Originally Posted by David Aiken
There should be a button on the receiver, and also on the remote, called something like "Room EQ" which is the way it's labelled for my 2807. Pressing that button cycles through a set of options that goes Audyssey, Flat, Front, and Off for the 2807. Make sure it's on Audyssey or Flatthe difference is that the Audyssey curve introduces a slight roll off in the top end that is designed to work with DVD mastering standards.
If you already had the Audyssey EQ turned on before changing the speaker settings, it should still be turned on.
You can also check/adjust this setting through the on screen setup options in "Room EQ Setup" in the "Auto Setup/Room EQ" section of the menus.
Thanks David, once again for your valuable feedback!
I have no experience with Audyssey EQ or Room EQ setups as I have never used it on my receiver. So I will double check if this setting is turned on or not. If not, I will enable it to be set at Audyssey or Flat mode.
However, I always thought that it is better to leave the original source intact without any post-processing adjustments - is this not the case for home theater movie experience as well ? Why would I want to adjust sound as it probably alerts the intended "sound experience" . Sorry to be "difficult" and asking all these questions - one after another, but I just want to be absolutely that I understand these issues. I hope you forgive me
Is there a read up available somewhere that explains in lame terms what the Audyssey EQ or Room EQ setups/settings are all about. My Denon AVR manual does not have a lot of useful info.
Perhaps , Chris (Audyssey) has some useful links or info that is specifically available for my Dennon AVR-988 receiver model that would explain and provide recommendations for my particular receiver and 7.1 apeaker setup.
Thanks in advance for your help everyone,
Nikonowski
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
I am so exausted with all this knowledge
) make a compromise..
I guess not..
