Originally Posted by aaranddeeman
Many thanks to giomania for the excellent write-up.
I ran Audyssey this afternoon using those steps on my Denon 1909.
After calibration, I found my fronts were set to large, I then changed them to small.
Also the crossover frequencies were set as below
Front : (None initially, 40Hz after changing it to small)
Center : 40Hz
Surr : 60Hz
Surr Bk : 60 Hz
LFE : 80 Hz
My fronts are JBL E80, Center is EC25 and surrounds are E10.
After looking at speaker specs I changed the crossovers as below
Front : 60 HZ
Center : 90 Hz
Surr : 80 Hz
Surr Bk : 80 HZ
LFE : 80 HZ
So here are my questions
1. I have noticed Audyssey always sets my SUB a little to hot (about 3db). So should I reduce the db level on receiver or turn the level nob on the SUB. (With multiple retries of the SUB level knob setting, I have achieved to get close to 0 db level for sub during calibration, so I am reluctant to touch that knob again)
2. By making the changes to crossovers mentioned above, will by calibration be thrown off?
3. I read here that I should set the LFE to 120Hz, should I change it?
Thanks in advance for your responses.
Center : 40Hz
Surr : 60Hz
Surr Bk : 60 Hz
LFE : 80 Hz
Front : 60 HZ
Center : 90 Hz
Surr : 80 Hz
Surr Bk : 80 HZ
LFE : 80 HZ
Altering any of these Xovers or the gain trims won't alter the MultEQ filters.
Definitely raise your LFE filter to 120Hz.
For the LCR Xovers, I would initially try 80Hz for all of them for a while until you get used of the sound, then try them at 60Hz. BTW, I'm assuming the centre is designed to be mated to the mains.
After you've sorted out the fronts,listen to the system for a few days before altering the loudness of the sub. If you do alter it, then do so with the gain trim (even though you've managed to get it to 0dB). You can quickly and easily bring it back to where it was if you want to.
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
