AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #1)
"Official" Audyssey thread (FAQ in post #1) - Page 1648
post #49411 of 62261
Originally Posted by J_Palmer_Cass View Post
I have a general question on that. How does one define dynamic range? The way that I use the term is the difference between the average signal level and peak level is the "dynamic range" of the recording. I know that there is more range available in the recording medium, but it is not noticed when the average level is say 12 dB down from the peak level.
Dynamic range is the ratio of the softest part of the sound/signal to the loudest part.
post #49412 of 62261
Originally Posted by djbluemax1 View Post
What matters appears to be that playback on a calibrated system results in much louder volumes at the same MV setting, requiring much less compensation by DEQ
Bingo.
post #49413 of 62261
What is the softest part of music/movies - silence (0 dB FS)?
post #49414 of 62261
Originally Posted by SoundofMind View Post
That's a long discussion you linked to. What are you referring to exactly?
I stopped skimming when I got to this relevant xchange:
Q: "I'm confused on one point. I quote:
0 dB (Film Ref): This is the default setting...
15 dB: ... material that is mixed at very high listening levels ...
10 dB: ... content ... that is usually mixed at 10 dB below film reference.
So 10 dB is for content mixed at 10dB *below* film reference, while 15dB is for content that it is mixed at a "very high listening level", presumably *above* film reference. If I'm reading this right, perhaps they should be labeled "-10dB" and "+15dB". Is it possible something got reversed when that guide was typed up? ...
November 13, 2010 06:09 am.
A: Hi CF,
No, it's not a typo. It's more complicated than just reference level... It also has to do with how much dynamic range compression is used in creating the content. So, I would just treat the numbers as just labels. The 15 dB offset is for highly compressed (in dynamic range) content that is mixed at high overall levels (e.g. hip hop music)."
I thought the discussion was about how DEQ gets the surround levels wrong because the varying loudness compensation was not applied to the surrounds when they had the mixers tweak the levels when MV was reduced? I didn't read on Ask Audyssey where anyone ... ask audyssey if that was the case, and if so, wouldn't that have changed what the mixers did with the surround levels.
This RLO chatter is a bunch of hooey. The darn thing - DEQ - is designed for movies. Music is so all over the place that, if one cares about accuracy, it is impossible to adjust DEQ correctly, and album to album is different. For music, turn it off and play it loud!
Jeff
post #49415 of 62261
Originally Posted by markus767 View Post
In my mind that's LOWER listening levels not higher.
How is 90+ db average listening level LOWER than 85?
The calibrated SPL of a monitoring system is completely unrelated from what is coming out of the speakers if you aren't concerned with an industry standard...
If the goal is to mix louder (without hearing damage) you must lower the monitor level to achieve more SPL if you are to also intent on using as much of the available headroom available on you recording medium.
You are assuming that if the engineers calibrate the monitors, that they stay at the calibrated "0", which they do not in my experience...
Once again, without a standard, "reference" is meaningless...
post #49416 of 62261
It's not. I thought you were talking about two different calibrations, one at 65-75dB SPL(C) and one at 85 dB SPL(C), both using the same -20dB FS calibration signal?
post #49417 of 62261
Traditionally, dynamic range is the difference in db between the loudest and softest signal (not the average and loudest) that can be reproduced by any part of the signal chain, and not used to describe content..
In my experience, we use the term "compressed" to describe content that has such little dynamics in the average vs. peak, and not "reduced dynamic range."
"Compressed" seems to be shorthand for compressed dynamic range. I understand Dolby DRC, so I understand your use of terms!
post #49418 of 62261
Jeff
Maybe even play it soft, medium, or loud.
post #49419 of 62261
Why irrelevant? This is what equal-loudness contours are about. A voice will sound slightly different when monitored at different levels. The mixer will use EQ to compensate and make it sound "right" at the specific listening level. It can't be "right" at all monitoring levels. That's why Dynamic EQ is needed in the first place.
Markus.. your argument only has relevance if you are constantly changing the monitoring level over the course of mixing a piece of content, which of course no one does when mixing on a given system (that's not to say they don't check the mixes at various monitor settings, but as a rule most music mixers set it and forget it... when they want to check for "changes" it usually requires going from mains to mid or near fields, or out to the car or iPod for a check..)
If you lower that monitors, you push up the gain into the mix buss to achieve the same SPL..
You are starting to run around in circles the concepts of a calibrated SPL monitoring level vs. how hot the recorded signal is vs. the SPL's coming out of the speakers... three different things, related yes, but none of the three wholly determinant of the others (i.e. if you calibrate to a certain SPL, and want to listen at a certain level, you can either turn up the monitor pot or push into the recorder or a complimentary combination of both.... however, if the result is 90db average SPL out of the monitors, equal loudness contours isn't relevant.)
As you stated, Dynamic EQ works optimally, and only as designed, when you know the reference level the material was mixed at..
Yes, film content is more dynamic.
My point is quite simple.
http://www.audyssey.com/audio-technology/faq "15 dB: Select this setting for pop/rock music or other program material that is mixed at very high listening levels and has a compressed dynamic range.".
Maybe my English isn't good enough but "very high listening levels" means "high monitoring level while mixing/mastering" to me. If this would be true then Dynamic EQ's Reference Level Offset would be backwards but it's not. It works as intended because monitoring levels were LOWER than the monitoring level for movies.
It works as intended because the monitoring levels were higher... you are confusing the monitor calibrated level with SPL again..
post #49420 of 62261
I was... and as I just stated in another post, the calibrated SPL has no bearing on how loud the mixer listens at... that is determined by how loud they turn up the monitoring pot, and, if it's not painfully obvious by now, is how most music mixers work in order to print hot and listen loud.
post #49421 of 62261
Sure, whatever. But as there is no standard, it's all a guess .. and a constantly changing one at that. Better to turn it off or use it however you like, but to blather on for page after page after page is silly.
post #49422 of 62261
FWIW, I think that they have come off that recommendation. I got that from John Dahl about a year ago.
Thanx, they also mention it on the THX site:
If you use Dolby® TrueHD or DTS-HD Master Audio™, your back surround speakers should be separated to produce a 60° angle from the main listening position. In addition, you should go to the “THX Set Up” Menu in your THX Certified AV Receiver/Pre-amp and set the ASA Surround Back Speaker setting to “Apart (greater than 48).”
This makes as little sense as their previous recommendation of placing the rear speakers together (only to use processing to make them sound like they're apart). If the above is to be believed, the reason to spread the rear speakers apart is if you switch from lossy (DD, DTS) or hi-rez lossy (DD+, DTS-HD HRA) to lossless (TrueHD, DTS-HD MA). Why would a small difference in fidelity between DD+ and TrueHD (assuming the difference is even audible) need a change in rear speaker configuration?
post #49423 of 62261
I think ASA was born out of 5.1 post-processing and still had a place for the 6.1 matrix/discrete formats. It was also addressing the issue of having one speaker configuration for all content. With 7.1 and, ESPECIALLY, hi-res MCH music, the efficacy has greatly diminished. But I'd guess that there is "inertia" and they cannot overhaul their stance overnight. Hence the walkback that has stopped at an awkward place.
Some time ago I moved to having two completely different speaker configurations - the 7.1 THX and an ITU one - that I physically swap in and out. And then swap Audyssey Pro filters as well. Actually, it was Pro that made this feasible. A kludge, but a feasible one.
Anywho, that's my $.02.
Jeff
post #49424 of 62261
If our hearing would solely respond to the physical sound field at our ears, yes, but it doesn't. That's why I gave the HRTF example.
The author in your sig points to research from Robinson & Whittle in 1960 and Sivonen & Ellermeier in 2006 which demonstrates that "sounds arriving from the side-front, about 60° will appear to be louder than those from the front and louder than those arriving from the symmetrical directions in the rear hemisphere". Same sound, different perceived loudness (depending on direction).
post #49425 of 62261
I didn't question any of this.
Let's get back to your example. Here's a drawing of our two systems. A dubbing stage calibrated to movie reference (A), the other is a music studio (B) with reference level at 70dB SPL (probably by accident). I presume these are the two scenarios you were talking about.
The black area in B is our content. Now we play that content on our calibrated movie system and the content will play at much higher levels than on our music system. This will lead to slightly bloated bass because the content was mixed for a lower playback level. With Dynamic EQ engaged we will get even more bass (when the master volume dial is turned down) therefore we have to reduce Dynamic EQ's processing (i.e. bass boost) which is achieved by setting an appropriate Reference Level Offset.
Anything you won't agree to?
post #49426 of 62261
True, since THX never matrixed stereo rears (only dual-mono rears using Surround EX). But even dual-mono rears would still have benefited from spreading the rears physically apart (less hotspotting in the middle of the back wall, better rear envelopment, fewer imaging reversal artifacts).
Would've been a little more understandable if they had recommended different configurations for 5.1EX/6.1 versus discrete 7.1, but the lossy vs lossless reason makes less sense. But, hey, I'm not their marketing person.
post #49427 of 62261
Toole doesn't provide much detail from those two papers. I'll get them.
post #49428 of 62261
Originally Posted by mogorf View Post
Actually I have given up on RLO coz I found it kinda tedious to adjust it CD by CD. Then, I came up with a tentative solution I already described here last November.
Here's the link to that post: http://www.avsforum.com/avs-vb/showp...ostcount=45951
I'm not sure this is the scientific solution but empirically it works. At least the song-by-song tweaking doesn't have to be done all the time.
Tell me where the bottleneck of this solution is!
It is exactly the ideal solution that I described, having metadata to reflect each song's loudness.
Your solution:
Therefore, after ripping a bunch of CD music and loading them to my HDMI capable laptop I can use a feature called "Replay Gain Edit" to rectify and save level differences that occur song by song or album by album. The best thing after sliced bread is when I can setup a play list with mixed music and in the end the levels become matched song after song.
post #49429 of 62261
True, since THX never matrixed stereo rears (only dual-mono rears using Surround EX). But even dual-mono rears would still have benefited from spreading the rears physically apart (less hotspotting in the middle of the back wall, better rear envelopment, fewer imaging reversal artifacts). Would've been a little more understandable if they had recommended different configurations for 5.1EX/6.1 versus discrete 7.1, but the lossy vs lossless reason makes less sense. But, hey, I'm not their marketing person.
I have a redo of my theater rear planned and part of that is to dis-collocate the rear surrounds and wire them for tripole (M&K) pattern from the monopole they are now.
Jeff
post #49430 of 62261
You won't listen to the music without lowering the playback level, either by reducing the monitor level if your playback system or lowering the level of the source... It will be unbearably loud if you do not. .
Either way you compensate , without knowing what the reference level was during mixing, accurate reproduction of the frequency response is impossible, but because we will tend to listen to music within an acceptable range around where it was intended, I don't think the issue is a great one of concern.
post #49431 of 62261
Isn't this what Intellivolume is for in Onkyos? I have never had cause to use it so I am not sure, but AIUI you can compensate for different levels on different sources, so if one routinely plays CDs at -18 in your example, then one would set Intellivolume to reduce the incoming signal from the CD source and thus one can leave the MV where it is. This, of course, is not much use if one uses the same player for CDs as one does for movie BDs/DVDs
Yes, I mentioned that this method is also a good solution, but not as surgically precise as Mogorf's metadata as his works track by track, and Intelli works on the overall source.
post #49432 of 62261
Are you saying my little picture is right or wrong?
post #49433 of 62261
I've just read the last 4 or 5 pages. My Conclusion: DEQ is garbage. I'd rather let my brain do the compensating than let DEQ compensate it incorrectly.
post #49434 of 62261
It's wrong because you are still ignoring the fact that music people don't leave the monitor at a calibrated level.... They will push the mix buss into the recorder, and turn the monitors up from where they calibrated at to get the desired spl.
This maintains a more balanced signal to spl ratio than your drawing reflects.
Calibration has nothing to do with where they mix at.
Does this topic need any more debate
Music, as a general rule, is mixed at a louder and higher level than film content.
What more is there to discuss?
post #49435 of 62261
I just tried to picture your own example...
Basically a music mixer is shifting the reference level up and down by adjusting the monitor gain. So how would a better diagram for B look like?
post #49436 of 62261
Then you got the wrong impression. Dynamic EQ is not garbage. It does what needs to be done. It's not perfect but better than no loudness compensation.
post #49437 of 62261
Once again, you are confusing the calibrated SPL of the monitor level to what is coming out of the speakers....
if you are printing at close to full scale, and the monitors are calibrated down even 20db, you are mixing at a much higher average level than films... the only thing turning down the monitors calibrated reference does is reduce dynamic range and the max SPL.
It is completely irrelevant to how loud the mixers are listening.... not sure why you think this is debatable....
Correct
As a general rule, music mixers listen/monitor at a higher average SPL than film mixers....
Probably. But it does not matter.
that is why the RLO is a negative number.
Sorry to disagree with the right honorable gentleman, but this is not related. Monitor level has no bearing on the average level of the mix. Pop music is EQ'd and further peak compressed after the recording session is finished. That's what defines the final properties in the release medium.
post #49438 of 62261
My new Onkyo 709 is yielding some very weird results with the mic calibrations (seems like some other people, not all, having similar issues since the last firmware update).
It yields a VERY tinny hollow sound after the 8-point XT measurement (almost like it's rolling off everything BUT the very high end). It defaults to "Movie" Audyssey curve, but i noticed that switching it to "Music" made everything sound fantastic (and much better than pre-calibration).
So regardless of the weird issue with the "movie" measurement, is there necessarily anything wrong with just leaving it in "Music" as far as Audyssey is concerned?
thanks
post #49439 of 62261
But the level on a recording is irrelevant for equal-loudness compensation. All that matters is the actual monitoring level during mixing/mastering.
All that matters is the SPL in the consumer's home.
Then why is it that virtually ALL music recordings have bloated bass with Dynamic EQ engaged? And why does Reference Level Offset correct only in one direction and not both?
All of this has been discussed during the last few days, there's really no need to repeat all of it.
Because DEQ does not understand the difference between reducing the MV to compensate for loud recordings vs a choice to play them back at reduced volume. That's why it needs RLO, or alternatively, some means to normalize program loudness (metadata, Intellisound) before the MV sees it.
post #49440 of 62261
Originally Posted by Roger Dressler View Post
All that matters is the SPL in the consumer’s home.
...in combination with the monitoring level in mastering, i.e. reference level. Despite there is no reference level formally defined, each recording has a point of reference where it was mixed at and where it sounds "right".
Because DEQ does not understand the difference between reducing the MV to compensate for loud recordings vs a choice to play them back at reduced volume. That’s why it needs RLO, or alternatively, some means to normalize program loudness (metadata, Intellisound) before the MV sees it.
I agree. Isn't that exactly what my little picture at http://www.avsforum.com/avs-vb/showt...9#post21552019 shows?
