4311 is reliable and bug-free and will probably cost you around $1.5K street. The Pro kit is $750 & $150 for a license. See the Pro kit thread for more.
post #42353 of 62741
Hi All,
Hi Chris,
I'd agree with what SoundofMind says in the post above this one, but I'd also say that with XT32 you don't need the AS-EQ1. XT32 does the same as the AS-EQ1. I use the EQ1 with my Onkyo 5007 because the 5007 only has XT and therefore lacks the greater filter resolution of the x008 series. Used like that it makes for superb bass - but you will get the same thing from XT32. So if you haven't already bought the EQ1, you can save some money - and if you already own it, you could sell it for a good price and spend the $$$ someplace else.
Kind Regards,
Keith
post #42354 of 62741
Jeff
Jeff,
Yes both subs gave the "chirp" sound and I got no errors of any kind and when I ran my tests with all speakers set to small the Audyssey light was on, but no box around it. I believe that the missing box means that I have changed the default Audyssey settings by selecting "small".
I will reset the AVP tonight, see if there are any upgrades and re-run the whole process again following the Setup Guide.
What I do not understand now is why just the center Genelec 1038 shows a crossover frequency of 120Hz and I get nothing for any of the other 1038's or the Genelec 8040's.
Also I am still trying to determine if I should be seeing EQ curves for the subs as there are none, but I see them for all the other speakers.(Denon was not much use here). Are these curves representing the applied Audyssey EQ or the frequency response of the speaker?
So far I am not very impressed by this EQ process, but its probably operator error!
post #42355 of 62741
Jeff,
Yes, and if it had not detected a sub and you changed mains to small, the Audyssey light would have turned off completely.
I wouldn't be concerned about that as room acoustics, the relationship of speakers to the room walls and to things in the room all go into what crossover is recommended by Audyssey.
If you are talking about graphs on the Denon, then they represent .. crudely ... what EQ is being applied. Can't help with why no sub graphs; hopefully a Denon owner can chime in.
post #42356 of 62741
Jeff,
Denon AVR's do not show EQ curves for subwoofers.
If you are getting calibration chirps from the subs, then Audyssey knows they exist. Changing satellite speakers from large to small should not turn off the Audyssey box. I don't think we have determined the root cause of your issue yet.
post #42357 of 62741
AJ, I think any changes from the Audyssey "recommended" settings will result in the box turning off. Trim level adjustments might be an exception to that.
Jeff
post #42358 of 62741
Jeff
That is correct for the most part. However, changing from large to small is also an exception, at least on my 4311. Trim level adjustments remove the box. Adjusting crossovers leaves the box unaffected.
post #42359 of 62741
Manufacturer specific perhaps.
Jeff
post #42360 of 62741
1)Where should i set the gain knob on the subwoofer during audyssey2eq? at 12 o clock?
2)if i sit only at one listening position, should i just keep it in the one position all three times?
