Originally Posted by mogorf
Yes Keith, I know you are doing a one-seater setup and there has been some (tentative) consensus here on making a tight measurement around the MPL when one is only interested to EQ the money seat. But IMHO that would still require multiple measurments, wouldn't it? And then, when you are doing a real-time one position tweak and finding the best graph, are you doing another full series of mic measurements afterward and averaging them in OM in order to verify the effects as per Audyssey's "fuzzy" principles? I think that would show you much more than a single mic position even if that single measurement is done on the fly in real-time. Whaddaya think?
I think that nobody who has done the 'sub distance adjustment trick', including Mark Seaton who pioneered it and Craig John who brought it to us here, and all the others who have found it to be very useful, have suggested that your method is required. You may be right - I don't know. What I do know is that the sound and the graph I posted speaks for itself wrt to the improvement I have obtained.
I am not sure how your method could be achieved in practice. AUIU you are suggesting taking several mic readings around the MLP to mimic those done with Audyssey's mic. And then averaging those measurements. How would you then adjust the sub distance settings in the AVP? Each time you adjust the sub distance by 0.2 of a foot, you need to see the impact of that adjustment on the graph. How would that be possible using the method you describe?
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
Same here. I let favoured guests use the 'money seat' and the rest, as you say, are so overwhelmed by what they hear (often hearing really good movie sound for the first time) that they are blown away anyway. For me, and you too it seems, this is the nirvana scenario. For once my downside of only having two seats works to my advantage and makes life easier wrt to calibrations.
I admire your perseverance, Feri, but asking the same question 100 times won't produce a different answer
