AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #1)
"Official" Audyssey thread (FAQ in post #1) - Page 1657
post #49681 of 62224
Originally Posted by markus767 View Post
That's exactly what I did describe.
If you agree RLO is needed based on my explanation, why did say “your description doesn't give any reason why Reference Level Offset is needed in the first place”? I thought that was made abundantly clear.
Not if music was mixed and mastered in a dubbing stage without the engineer changing the listening level.
I already said "exactly right" to your hypothetical example.
Yes, but this is irrelevant. Relevant is the reference point of the mastering system and the listening level of the mastering engineer.
Except it’s not. Mastering engineers are a funny bunch. They use their own methods to get the desired results. Not many people get to see or hear how that's done (I feel privileged to have such friends who let me peek behind the curtain). The results are judged by various criteria that have no bearing on their chosen monitor loudness.
Correct but the point is that Dynamic EQ applies the correct compensation EQ in both cases. One either sets Reference Level Offset or reduces source input trim. Both methods can be used to restore spectral balance.
Either of those conditions will work, which is exactly as I explained in my two cases. What will not work is simply turning the master volume down.
post #49682 of 62224
Originally Posted by Roger Dressler View Post
Except it's not. Mastering engineers are a funny bunch.
May I ask, Roger: is there an ideal listening level for a given piece of music that has been mastered by one of the funny bunch (and possibly re-processed by a mate)?
post #49683 of 62224
OMG: 1600 pages!?!
Forgive me for not looking through them all. I am considering purchasing either of two AVR's, each of which use Audyssey.
I plan on having 2 different "sound fields". I will have an LCD TV with a center speaker beneath it (Polk Cs245i). I will ALSO have an electric retractable projector screen which will drop down in FRONT of the center speaker.
I would think that having a movie screen in front of the center speaker will affect the sound.
Can I calibrate my system for TWO settings? One setting, the most used, will be without the projector screen. The other, used less frequently, but very important to me, will be WITH the screen in front of the center speaker.
Ken
post #49684 of 62224
This is my last try in explaining myself why Reference Level Offset is needed and why I think that music is mixed at lower levels, not at higher level as commonly stated.
Here's a diagram on which I will base my reasoning. So it's crucial to understand what the picture shows. The upper limit of the green area is the average level of a sound recording. The red area is the headroom for peaks.
A) This describes the situation in a dubbing stage. There's a defined reference level that links sound pressure level and the upper limit of the recording medium. 0dBFS = 105dB SPL.
B) shows how loud a modern music mix would sound when mixed and mastered in a dubbing stage. The headroom of such a recording might only be 3dB hence the average level is a whopping 102dB SPL. This is very loud and can lead to hearing damage. That's why in practice most music isn't mixed or mastered that way.
Nevertheless, if this mix would be played back on a movie reference calibrated system at home, the recording would still play at 102dB which would make us reduce the listening level. By doing so the music will sound bassshy because of the equal-loudness contours. But thanks to Dynamic EQ we can reduce the listening volume to a comfortable level without creating a spectral imbalance. Dynamic EQ corrects such a spectral imbalance by boosting bass. It boosts bass when we set the master volume dial below 0 and it cuts bass when we set it above 0.
C) Because mixing and mastering music at movie reference level is so unbearably loud, the mastering engineer will actually reduce the listening level. By doing so the music will sound bassshy because of the equal-loudness contours. He will ultimately correct this spectral imbalance by boosting bass.
At home we listen at similar low levels and the mix will sound more or less balanced. The correct listening level will alway be an approximation because the mastering engineer has no way to tell us about his reference level.
What happens when we play that recording on a movie reference level calibrated system with Dynamic EQ engaged?
D) Let's play the recording from C - that was mastered at lower levels - on a movie reference level calibrated system. Again the mix will produce an average sound pressure level of 102dB but this time the mix will sound bass-heavy when compared to example B because the mastering engineer added it in step C.
If we now reduce the listening level with Dynamic EQ engaged, even more bass boost is added. This will lead to bloated bass.
We need to tell Dynamic EQ somehow to reduce bass with the master volume control at 0. We also need to tell Dynamic EQ not to immediately start boosting bass below 0. This is achieved by setting Reference Level Offset.
We tell Dynamic EQ that the reference level is not 85dB any longer but 70dB. This is done by setting Reference Level Offset to 15 (85-70=15). Now with the master volume control at -15dB, Dynamic EQ would perform no processing because this is our new reference level. If we select a volume setting below -15dB, Dynamic EQ will again start to boost bass and it will cut low frequencies if we set the master volume control higher than -15dB. This is exactly the processing we need for our mix to maintain spectral balance.
We could also simply reduce source input level by 15dB. This would have the same effect as setting Reference Level Offset.
post #49685 of 62224
For reference here are the actual EQ curves Dynamic EQ applies to a pink noise test signal:
Take them with a grain of salt, especially at the lower end.
Kind of interesting results.
There are many curves there based on the MV setting. It is pretty clear from those curves that when some people "goose" their subwoofer calibration a bit (minor of major boost), they are only boosting part of frequency band that needs to be boosted. DEQ boosts well beyond the subwoofer range.
Now if you do not have DEQ, then perhaps the bass EQ in your reciever should be used to raise the bass levels along with a flat subwoofer calibration. My typical listening level is near 10 dB below reference, and that is the level that I use to fine tune my system.
My CD player has an adjustable output level, and that is what I use to level match a CD music level with a nominal DVD/BR movie level.
Also, do people really listen to their systems at master volume levels much lower than 20 dB below reference level? The reason that I ask is my old pioneer receiver had a mute button on it, and -20 dB was considered to be mute in the old days.
post #49686 of 62224
Originally Posted by saj2001ind View Post
hi Since you have quite a long term experience with equilisers, I wanted to ask you if you feel any difference between MultiEx, MultiEx XT and MultiEX XT32 ?
would you recommend anyone here to updrage their AVR just to get MultiEq XT if he already have a multiEQ ?
-------------------------------------------------------------------------------------------------From my experience with equalizers/equalization over the years, i would definitely get any version of Audyssey MultEQ, preferably MultEQ XT32 due to its much more accurate in-room calibration results but if you cannot afford it as currently being offered only in high-end A/V equipment, then go with MultEQ XT, which can be found in receivers costing $500.
I own very/very large and wide electrostatic panels as F/L speakers and the difference Audyssey MultEQ XT made is amazing; I imagine that by going with MultEQ XT32 in my new Integra DHC-80.2 processor it should, if anything, improve on an already outstanding result.
As for upgrading from MultEQ (dozens of tap points) to MultEQ XT (hundreds of tap points) it's just a matter of achieving a finer gradation of equalization, and in this case, the "finer" the better...
BTW, thanks batpig and marcus767 for the answers and links...
post #49687 of 62224
You are wrong.
In the only two ways that matter (level on the recorder and SPL during mixing/mastering,) music is mixed at a higher level than film content.
That is why attenuation is needed.
Your pretty chart and it's following description completely ignore the fact that since there is no standard reference for how people mix music, you cannot throw the rules for mixing film at a STANDARDIZED playback reference into the mix, so to speak, as a comparative reference for your argument.
post #49688 of 62224
FM, do mixers ever have hearing tests? Perhaps your hearing and the hearing of all other film mixers should be graphed and encoded into the movie as a "calibration file" that would serve as a "EQnorm" that would offset the reference EQ.
Jeff
post #49689 of 62224
Originally Posted by FilmMixer View Post
You are wrong.
Marc, it isn't helpful repeating "you are wrong" without giving any additional explanation or without going into detail where my explanation might be wrong.
By the way, Roger agrees that reducing source input level has the same effect. Why don't you simply test it yourself? Reduce the output of your CD player or use IntelliVolume.
So someone has to be wrong. I don't have a problem with being that person but you don't present any arguments so I have to stand by my claim.
P.S. I never said that SPL in a dubbing stage is higher than in a music studio. In fact I stated the opposite some posts back. I also never said that recorded level of a movie is higher than on a music recording. It's also irrelevant for the discussion why Reference Level Offset is needed. The important argument is that nobody would mix and master music (with peak normalization) on a system that is movie reference level calibrated. It would simply be unbearable loud. Please read my post again. I don't know how to make it any clearer.
post #49690 of 62224
Jeff
That's actually what is already happening. Everybody can only listen through his own ears. The decision if a sound needs EQ tweaking is based on that. So if Marc's hearing tells him that a sound is lacking bass, he will EQ it. You might have had decided differently.
post #49691 of 62224
What is your suggestion for music, turn off DEQ and manually adjust volume as well as bass/treble individually for each music track to your own personal preference?
post #49692 of 62224
While we're on/near this topic, I have a quick question I've always wondered:
What about musical concerts that are released on DVD/Blu-ray? Are they mixed/altered during DVD/Blu-ray production to film standards? Or can they be all over the map and held to no standard?
post #49693 of 62224
and the reports of Audyssey being screwy with Onkyo keep on comin':
"I thought it was just my setup. It sounds like a tin can! It sounds as if the mids have been reduced & the upper frequencies have been raised."
This is the same exact phenomenon.. for the people experiencing the problem, there is little variation with the actual sound oddity.
post #49694 of 62224
Marcus.
Are you kidding me? I've given plenty of examples.
These aren't disputable facts.
If you have to turn the volume down when listening to music, that is proof the recordings are "louder.".
If you haven't been to a mix session for music, and heard the SPL's levels, I can't prove that to you. You just need to take my word on that.
Your statement that music is mixed at a lower level is false.
I don't need to back it up repeatedly, and neither does THX or Audyssey.
post #49695 of 62224
I would think that, other than something created as a movie, e.g. Scorsese's The Last Waltz, concerts on DVD/BD would be under the "no standard" category.
Jeff
post #49696 of 62224
Well maybe it is and maybe it isn't. Without context or follow-up questioning, this could be anything.
Jeff
post #49697 of 62224
Jeff
And while it is most probably a "no standard" category I also wonder how an SPL of a concert that easily goes up and above 130 dB in the stadium can be translated to a disk, with or without a standard? Maybe FilmMixer has the right answer.
post #49698 of 62224
Marcus.
I don't have the feeling that you really read my posts thoroughly. You put words in my mouth and you also do not really respond to my arguments. This is simply a waste of time for both of us and anybody else that might be interested to get a deeper understanding of the topic.
post #49699 of 62224
Oleus:
just ryi Yesterday when I had a freezeup on the movie curve and coulld not change it. I turned off all my equiiptment and unplugged the Onkyo for about 10 to 20 seconds and restarted everything and the Onkyo currently from then on has worked flawlessley. Mabey a fluke or the start of things to come but All now works amazing and back to normal. I guess for me it is a wait and see. I guess that is not the case with yours?
post #49700 of 62224
post #49701 of 62224
Jeff
True - but reports are coming in from all over. Even Norway is reporting issues and there is a lot of similarity in the descriptions. The biggest reason for believing it might be Onkyo FW breaking Audyssey somehow, though, is their previous form... I'd like to know for sure because when my Pro kit arrives, I will of course have to update the 5509 FW. BCJ made a good point that the FW will have been thoroughly tested by Audyssey on this occasion, so that gives me some peace of mind. Audyssey have already thrown one attempt by Onkyo back...
post #49702 of 62224
Jeff
i meant in terms of the sounds being produced. so far with the people reporting the problem with audyssey/onkyo, the same tinny hollow sound is the common thread (while other factors, like whether it sounds like that on MUSIC curve or only with THX selected, aren't as consistent).
william i will try unplugging the receiver tonight and leaving it unplugged for a while and see what happens.
post #49703 of 62224
Originally Posted by kbarnes701 View Post
True - but reports are coming in from all over. Even Norway is reporting issues and there is a lot of similarity in the descriptions. The biggest reason for believing it might be Onkyo FW breaking Audyssey somehow, though, is their previous form... I’d like to know for sure because when my Pro kit arrives, I will of course have to update the 5509 FW. BCJ made a good point that the FW will have been thoroughly tested by Audyssey on this occasion, so that gives me some peace of mind. Audyssey have already thrown one attempt by Onkyo back...
Not to undermine your confidence, but Onk has already hosed Audyssey-approved code by not checking the little box for "use the Pro mic calibration file for Pro calibrations" before compiling their firmware. That was the cause of the problem not long ago with the 5508/80.2.
post #49704 of 62224
Could be. Not saying it isn't. But we're heard "dialog sounds tinny" already and it was location/position of the center channel speaker. Keith makes a good point, though, about reports coming from all over. Maybe it *is* a duck.
Glad my unit has gone through its growing pains ...
post #49705 of 62224
Among other things I think we're using "levels" in inconsistent ways.
Aren't you both saying the music is recorded with higher recording levels (compressed closer to max volume on the recording medium than are film recordings), but that the monitors are not outputting 105db into the room when the recording level hits 0db on the meter, because that would be crazy?
I'm never been able to sit on on a movie mix, but I have sat in on pop recording mix sessions, and there was no way we were listening at 105db as measured in the listening room -- but the recording itself hit -3 consistently on the computer readout.
Some might call that "higher levels on tape" and "lower levels on the monitoring speakers" when mastering music. All I know is that it sounded as loud as a movie soundtrack on that system...but that one had to lower the volume knob when listening to music playback (vis-a-vis movie playback) in order for things to sound similarly loud in the room... By about 15db on the volume knob.
post #49706 of 62224
Markus. I corrected you on one specific point.
That last sentence is what I disagree with.
I don't think because you keep accusing me of not understanding all of your post has anything to do with the falsehood of your statement.
Nor does your continued insistence of trying to lure me into a debate make the statement true.
I didn't refute your other pints, and was solely commenting in what I said.
I owe you nothing, but of you are going to post things that aren't factual I am going to pint that out.
Just because you "think music is mixed at a lower level" doesn't mean you're right
And in the end I understand it's semantics, you clearly are saying the conventional wisdom in incorrect.
And it is not.
post #49707 of 62224
oddly enough, I reported a similar problem back in May 2011 with my TX-NR708 here http://www.avsforum.com/avs-vb/showt...8#post20391938
I never got a response from others so assumed I just either had a bad unit or I was hearing things
This issue was intermittent but reliably kept coming back. It would "fix" itself with a hard reset and re-run of audyssey but wouldn't stay good for long.
Ultimately, this led to the demise of that unit and a new TX-NR809.
post #49708 of 62224
Shucks, Jeff... you know how to damp down a guy's dreams
post #49709 of 62224
And it is not.
I don't want to lure you into anything. You can choose for yourself if you want to participate in the discussion or not. It is you that keeps on responding to my posts. All I wish for is a factual discussion.
So to recap, you agree to anything I've said here but you disagree that music is mixed at lower levels than film, correct?
Do you also agree that music isn't mixed, mastered and monitored on film calibrated systems because this would be unbearable loud? If yes, you probably also agree that even if a film calibrated system was used to begin with, the mastering engineer would turn down the monitoring level?
post #49710 of 62224
From a technical point of view one tries to max out the recording level on the medium to optimize the S/N ratio, dynamics and resolution. This has nothing to do with the monitoring levels in the studio during the final mix, which you try to keep comfortable for your and everybodies ears and pleasure.
