I'm using a glitch free onkyo 3007 with Audyssey XT. The onkyo 3007 sounds great as is, just that the add-ons like Audyssey need refinement to catch up to the onkyos perfection in SQ.
FWIW, on the MUSIC curve the Audyssey XT calibration sounds amazing on my Onkyo 709 for both music and movie sources. So i'm happy :-)
Doesn't sound like exactly your same issue, but some of us had weird Audyssey results on the MOVIE curve after a certain firmware update.
I have a integra 80.2, I am on the latest FW but have had this problem for 1 year.I do remenber that certain FW update and was thinking that also, but movie or music curve I still get the brightness.I try to dial it down on the movie cruve with re eq but movie does not have an stereo mode and that is what I use for music.
Interesting. There was some discussion on the Onkyo forums about this weirdness. For the particular glitch i am taking about, it sounds REALLY tinny, almost like an AM radio broadcast. ZERO low end and a distant, tinny sounding center channel. Is that what you are hearing?
i used MultEQ XT with my 709, and the Audyssey issues only started for some of us after a December 2011 update. It's not an Audyssey problem, i only bring it up here because the of the "bright" sounding Audyssey results a recent poster has been reporting and he too has an Onkyo.
Audyssey filtering is the problem for sure, turn off Audyssey is to turn off the problem. The good news is to trick Audyssey and make it work for you and not against you. The mike and how its used is the key to all the problems one may have with Audyssey SQ.. With over five years of dealing with Audysseys bugs I've learned how to master it..
And THAT^^^ is certainly "the last word in audio"... learn how to use the product incorrectly to "master" it.
As my post(s) clearly indicated, sticking with the MUSIC curve in my receiver yields fantastic results as opposed to "turning audyssey off". Something happened with certain runs of certain Onkyo receivers that seemed to corrupt how it was handling the "movie" calculation. It wasn't just off...it was WAY off.
Everyone has there way with dealing with Audyssey bugs. Room treatments are the most popular in this thread..
Mike from a buddy? You should always use the same model mic that was bundled with your avr or pre/pro otherwise the factory installed calibration file will not match the buddy's mic specs if it's not the same model.
Yes it is the corect mike, the same as the one I have.Buy the way, I have heard no diferences with my new aud. mike and stand, but still testing
I have dipoles behind the sofa and a pair of in-ceiling speakers. For 7.1 sources I would like the dipoles in “surr back/amp assign” connections set as surr back and the in-ceiling in the “surround” connections. For 5.1 sources I would like to use the Denon 3311 height processing and have the dipoles in “surround” connections and the in-ceiling in the “surr back/amp assign” so they can be assigned as a height speakers.
I was thinking of making avr backups after running Audyssey for each setup. Then I would just reload the backup with the proper EQ that I want to be running. I probably wont change the setup that frequently as there isn't that many movies encoded for 7.1 speakers. I don't mind loading backups but pulling the receiver out to switch connections would get tedious. I wish Denon had made the "surrounds" along with the "surround backs/height/wide" assignable in the 3311.
Is there a physical speaker switch box that can physically swap/remap your speaker connections?
If you have multiple surround connections, that would work. "Surround" though as rear surrounds won't play unless "surrounds" are present.
As for a switch, a DPDT would work for swapping two speakers on one amp channel. (You'd need two switches.)
I am not familiar with how to assign speakers and whether that can be done "on the fly." Your question would be better asked on the Denon thread. More likely to get a fast, accurate and complete reply there.
This is what Audyssey set up for my frequency levels. They sound great. The only thing that was off was the distance so I manually adjusted those and I prefer my preset eq settings. Set the speakers to small and crossover freq to 80. Lmk if this looks good to you guys.
You appear to have some problems. Your surrounds and subs look to be 'maxed out'. Check out this part of the FAQ:
You should not need to change the distances (delays) set by Audyssey. If the distances were significantly out, then you may have a setup issue - see here:
