Another take from me:
I usually have the sub's volume at about 10%, then run the first position. Then I let Audyssey calculate, and check the settings.
If my distances are correct, and all looks good, I look at the speaker trims. If the sub is way lower than the rest, I turn it up a bit, and start over.
Do this until the subwoofer trim is at a few negative dB, and THEN leave it alone, do all measurements and let Audyssey work some magic in all your positions. Takes a little time, but leaves out the guesswork.
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
