Originally Posted by jdsmoothie
The question was worded as you originally asked ... and the answer was that 2 stickied Audyssey threads won't be permitted. As already mentioned, a 2nd Audyssey thread would be too confusing and result in double posting ... not the desired end result. Keith will be developing the FAQ inside of this thread and then at some point may place it in a dedicated "locked" thread, as once locked, cannot be accessed without a mod's intervention.
Once again, I NEVER suggested 2 stickied Audyssey related threads. From Day 1, my recommendation was always to create a new stickied thread specifically for the FAQ and setup questions and unsticky THIS current thread.
Title them appropriately so they're easily distinguishable between one for questions regarding Audyssey setup and use vs. this current thread where the topics are much more in-depth and diverse. Direct any setup questions in this thread to the FAQ thread, and direct any acoustic theory questions in that thread to this one (in just the same fashion that general Audyssey questions are answered but Denon specific feature questions are referred to the Denon threads for that particular model).
I guess these concepts must be a lot harder to understand than I'd initially assumed. I don't see this current solution working out very well for very long.
Max
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
I mean that there is not a free line of sight from the front speakers to the wide speakers and since it is supposed to handle room reflections I guess if the reflection from the front bounce in the oven there will be a timing issue (i refer to wide speaker on the left side in picture A between oven and door). If i raise it the tweeters for fronts and wides will be at different heights (about 30-40cm) which is not acc to DSX spec, so wonder what is worst
