AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #1)
"Official" Audyssey thread (FAQ in post #1) - Page 1763
post #52861 of 62235
Originally Posted by kbarnes701 View Post
I think, but am not sure, that I have heard thunderstorms where there has been a lot of bass content. But not the one yesterday. Maybe our British thunderstorms are mixed and mastered differently?
I think you must be right. I am going to speak to whoever is responsible and demand reference level storms in future!
Oddly, my dog isn't the least bothered by thunderstorms, fireworks or any Bruce Willis movie. It was *me* who was cowering as the thunder clapped and the lightning flashed. He was off in a hedgerow after a rabbit he'd seen a few minutes before the heavens opened. Priorities I guess. 10 minutes later, the sun was shining and the sky was entirely blue. Weird weather we're having here.
I'm pretty sure the thunderstorm I mentioned was recorded HOT. There's no way the LFE channel was restricted to 115db peaks! LOL
As far as weird weather goes, we had 70f degree weather in February (when it's usually between the teens to 30's), 80f + degree weather in March, then it snowed this week in April. Maybe the world is coming to an end in 2012? Enjoy those HT's while you can people!
Originally Posted by Al Sherwood View Post
I know that this may appear unrelated to Audyssey, but from my viewpoint it would seem that by using Audyssey and its suggestions for low frequency cutoffs for the various speakers it is directly related to my question:
I have speakers in hand for all 11.1 channels supported by DSX, my question pertains to the height and surround speakers only. On previous tests that I have run with them (S-2) the cutoff was around 100 Hz or above, given this is a function of the speaker, it's placement and the room, the need for a speaker that reach lower seems fruitless but never the less I am tempted to upgrade the surrounds and heights to larger units...
I currently have the Klipsch S-2 and I am considering the S-3's (a similar situation exists for the Height channel B-2 versus B-3), is the a benefit to going to the larger speaker(s) for these channels? As these now as they are out of production and I see some for sale I am tempted...
B-2: FREQUENCY RESPONSE 62Hz - 23kHz +/-3dB
POWER HANDLING 75 w (300 w peak)
SENSITIVITY 92dB @ 2.83 volts/1 meter
B-3: FREQUENCY RESPONSE 55Hz - 23kHz +/-3dB
POWER HANDLING 85 w (340 w peak)
SENSITIVITY 93.5dB @ 2.83 volts/1 meter
S-2: FREQUENCY RESPONSE 83Hz - 23kHz +/-3dB
POWER HANDLING 100 w (400 w peak)
SENSITIVITY 91dB @ 2.83 volts/1 meter
S-3: FREQUENCY RESPONSE 62Hz - 23kHz +/-3dB
POWER HANDLING 110 w (400 w peak)
Al, although the general consensus is that bass below 80Hz is non-directional, I've discerned that as with many things, YMMV.
All my speakers currently play flat in-room to the 30's Hz. I tried a simple test of switching between crossovers of 40Hz (the Audyssey XT32 default in my system) to 80Hz (the common recommendation) after the 'stereo bass' discussion came up.
I listened to both stereo music tracks as well as multi-channel movie clips. I heard the slight improvement in stereo music, but the difference was more easily heard/felt with surround sound. Specifically, one of the clips that I used for testing was the 'Star Wars: The Phantom Menace' pod race scene.
In that scene, I could hear the difference between the crossovers. I realized that I could hear the difference between my normal 40Hz crossover as the pods rumbled/roared by, vs the 80Hz crossover where I could actually hear the difference between, "these frequencies are panning across the speakers, THESE frequencies are not". The effect was a difference between the sensation of an actual real large object/vehicle zooming past vs the reproduced sounds of an object panning past.
It appears that I can localize below the regularly mentioned 80Hz. The papers that were posted also indicate that many folks can hear the differences and suggest that the real point at where folks cannot determine directionality or any envelopment differences is about 45Hz and below.
As I mentioned though, YMMV, but if you upgrade the speakers (and if you can get a great deal on them, why not?), you can try these tests for yourself.
Originally Posted by IceTBC View Post
Definitely not orange either since it's hard to make out against the theme I use here on AVS. IMO bold works out much better if you want to either emphasize or make text stand out from the rest.
Originally Posted by pbarach View Post
I agree. Use either BOLD or ITALIC (rather than changing the text color) and anybody reading these forums will make out the words without difficulty, regardless of what theme they use.
Bold and underline, together, makes text really stand out, especially if you prefer not going through the hassle of separately quoting passages/paragraphs from a person's post to answer several different questions.
Max
post #52862 of 62235
....evidently has MultiEQ XT. Does anyone know why the US version does not? And, does anyone know if it's possible to upgrade via a firmware update from Denon?
post #52863 of 62235
Spot on SB! A Parson Russell Terrier. He is a true terrier - "what's the problem with 120dB thunder and lightning everywhere when there is a rabbit to be caught?"
I thought so, Keith. Although many of us here in "the colonies" still refer to them under the older "Jack Russell" name. Old habits die hard. One of my neighbors has had one for the past decade. My wife calls Sparky "a dog on springs". Nothing deters him when he's after porquepines, field mice, rabbits, ground squirrels, raccoons, foxes, even the occasional coyote! He's fearless and determined to a fault.
On the other hand, our dog Missy (a 14yr.old Australian Shepherd/Border Collie cross) has always been afraid of loud noises. Thunder storms, gunshots, and the Fourth of July fireworks scare the s**t out of her. She won't even stay in the room during close to reference level action scenes in my HT. The train wreck scene in Super 8 really does a job on her.
See, I was able to squeeze in a reference to HT in an attempt to keep this post OT
Cheers,
SB
post #52864 of 62235
Hi, welcome. Here is an accurate guide to the features of the current Denon models. That AVRxx12 thread would probably be a better place to post your question. Edit: but see jdsmoothie's post below
There is no FW upgrade of MultEQ to XT available on any model I know of. The 1712 is the budget audiophile model with no networking but it has XT. The 1912 adds other features but has MultEQ. The 2112, with XT, is really the sweet spot inexpensive-but-loaded value Denon AVR model.
post #52865 of 62235
I don't know about in the States, but here the Parson is somewhat different to the regular Jack. The Parson is a Jack but taller, basically. So they think they are even bigger dogs than the regular Jack - and that is *big*
Yes, that describes mine to a T. The other adjective that springs to mind is 'stubborn' But I like 'determined' more...
There's a lot of HF in that scene (in fact many people complain about the lack of deep bass in it - me included) and maybe that is what freaks her out. Mine is pushing 6 years old - he isn't scared of the SPLs in my HT room but he regards it with disdain - he looks in, looks at me like I am nuts, scratches himself and goes off to look for more interesting passtimes.
Dogs and HF - that's OT isn't it?
post #52866 of 62235
There is no 1712 or 2112 in Europe, XT starts with the 1912 there.
post #52867 of 62235
Originally Posted by Shinyav View Post
Here is some messing around with sub distance.
The label for each is if audyssey is on or not and the sub distance in feet.
Was the shorter or longer distance the Audyssey setup distance? And is that both of the fronts together with the sub? Or what does the other one look like?
post #52868 of 62235
Originally Posted by AustinJerry View Post
Forget the Audyssey off measurements. Continue adjusting the distance up or down in small increments until you get the flattest response, and then conduct a listening test to see if you like it. The red graph is obviously not the better one...
K no more non audyssey measurements. That is the flattest I could get it being in a reasonable range from what audyssey set. I don't know how extreme I can go without effecting timing.
The longer one was Audyssey. And that is both the fronts together.
post #52869 of 62235
I have purchased a real mike stand and aud. mike adaptor, but the overly bright sound is still there ,I am now going to do outside of the box measurements any one have any ideas.
post #52870 of 62235
Worth remembering that these REW (or equivalent) measurements are interesting, but only valid in a general sense since they probably do not make the same multi-measurement and weighting calculations that Audyssey does. In a sense it is a difference of opinion between two "algorithms," not a means to verify the exact performance.
post #52871 of 62235
In case you are interested in seeing an example of improved bass response in the crossover region after tweaking the sub distance, I have attached a graph. The green line is the original sub distance as calculated by Audyssey. The red line is the result after adjusting the sub distance to produce the smoothest response at the x-over (80 Hz). Both graphs are single measurements at the MLP.
Your comparison is quite convincing but something about the post-EQ adjustment of sub distance has been bothering me.
When the sub distance is changed, the phase or "time" of all sub frequencies is shifted relative to that of all higher frequencies. Is that okay? Might Audyssey be taking that into account when coming up with what looks to be an imperfect blend between sub and satellite?
We are taking a very complex sound wave that is broken down into components (sub frequencies and higher frequencies) and outputting it via two different drivers (sub and satellites). If those two sound components are re-mixed in the air between the speakers and our head with a different phase/time relationship, haven't we changed the complex sound wave?
Adjusting the sub phase/time so that the SPL magnitude at the blend or XO point no longer has a dip suggests we are bringing the two into phase at that frequency. However, ported subs usually have a large group delay meaning that the phase/time changes rather significantly at progressively lower frequencies. Matching the phase/time at the XO may mean a greater mis-match at progressively lower frequencies and maybe a greater distortion of that complex sound wave.
Has Chris ever weighed in on this? I wonder if we are missing something and maybe correcting something that is already good from a perceptual standpoint.
Since Audyssey EQ's for a good blend, it just doesn't seem like something that would be gotten wrong. And if a good blend involves more than just the narrow frequency band around the XO, why can't the amplitudes at the XO be adjusted to cover this dip at the XO.
Is this issue common only with ported subs? Is it common only with XT and not XT32 (higher resolution of XT32 takes care of it)? Does the pro kit's more complex blend algorithm take care of it?
Just tossing this out there looking for peace of mind. I don't have the issue but it bothers the engineer in me all the same.
post #52872 of 62235
I agree with the above post. I think it is fine tweaking it maybe a foot or two, but something like a 5ft change usually starts messing with how things "sound" because of the difference in delay time.
post #52873 of 62235
I think Keith's comment about the potential for new satellites to not change the 100 Hz crossover point is a good one.
Notice that Audyssey is finding your satellite outputs dropping at around 100 Hz even though your current satellites have capability considerably below that. This will not change with the more capable satellites. The room characteristics have diminished the output below 100 Hz and will do so for the new satellites regardless of how low their -3db point is. Hence the likelihood that the crossover point will not change.
If the room characteristic that diminishes SPL below 100 Hz in the listening area is only 10 or 20 Hz wide, the higher output of the new satellites at lower frequencies might turn a roll-off into a dip and one that Audyssey can correct. In this case Audyssey might choose a lower XO. However, given that the B3 only gets you 7 HZ more I think it is very unlikely to help. The added 21 Hz improvement from the S3 just might get you a lower XO.
You might try different mic positions, maybe raise the mic a bit or make the MLP a different seat (or move it a bit if it's between seats) to give Audyssey a different basis on which to identify the low-end cut-off of the satellites.
I'm not saying I wouldn't recommend the upgrade, but I think there's a good chance the XO won't change.
post #52874 of 62235
From the distance experiment I did with my room/sub, going from 12.5' to 16' made a world of difference (that along with x-over setting).
post #52875 of 62235
Hi Harrison, while I fully agree with you on the engineering side of the story, I tend to belive that a test microphone surely behaves differently than our ear/brain combo. Clear cut graphs can be taken showing delays (or even early arrivals when sub distance is set less to what Audyssey set it), but I think our hearing system will be able to take care of that or maybe pay not too much attention to delay shifts rather than paying attention to variations in the frequency range (limited around the splice).
Just my 2c.
post #52876 of 62235
Harrison, your questions seem valid to me, and I too had reservations about messing with what Audyssey had set.
To add a little more background information, I have three sealed subs (Hsu ULS-15's), and an AVR with MultEQ XT32. It is always a challenge to run an Audyssey calibration when more than two subs are involved. My approach is to connect two subs to the first sub channel with a Y-cable, and place these subs equidistant from the MLP. The third sub is on sub channel 2, and placed considerably closer to the MLP than the other two subs. After calibrating in this manner, I listen closely to the bass response first with the default Audyssey distances, and then after adjusting the distances for flattest response using REW. Based only on my ears, the bass sounds better with the adjusted distances. I don't know how to measure the effect on phasing. However, if the effect were bad, I suspect I could hear it.
There are a number of us here on the Audyssey thread that have used this approach when calibrating three or more subs. I believe Craig John was the first to suggest this to me. I have not discussed this on Ask Audyssey, so I don't know what the official answer is.
post #52877 of 62235
Just my 2c.
+1. The relative phases of the frequencies also change whenever you move whether your sound source is natural or from speakers. I am pretty convinced re are not wired to react to relative phase per se. I lost the link but somewhere a site shows and lets you hear the phase inaccuracies of a number of headphones. A square wave sounds the same yo me even when the phases are so misaligned that the eave beats no visible resemblance to a squsre wave. I was a bit surprised
post #52878 of 62235
I do not believe this is the case. Source?
post #52879 of 62235
Here's an interesting discussion on Group Delay of Loudspeakers and the audibility thresholds of group delay of the human ear.
post #52880 of 62235
AFAIK, actually Audyssey EQs each speaker and sub(s) inedependent of each other, then reports the results to the avr and the avr sets the crossovers with HP and LP filters. The slope of those filters will be responsible for the flatness of the dip at the splice at and around the c/o point and as wee see it's far from being perfectly flat. So, in other words, Audyssey is least responsible for the splice.
post #52881 of 62235
In my case after audyssey the mains are set full range. Depending if I choose 40 80 or 120hz crossover the correct distance setting based on flattest response is different. And all of those distances are different than the distance set by the receiver setup. And it varies from 6ft to 18ft.
Changing the sub distance this much does sound different, but it doesn't seem to be the freq response rather the timing of the bass with other freq. Could be just placebo since that is what I'm "trying to here" but don't know ho to prove it.
post #52882 of 62235
First why not settle with the proper c/o setting (like 80 Hz), then tweak the distance for a flat(ish) splice, then forget about it and enjoy! How is that?
post #52883 of 62235
Well, because testing a month or so ago showed 80hz is too high as surround pans are much better with 40-60hz crossover. If I run them full range I don't have to worry about the distance as much because there is no integration with the mains and that would be the best setting. But knowing full range is not optimal, I wanted to use 40hz for the front crossover but that gives the best sub integration with a sub distance of 18.5ft vs the 13ft set by the autosetup. But music sounds "off" with that distance setting.
So OCD has won and there is no perfect setting.
post #52884 of 62235
Very good read but I didn't see any answer in there.
post #52885 of 62235
INTEGRA DHC80.3
Ran the room correction 3x, each time during speaker set up LCR RSB all show up, LSB pings but the Audessy doesn't highlight it and I get an error.
Ideas?
BTW 5.2 config.
post #52886 of 62235
No particular source other than Chris' comments over the years. Also, as I recall, a key feature of the pro kit is a more elaborate algorithm for developing the blend; hence my question about whether XT32 does a better job of achieving a smooth gain curve at the XO.
What we don't know is what all goes into the blend calculations. If it's just a matching of the phase of the sub and satellites at the XO (and a corresponding gain adjustment) then it's a simple matter and it's hard to believe that Audyssey is ever getting it wrong.
I'm assuming that all satellites are adjusted for similar phase at the XO and when the dip occurs, it occurs with all satellites. I don't know that we know that either.
But, there seems to be a consensus that adjusting the sub phase (distance) improves the sound and I can't argue with that.
post #52887 of 62235
I've been assuming that Audyssey knows what the XO filter characteristics are and takes those into account when setting the speaker distances and the Audyssey filters. I wonder if either that isn't the case or the receiver manufacturer is not giving Audyssey accurate information to work from. Is this problem common to only certain receivers?
post #52888 of 62235
A very interesting read indeed. I recall reading similar material when I compared characteristics of vented and sealed subs a few years ago and decided to go with sealed subs.
I wonder though, with the advent of Audyssey and improved speakers and HD and SACD sound, might we be more sensitive to group delay than the authors referenced found (I didn't check their publish dates but I assume they pre-date the latest technology)? Maybe it's the OCD but we are fussy bunch with keen ears and some excellent equipment. I'd bet that group delay is a bigger issue today (for us) than it was 5 or 10 years ago. This suggests that if adjusting the sub distance improves sound, it's the right thing to do. If the sub distance is increased to smooth out the blend, then a byproduct is effectively a reduction of the group delay.
Have those that adjusted the sub distance found that increasing it is the solution?
post #52889 of 62235
Originally Posted by Lord Godking View Post
INTEGRA DHC80.3
Ideas?
BTW 5.2 config.
In a 5.2 setup you don't have a Left Surround Back and a Right Surround Back. You have a Left Surround and a Right Surround. Re-connect your surround speakers to the proper connections on the AVR and run Audyssey again.
post #52890 of 62235
1998 is mentioned at the top of the article. So, ancient in tech terms. A lot will have happened in 14 years I'm guessing.
