Sorry, I did not know that.
Featured Stories
Topics Discussed
Related Forum Threads
- First Time Sub Owner - Quick Help On Setup Last post on 1/13/13 at 4:30pm in Subwoofers, Bass, and Transducers
- Marantz AV8801 Preamp/Processor Official Owner's thread Last post on Today at 6:43 am in Receivers, Amps, and Processors
- Onkyo TX-NR818 "official" owner's thread discussion Last post on Today at 7:35 am in Receivers, Amps, and Processors
- I could use some advice please Last post on 3/3/10 at 6:16pm in Speakers
- Energy Owners Thread Last post on Today at 9:03 am in Speakers
Related Articles
Audyssey FAQ and New User '101' Help & Setup Guide
Edited on 1/20/13
- Audyssey FAQ and Beginners '101' Setup Guide
Edited on 8/22/12Related Reviews
"Official" Audyssey thread (FAQ in post #1) - Page 1896
Gear mentioned in this thread:
- pepar
- Trader Feedback: 0
- Wireless Member
- offline
- 23,651 Posts. Joined 7/2002
- Select All Posts By This User
- joehonest
- The LastWordIn Audio
- offline
- 891 Posts. Joined 5/2011
- pepar
- Wireless Member
- offline
- AustinJerry
- online
- 3,352 Posts. Joined 1/2003
- joehonest
- offline
I know what I like, and now I got it, whats wrong with that? There really wasn't any audible problems before, only with audyssey on caused the audible discomfort. Sure I know theres something in my HT mix that needed to be corrected and that can be done in many different ways.. I found a fix / patch that is cost effective and I feel that really works for my needs. I think I should get a little credit for my ingenuity. In this game its not your way or the highway... My way didn't ignore the problem, it hit it straight on like a shot gun blast at point blank range.
If I said it took $1500 in room treatments to fix this, would I of gotten the nod of approval?
Most people who have used audyssey have bitched about it in one way or another at sometime.. For me, any fix that works is a good fix, and if it didn't cost me anything than its that much better !
I'm just passing my findings on to others who are in the same boat as I, use at your own risk..
Edited by joehonest - 10/4/12 at 7:20am
- bfreedma
- offline
- 1,950 Posts. Joined 10/2005
I know what I like, and now I got it, whats wrong with that? There really wasn't any audible problems before, only with audyssey on caused the audible discomfort. Sure I know theres something in this HT mix that needed to be corrected and that can be done in many different ways.. I found a fix / patch that is cost effective and I feel that really works for my needs. I think I should get a little credit for my ingenuity. In this game its not your way or the highway... My way didn't ignore the problem, it hit it straight on like a shot gun blast at point blank range.
If I said it took $1500 of room treatments to fix this, would I of gotten the nod of approval?
What you did to "resolve" the issue is the equivalent of cutting off your arm to cure a hangnail. No credit due.
- primetimeguy
- offline
- 2,807 Posts. Joined 9/2005
Thanks for all the fast replies everyone.
I am going to give it a few days of listening and give myself a chance to adjust. I only spent a few minutes listening to it after running Audyssey.
Once againg thanks to everyone for the help and all the great info on this site.
Could also try the "music" curve which is flat and does not have high freq roll-off. Maybe that is more to your liking.
- joehonest
- offline
Music surround modes also spead the center or vocales differently than movie surround modes. The mains will have more to do with what you hear in many music modes, which is a good thing, if the center is doing more harm than good... This is very clear with 2.0 inputs.
Edited by joehonest - 10/4/12 at 8:41am
- kbarnes701
- offline
- 10,433 Posts. Joined 1/2008
It's not super critical to get the level at exactly 75dB on that first Audyssey screen. The idea is to get it to 75dB so Audyssey can set the trim later to something appropriate - between -3.5dB and +3.5dB is the usual range suggested.
I would set the sub to about 78/79dB initially and then run Audyssey and see what trims it gives - if the sub is in that -3.5dB to +3.dB range, you're done.
You can do a quick 'n dirty test by putting the Audyssy mic at the MLP, running the minimum number of positions (3) without moving the mic and then seeing the trim for the bass. If it;'s OK, then run Audyssey using all positions as normal.
Please report back your findings and if necessary we can dig a little deeper. I suspect you will be OK.
Thanks - I adjusted the B&W PVD1 by it's max volume trim by -6db - this allowed Audyssey to run as it showed a level of around 77db or just a little less. I checked the Denon channel levels and it showed that all the M-1s had been increased between 3db to .5db while the subwoofer had been decreased by 4db. The -4db is just outside the parameters you mentioned of + or - 3.5db. Do I need to try any other adjustments and re-run Audyssey to try to get the subwoofer adjustment from -4db down to 3.5db or less or the - 4db is ok?
Hi - sorry for late reply - I have been away for a few days without a net connection. No need to do anything - -4dB is just fine. You are good to go!
- primetimeguy
- offline
I wasn't referring to the Music Surround Modes, but rather the chosen Audyssey curve. I believe in most Onkyo's where you have a choice the flat curve is called Music and the reference curve with high freq roll-off is called Movie.
- sdurani
- offline
- 15,812 Posts. Joined 10/2001
Besides, PTG already mentioned that his comment was about the music EQ curve, not music surround mode, so no need for me to go further into that.
- joehonest
- offline
The onkyo has RE-EQ on/off in most movie modes. The Audyssey curve music / movie are tied to the sound modes with the 5007, The newer onkyos / Audyssey do offer that feature in its self. I tried them all.. But still for me no Audyssey curve/ fitlers for only the center sounds the clearest, but the subs, mains and rears all do benefit from Audyssey. I'm happy onkyo allows me this tweak.. I see the new Audyssey software suite now has a "Dialogue Enhancer" feature, Its good to see Audyssey listens to the needs and crys from there users... A good reason to upgrade, If I haven't found this tweak, it would of been well worth the cost just for the new "Dialogue Enhancer" feature..
- pepar
- Wireless Member
- offline
I'm glad you're happy, but don't kid yourself. You did not fix the problem, you fixed the symptom. And my deja vu tells me that this will be my last comment on your "fix." Unless you bring it up yet again in another six months.
- AustinJerry
- online
Not Joe (thank goodness), but he may have been referring to a feature on the new Denon 4520 AVR. I think this is a Denon technology, not an Audyssey technology. If it were from Audyssey, their marketing department would have made us well aware of it.
- joehonest
- offline
I saw the new denon 4520ci has it along with other Audyssey menu goodies,,
check it out @
http://www.avsforum.com/t/1430049/the-official-denon-avr-4520ci-thread
- pepar
- Wireless Member
- offline
- pepar
- Wireless Member
- offline
- joehonest
- offline
- joehonest
- offline
I wish I could post some techy print out to be analyzed.
I believe its some phasing cancellation, but not at all frequencies, due to being 3way speakers for mains and cc.
- primetimeguy
- offline
- pepar
- Wireless Member
- offline
- sdrucker
- online
- 1,052 Posts. Joined 2/2006
That would be a relatively simple assessment with an OmniMic or REW measurement kit, and a frequency sweep on a Frequency Response graph:
a) Run test tones wirh the center channel with PLII Cinema and Ausyssey Off (other speakers off)
b) Repeat with Audyssey on, and Dialog Enhancer, DEQ and DOL off
c) Repeat with above, but Dialog Enhancer on, DEQ and DVOL off
If you overlay these three graphs, you'll see what Audyssey and/or Dialog Enhancer is or isn't doing, and whether Dialog Enhancer is effectively turning off center channel Audyssey.
- pepar
- Wireless Member
- offline
- sdrucker
- online
- kbarnes701
- offline
That is not correct. Re-EQ is always off unless you are in a THX mode. If you use THX and therefore Re-EQ, you need to ensure that the Audyssey Music/Flat curve is used in order to avoid a double roll off at the HF end. In all other (non-THX modes) the music/movie curves have nothing at all to do with the sound modes (and they are not really "tied to" them ever).
I'd prefer to find out what is causing the problem rather than have no room correction on the all-important centre channel.
What is the "new Audyssey software suite"? ITYF that the Dialogue Enhancer is something in your particular AVR.
- Gellidius
- offline
- 548 Posts. Joined 3/2007
Wow, i never expected the definition for ITYF would be on the Net, but it is.
see here: http://www.internetslang.com/ITYF-meaning-definition.asp
- kbarnes701
- offline
LOL. Good find, that site.
- djbluemax1
- offline
- 1,564 Posts. Joined 10/2004
Max
- "Official" Audyssey thread (FAQ in post #1)
Recent Discussions
- › OLED TVs: Technology Advancements Thread 7 seconds ago
- › Recommendation on size and model for 12.5 feet distance? 9 seconds ago
- › HDHomerun Prime Owners Thread 12 seconds ago
- › Recommendation on size and model for 12.5 feet distance? 41 seconds ago
- › Official LG XXLM7600 Owners Thread... 42 seconds ago
- › Whatever happened to DCM's Steve Eberbach? 45 seconds ago
- › 2013 Formula 1 in HD 1 minute ago
- › B&W Owner's Thread 1 minute ago
- › AVS Can't-Wait Special—"Mastered in 4K" Blu-Ray Releases 1 minute ago
- › The Official ChromaPure thread 2 minutes ago
Recent Reviews
- › Marantz AV8801 by zuluwalker
- › VIZIO 55 inch Class LED - M3D550KDE by indept
- › Optoma GT700 3D Game Time Projector by paul65000
- › InFocus X1A DLP Multimedia Video Projector by coastercard
- › BenQ W1070 1080P 3D Projector by arjjr
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
