Originally Posted by krabapple
I have 5 identical bookshelf monitors all around (Behringer 1020p) . My new Denon 4311CI is the first AVR I've owned that 1) allows different XO for different channels and 2) has Audyssey (XT32). Heretofore I always set XO at 80Hz. The Denon sets some of my speakers to 60 Hz (C/LS/RS), and some to 80 Hz (L/R). Not sure why it did that, but it sounds fine to me so far...
There could be loads of reasons why your XOs get set to 60Hz - the most likely is that the position of the speakers in the room is influencing the -3dB point which Audyssey uses to 'advise' the amp which then decides where to set the XO. If the speakers are near a boundary for example, then this will reinforce the lower frequencies to some extent. Raising the XOs to 80Hz is almost always a good idea for the reasons mentioned in my earlier post in reply to ZXSpeccy. IOW, I'd suggest you raise the speakers set to 60Hz to 80Hz
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
