AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #1)
"Official" Audyssey thread (FAQ in post #1) - Page 1818
post #54511 of 62201
Originally Posted by pepar View Post
Updated Linky Doc.
FAQ Links.doc 40k .doc file
Thanks Jeff. They still don't display properly though - see below. I can’t figure out why - my knowledge of html coding is pretty much less than zero.
[URL="http://www.avsforum.com/t/795421/official-audyssey-thread-faq-in-post-1/51780#user_f7"]f)7. What is ‘LFE + Main’ or ‘Double Bass’ and should I use it? (click here)[/URL]
post #54512 of 62201
Originally Posted by asere View Post
Please excuse my ignorance or dumbness but as far as waste main speakers goes how are they wasted? Are they wasted if example they are crossed at a lower point like 60hz vs 120hz?
What Chris was saying is that when people set their speakers to 'Large' they do so because they mistakenly believe they will handle the low frequencies and so by setting them to 'Small' and using bass management they are somehow 'wasting' the true capabilities of their main speakers. It stems from a complete misunderstanding about bass management and what 'large' and 'Small' really mean.
post #54513 of 62201
Originally Posted by EndersShadow View Post
I agree most speakers should be set small, but depending on their quality the xover could be lower than 80. My Polk LSi setup is all are set at 60 and they sound GREAT, I even toy with setting them to 55.
Absolutely. 80Hz is just a good starting point for most people, in most circumstances. For some a somewhat lower XO will be better and for others a somewhat higher XO. Measuring and listening will usually reveal which is best.
post #54514 of 62201
Originally Posted by kbarnes701 View Post
Originally Posted by ccotenj View Post
one thing i will never understand... many insist on crossing over too low, because they don't want to "waste" their main speakers...
of course, by doing so, they are "wasting" their sub, which is almost certainly more competent at producing those frequencies...
smile.gif  It's a weird 'perception' thing I guess which ignores the actual science and reasoning behind our recommendations. And of course, by forcing the main speakers to try to reproduce frequencies they can’t handle, at levels they can't reach, they really are 'wasting' their main speakers, in the sense that they are causing them to work less well than they actually could.
the funny thing about this is the idea that you are "wasting" the speakers' performance because you aren't pushing them to their absolute extreme limits of performance. I mean, are you "wasting" your BMW because you aren't pushing it to the redline constantly? The speakers are covering, what, like 8-9 octaves? And all you are doing is relieving them of the very lowest one which is the most difficult to produce..... and, of course, it's also the octave for which you dropped hundreds (or thousands) of dollars on a subwoofer!
post #54515 of 62201
@JEFF:
Jeff - I can do links using the editor - the one below works  for example. But if I look at it using 'Source' in the editor, there are reams of html code! It would make the Linky doc absurdly long-winded - surely it doesn't take all that code to do a simple link??
Edited by kbarnes701 - 6/14/12 at 10:11am
post #54516 of 62201
this probably has more to do with room acoustics than speaker quality. Many, many of the folks in this thread have speakers that can play down to 40-60Hz and lower with ease, but use an 80Hz crossover because you get better overalls system response. As Chris noted a few posts up, that region is dominated by modal issues with the room.... so if things sound better with a 60Hz crossover than 80Hz it's probable that the REAL reason is the interaction of the speakers with the room at those frequencies, not because your speakers can "handle" it better.
post #54517 of 62201
I would agree.
With my Denon 3808, I can sit at the MLP and toggle the crossover up and down on the fly while playing various music tracks with known good bass quality. I used Steely Dan's "Gaucho" when I last did this.
Going up and down through the crossover choices yields very different perceived in-room bass response. I found that in my room with my gear (NHT Classic 3, 3C, Classic 2, HSU 1225 sub) I preferred 100 hertz.
Brian
post #54518 of 62201
Gotcha, hopefully shortly I will find out as I am getting together some stuff to do REW of my system so I can see what kind of room treatments I need and just see how my system performs as a whole.
Also want to get these graphs before I upgrade my AVR to either one with Audyssey XT or MCAAC so I can see what differences there are in room response with the different EQ's.
post #54519 of 62201
I have JTR Triple 12-HT LP speakers (rated down to 65 Hz) in the L, C, R, Wide, and Surround speaker locations crossed over at 80 Hz to four Seaton Sound SubMersive HP's. While I would probably have set the crossovers higher myself, Mark Seaton performed the audio calibration, and I trust his judgement. My previous speakers (Mirage OM-5's) were crossed over at 100 Hz to the SubMersive HP's.
Mark
post #54520 of 62201
post #54521 of 62201
Yeah, but every day he is seriously weakening the structure of his house. We'll have the last laugh when it finally falls down biggrin.gif
post #54522 of 62201
[URL="[URL=http://www.avsforum.com/t/795421/official-audyssey-thread-faq-in-post-1/51780#user_f7]http://www.avsforum.com/t/795421/official-audyssey-thread-faq-in-post-1/51780#user_f7[/URL]"][URL=][/URL]f)7. What is ‘LFE + Main’ or ‘Double Bass’ and should I use it? (click here)
I think I see what is happening. Pls stand by ...
Don't click any icons at the top of the window where you enter your post. Just paste the line into the window as is -
If you want to go back after pasting and change the text color or emphasis, you can. But otherwise this is a straight paste operation.
Edited by pepar - 6/14/12 at 11:42am
post #54523 of 62201
post #54524 of 62201
I'm not clicking any icons Jeff - just copying the link from the Word document and pasting it. When I do, this is what I get:
[URL="http://www.avsforum.com/t/795421/official-audyssey-thread-faq-in-post-1/51780#user_A "]A. General Audyssey Issues (click here)[/URL]
What's occurring??
post #54525 of 62201
Audyssey set my Quintuple crossovers at 60 hz but the audio sounded a little thin to me. I tried the 80 hz and 100 hz crossovers and at 100 the audio was a little too heavy (bass). At 80 hz it sounded just right. Tried various BD clips and everthing came in perfect with the 80 hz crossover. Triple 8 surrounds were also at 60 hz and also changed them to 80.
post #54526 of 62201
In my case, "waste" means real money. My speaker manufacturer (PSB) makes a tower and a bookshelf speaker that are essentially the same, except for the number of bass drivers and the rated low end. The difference in cost is $1,500 per speaker. I purchased the tower model. Above 80 Hz, the two models perform essentially the same. So, since I set the crossovers at 80 Hz, I could have had the same results using the bookshelf model, saving myself $3,000... Hindsight is a bitch.
I remember Chris saying he didn't understand why anyone would buy tower speakers any more (for home theater, that is).
post #54527 of 62201
John Ashman (Alimental), a former NHT dealer who used to post at AVS quite a lot used to always say "You should only pay for your bass once". I always thought that was a great way to look at it.
Brian
post #54528 of 62201
Brian
And then we could tell those "My speakers are Large and I paid for them" folks that:
1. Modern AVRs don't have power outputs for subs, only line outs, coz AVR makers know people will buy powered subs will a built-in high power plate amp. To generate high SLP at low frequencies requires a lot of energy.
2. Having bass redirected to the sub(s) makes the in-room placement of the sub(s) not just much more easier (sub-woofer crawl), but also independent of the satellites leaving them in charge of imaging (directional), while subs are in charge of the rumbling (non-directional).
3. 80 Hz (or so) is not just an arbitrary number, it has been set as a target after a lot of experiments when the 5.1 system was introduced that shows our ears start to loose directionality below that frequency. We can still hear the deep tones but can not point out its location.
post #54529 of 62201
Because tower speakers tend to go lower than monitors which
A) allows the user to select the crossover that sounds best to them. You don't really want a speaker that starts rolling off at 80Hz with an 80Hz system crossover as it will probably start distorting at high SPLs, affecting the crossover region
B) as has been discussed in THIS very thread, some folks can localize below 80Hz.
Brian
It's always nice to simply ignore data that doesn't support our own biases isn't it? Makes our own points seem so much more valid.
The 80Hz figure is no different than the movie industry's 24fps. They selected it as the number with minimal objections that is easiest to obtain.
In the film industry case, 24fps was the lowest frame rate they could use that most folks could view as creating an acceptable illusion of movement without too much objection to the motion artifacts it causes. They chose it to save money. Lower frame rate = less filmstock used = lower costs on filmstock and processing said filmstock. They did NOT select it because it was 'the best'.
In the case of audio, similar reasons were used. 80Hz was determined to be the point where most speaker manufacturers should be able to easily produce z speaker that can play fairly flat at reasonable levels, and the point where people didn't find localization too objectionable. As I mentioned above, we've already discussed in THIS very thread, that studies have shown that stereo bass IS discernible and that the actual lowest frequencies for localization are probably around 45Hz. In my own system, with speakers that can all play flat in the 20-30Hz range in-room at Reference, I find a 40 Hz crossover preferable. But as I said, it's always easier to cite the info that supports one's viewpoints and ignore the ones that don't.
I've personally found that I can localize bass below 80Hz in stereo and multichannel setups. In fact, I never thought about it before that particular discussion but I realised that I can locate the subs in nightclubs even when they're hidden, because I can hear the difference in where the upper and lower frequencies of the bass beat is coming from.
Sometimes I hate this hobby because ignorance is bliss. Once my conscious mind is aware of something, I can't help but be distracted by it. Before avsforums, I didn't know I could localize below 80Hz, had no idea what 'dirty screen effect' was, or 'vertical banding', 'rainbow effect', posterization, high frequency ringing and edge enhancement etc. etc. Sure, all this info and knowledge about proper grayscale tracking, color fidelity and gamma curves, frequency response, modal ringing and reverberations, energy time curves and first reflection points, have all served to help me optimize my own setup and improve its results and my enjoyment of it, but it's also made me much more aware of any deficiencies in ANY setup now.
As far as psychological bias goes, it swings both ways. It's true that some folks may not be able to localize anything below 80Hz (or maybe even higher), and simply prefer to use a lower crossover with their capable speakers 'because they paid for it'. On the flip side though, it's also possible that there may be folks who might be able to localize below 80Hz who would benefit from trying lower crossovers but who refuse to consider the notion because they DON'T have speakers that can play flat that low and don't want to even think about how much it would cost to replace all their satellites with speakers capable of Reference volumes flat down to the 20's or 30's, because as we're all aware, those ARE expensive, and within the same manufacturer's line, speakers that can play flat to 105db down to the mid-20's (if a particular manufacturer even makes speakers that play that low) are going to be far larger and anywhere from 2x to 10x the price of speakers that can play flat to 70Hz. So rather than entertain the possibility that a lower crossover might produce a discernible improvement to them, they prefer to not even consider it so they won't chance learning that their own system may turn out to be less than ideal for their own hearing acuity.
Either case, using lower crossovers simply because you paid for the more expensive, bigger speakers, or dismissing lower crossovers without ever trying them because one's own speakers can't do it, and the prospect of an extremely expensive upgrade is daunting, are both less than ideal. But we all have our own psychological biases.
Max
Edited by djbluemax1 - 6/14/12 at 3:28pm
post #54530 of 62201
Originally Posted by Jim E. View Post
Yes that's true. The processing power of the stand alone unit is much more robust. I have also heard it first hand against the 4806CI.
Jim
The stand alone audyssey processor has about 2x the resolution of XT, perhaps a little more. I now have a Denon 4311 with XT32 so I no longer need the external processor (sold it) and I get much more resolution on all channels. It does, in fact, give me very good resuts with just my main speakers that go down to about 32hz (NHT 2.9's) and I'm trying to figure out if I like the multiple sub effect (I have a james sub) or if the system sounds better routing everything below 80hz to the sub alone. It seems to depend on the content...
post #54531 of 62201
Let's hold it for a moment Max. Problem comes when we believe in and accept the term "what sounds best for them". The starting point of getting subjective. Meantime, agree, nobody wants speakers rolling off at 80 Hz, but speakers would be hard to be found on the market today that would comply to that lousy spec. Agree?
Hard to believe some folks can localize below 80 Hz, we all share the same ears, don't we? Anyhow, how low can they localize below 80 Hz?
What's the problem with selecting the 24 fps? Any fps above would just be a waste of "machinery", our eyes will benefit nothing.
Speaker makers today can make excellent speakers that can easily go way under 80 Hz. Isn't this the topic discussed here when some folks get hurt for mentioning their speakers should be set to 'Small"? Go figure! smile.gif
And then such studies on stereo bass have been given up and discontinued. IIRC, Denon 5308 had a feature to route bass from L and R speakers to L & R placed subs, but even that feature did not show up in newer models. Following the model numbering system of Denon this means a model from 2007.
IMHO, localizing subs and localizing sounds under 80 Hz(ish) is two different things. You know what I mean, eh? smile.gif On the other hand, since when can an audio system of a night club reach the pinnacle of the carefully set up HT systems of members frequenting this Audyssey thread? Come on, Max! wink.gif Are they using 5 channel stereo for everyone on the dance floor to hear all the mess?
post #54532 of 62201
No more hard to believe than some folks having different vision than others. We don't all share the same ears, nor the same eyes.
Given up? David Griesinger and Robin Miller have separately demonstrated the detectability of stereo bass. Since their research hasn't been refuted, what would you have them do? Repeat the same studies and publish their AES papers all over again?
post #54533 of 62201
Please provide data or links with tolanrences, say down to 45 Hz, Sanjay. smile.gif
Did they succeed to sell their science to Denon, Onkyo, Marantz, etc.?
post #54534 of 62201
Most importantly- how is this bass handled at the mixing stages of the big studios? Is it mixed in stereo all the way down, is it summed below a certain frequency and directed to the LFE channel, or what?
Cheers,
SB
post #54535 of 62201
Share the same ears? As Sanjay already noted, we all have different eyes and ears. How often do you lend your eyes/ears to someone else? I don't know about you but I'm a bit selfish and keep my eyes and ears to myself. If you haven't noticed that people not only have different vision (those funny things that people wear on their face with the clear lenses are called eyeglasses, they correct for differences in vision), but different hearing, then there's obviously no point in discussing anything with you.
Wow... OK, thanks for making my point. There REALLY is no point discussing THAT topic with you
As Sanjay has pointed out, those studies have been confirmed and no one has refuted them. He's posted links to those studies in THIS VERY THREAD, and I've linked to them too, but then again, as we've seen time and again, you very conveniently forget any data that doesn't support your own preconceptions (or appears to contradict Chris or call any Audyssey claims into question).
This is simply a case of trying to blow smoke. The point is that I can not only localize bass below 80Hz in my own optimized system, I can localize it in other types of setups meaning it's not the perfect or specific placement in my own HT that I can localize, it's the frequencies. If I had stated that I can only localize it in my room, you would have pulled a different argument stating that it's possibly because I know where all the speakers and subs are placed in my own HT.
Replies in bold and underlined
Feri simply likes to forget anything that contradicts Chris, calls Audyssey into question or contradicts his own preconceptions. We're all aware that he follows this thread quite devoutly, and was himself, involved in the discussion about stereo bass, but as is evident from the 2 separate occasions where the discussion came back around AFTER the first time, he has conveniently chosen to forget everything that anyone has referred to including the studies that you linked to. Not much point discussing anything that would contradict Chris K.'s "don't know why anyone would buy tower speakers anymore" with Feri.
Feri, if you REALLY wanted evidence, you can search this very thread. I'm not wasting the time to point you to it YET AGAIN.
Max
P.S. The main reason I chose to post about this is because the same folks keep on repeating the '80Hz' mantra, citing only the stuff that supports their position. They never bring up the fact that there is evidence to support other options/configurations. My posts are simply to even out the playing field so folks can see that there are not only other possibilities, but factual reasons to support them, and they can look it up and choose for themselves
Edited by djbluemax1 - 6/14/12 at 8:26pm
post #54536 of 62201
Cheers,
SB
As FilmMixer has already stated (for anyone who isn't aware, Marc is an award winning audio mixer, hence the SN FilmMixer), many/most studios mix film soundtracks with full range front LCRs and subs for additional reinforcement for the LFE and surrounds.
Max
post #54537 of 62201
Already provided links to papers by both Miller and Griesinger the last time this discussion came up. It's obvious you didn't read them last time. If you are truly interested this time, do a thread search.
They weren't trying to sell their science to Denon, Onkyo, Marantz, etc., just publish the results of their research.
post #54538 of 62201
No, no, Sanjay, i wasn't talking about stereo bass, but wanted to know any evidence of the ability of our ears to localize bass below 80 Hz, e.g. even down at 45 Hz. And whether there is really such a huge difference between people's ears or not. If you know of such published research I'd be glad to read it, just like I read all about stereo bass when you posted links. smile.gif
I see. Thanks.
post #54539 of 62201
The same year Miller presented his paper to the AES Convention (2005), a research team from Australia was publishing concurring results:
Localization and Image Size Effects for Low Frequency Sound
"Using four subwoofers, this study investigates auditory image characteristics for one-third octave bands of pink noise in the frequency range 25 Hz to 100 Hz. The subwoofers were located at 90 degree intervals: 45 degrees to the left and right, and in front of and behind the subject. Single noise bands, coherent pairs, incoherent pairs and different frequency band pairs were subjectively assessed. Subjects drew the auditory image as an ellipse on a response sheet. Results indicate that left-right discrimination occurs even at the lowest frequencies of human hearing – a finding consistent with other recent research. ASD and ASW are correlated, increasing at low frequencies for the stimuli tested, and for simultaneous presentation of coherent or incoherent signals."
The paper can be purchased here: http://www.aes.org/e-lib/browse.cfm?elib=13041
post #54540 of 62201
Hi Feri,
Er... that would be every THX spec speaker then!  I was about to take this up with Max and then saw your post, so I am killing two birds with one stone :)  My THX spec speakers are designed to roll off at 80Hz and to be used with a sub. They are not intended to be used on their own of course. I have sympathy with Max's overall position but THX spec is THX spec and that demands that the mains roll off at 80Hz.
I certainly can't. I have tested it and I can just about localise at 100Hz, but even then it's not certain.
Some movies are being made at 48 fps now - Peter Jackson is doing it on, IIRC, the Hobbit. But apparently the result is horrible and makes it look like it was shot on video - the 'soap opera effect'.
LOL. People do seem to view this large and small thing as some sort of affront to their manhood. "Whaddya mean - my speakers are *small* you lousy SOB" :)
I used to frequent a lot of high-end clubs with very good sound systems, but there is always way too much emphasis on bass and the sound is really multi-channel mono. There is no 'sweet spot' in a club. It's not a useful analogy IMO to a good home system.
