Make sure you only have on the sub and not the speakers for the crawl. You will need to turn them off on the AVR (if there is a setting) or disconnect the speakers.
Hi JD - just for the avoidance of doubt in my own mind, are you saying that the Denon will output the test tones after Audyssey filtration has been applied? This was not my understanding. AFAIK, the test tones bypass Audyssey - so if Audyssey has made any significant adjustments to any part of the FR, then this will affect the reading won't it? I mean, if, for example, Audyssey has applied a (theoretical) 6dB boost between 200Hz and 1000Hz, that will surely affect the in-room dB overall level, and that actual in-room level will not be reflected in the test tones if they are 'pre-Audyssey adjustment'?
