Originally Posted by mogorf
+1.
#1 is the most important measurement point to be taken at the MLP (Main Listening Position) where Audyssey sets channel levels and distances. Moreover, I might as well move the sub out of the left rear corner to up front somewhere between Center and Left Main speaker or Center and Right Main speaker, whichever is convenient. Corner placement of the sub may result in unwanted boominess due to room gain making it a bit hard for Audyssey to tame.
Sketch is OK, maybe a couple of photos would also be nice to get a better glimpse at your setup details, like toe-in of Front Mains, tilt of Center, proper height and angle of surrounds, etc.
+1.
Thanks for the response!!! The reason I put #1 where it is is because that is where I sit 95% of the time for watching tv and when watching movies with the wife - she sits on the loveseat. If I am at home alone watching a movie I will then sit in the middle of the couch (currently #2 on the sketch). Based on this (95% of time at end of couch and 5% of time in center of couch) should I leave # 1 and #2 where they are or should I flip flop them?
Unfortunately, relocating the sub (or any of the speakers or furniture) is not an option because of an 8 month old skooting around. In addition, the SV Sub is a monster (2 x 12" downfiring subs in a cherry enclosure) so it would really look odd having it sit at the front wall. Right now it looks like an end table slightly pushed away from the end of the couch. I have moved it away from the corner some, but not as much as I would like, but it will have to do where it is currently located.
Regarding the set-up it is not ideal, the front mains and center are too high, but they are angled down and the FL and FR are towed in slightly (as much as they can without looking like cr*p). The surrounds are hanging from the ceiling pointed inwards and down at 45 degrees, but like I said, moving any of the speakers or sub is just not an option so I am hoping Audyssey corrects for some of my poor set-up.
Here is a second go at the 8 positions - I will use a shorter tripod for positions 1,2,3, and 5 and then lengthen it to keep same mic height for 4, 6, 7, and 8. Thoughts on these 8 positions - 2' separation left to right and 3' between back row and front row.
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
