Originally Posted by ggsantafe
Denon's are not THX certified, so there is no mention in the Denon Owner manual of THX settings. Likewise there is also no mention of the Re-EQ offset for Denon owners. Just pointing out what Austin Jerry was referring to in his post about Onkyo specific terminology, not trying to debate the concept of THX reference
OK thanks - for clarification, Denon AVRs don't have DSP modes then such as THX Cinema? EDIT: I just checked - a couple do but I am surprised to discover that most don't, including my 'favourite', the 4311. I spotted something called 'Cinema EQ' in the specs which I take to be Denon's own version of RE-Eq or something like it.
Do Denons have user-selectable Audyssey Reference or Flat curves, like the latest Onkyo's Audyssey Movie/Music curves? If they have a user-selectable Reference curve then that already has the HF rollof, so without any THX modes, I can't quite see the purpose of Cinema EQ. On the Onkyos if you select Movie (Reference) then RE-Eq needs to be off of course. If you select Music (Flat) then RE-Eq needs to be enabled if you use a THX mode. Some units don't give you the choice of user-selectable curves so all this happens 'behind the scenes'. No wonder people get confused
Whether they are THX certified or not, of course, they will still use Audyssey with the prime objective of Audyssey which is to set a system up so that at 0dB on the MV it is playing at THX Reference level. I can’t see how that is AVR-specific (assuming the AVR has Audyssey MultEQ). Maybe it's best to delete the reference to THX and call it just 'Reference Level' - that way nobody with a Denon can be confused into thinking it doesn't apply to them.
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
THX Ultra2
THX Select2
THX I/S Plus Systems
THX Certified Multimedia Products
It's just there because... it is.... I suppose there are people who don't use Audyssey who want some method of high-freq roll-off. But anyway, Cinema EQ on Denons really doesn't have anything to do with Audyssey MultEQ.
