Originally Posted by hclarkx
Keith, is this accurate (the underlined part)? I thought XT32 pretty much duplicates the Sub EQ which I think has a separate set of filters for each sub. I.e., not only are the distance/delays for the two subs properly taken into account, but each is EQ'd so that 1) it is moderately flat across the listening bubble and 2) deviations from that are made so that the two subs together are as flat as can be across the bubble. I.e., the two subs are EQ'd to be largely complementary across the listening bubble.
Harrison
Harrison
Thanks Gooddoc for the confirmation. (And SoM too I see - I've been away and only skimmed the intervening posts).
Originally Posted by Gooddoc
IMO, I believe the latter is at least somewhat overblown. That is not to discount distance/delay as unimportant, but I don't think it's nearly as important to SQ as the increased filter resolution provided by XT32. It's why I think that when using dual subs with XT, if its not possible to get the subs equidistant the benefit of smoothing the FR with the 2nd sub is likely to far outweigh any potential negative impact caused unequal distance.
I would think you are probably correct too. I'd say they should "ideally' be equidistant but I go along with your thesis that the second sub benefits are so considerable that they outweigh the lesser benefits of equidistance. This will be especially so if measurement shows that the best performance is achieved by sub placement that also happens to NOT enable equidistance.
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
I think it absolutely demands measuring equipment, and some knowledge of how to use it and how to interpret the results, if one is going to change the Audyssey-set distances. Not that that doesn't make it potentially worthwhile but for most Audyssey users and those without measuring gear, I still say that equidistant is ideally the best way to go. I don't think we are fundamentally in disagreement about this.
With XT32, it would be rare for someone to want/need to tweak distances individually. Basically XT32 gets it right. In addition, any distance tweaks should be done with a measurement system, not by ear. And that brings me to my point below...
