since you have no interest in audyssey, please move on to another thread...
Featured Stories
Topics Discussed
Related Forum Threads
- First Time Sub Owner - Quick Help On Setup Last post on 1/13/13 at 4:30pm in Subwoofers, Bass, and Transducers
- Marantz AV8801 Preamp/Processor Official Owner's thread Last post on Today at 5:49 pm in Receivers, Amps, and Processors
- Onkyo TX-NR818 "official" owner's thread discussion Last post on Today at 9:38 pm in Receivers, Amps, and Processors
- I could use some advice please Last post on 3/3/10 at 6:16pm in Speakers
- Energy Owners Thread Last post on Today at 9:16 pm in Speakers
Related Articles
Audyssey FAQ and New User '101' Help & Setup Guide
Edited on 1/20/13
- Audyssey FAQ and Beginners '101' Setup Guide
Edited on 8/22/12Related Reviews
"Official" Audyssey thread (FAQ in post #1) - Page 1914
Gear mentioned in this thread:
- kbarnes701
- Trader Feedback: 0
- offline
- 10,387 Posts. Joined 1/2008
- Select All Posts By This User
BTW, I read your build thread today - I love the way you say in the first post or two that you don't want to live in a black room and then spend the rest of the thread gradually progressing towards, er, a black room! Great thread and I enjoyed reading of your experiences. I'm also keen to know where/how you found a woman who not only tolerates cables and speakers everywhere but actually *likes* it....
Pure gold.yea...
the initial design goal kinda got lost there, didn't it?
thanks... i enjoyed "building it"... as you saw, there were quite a few "learning experiences" along the way...
as far as swmbo, she's a keeper, for sure...
i guarantee you that you don't want her sister though...
I won't ask.... ;)
Again not true, I have interest in Audyssey, this is why I am here. This is just confuse me when you refer to non-existent suggestions to something I was not even asked. Or do you suggest to solve any problem with Audyssey? Sorry, I've tried - it doesn't work and make things worse in my case. Do you have any suggestion on how to make Audyssey not to distort high frequencies in my case? This would make my problem with room treatments not so urgent
- jdsmoothie
- AVS Addicted Member
- offline
- 34,352 Posts. Joined 9/2007
30Hz is nothing really special as far as subs are concerned. I'd consider 20Hz to be the very minimum that a true sub should reach - and preferably quite a bit lower. But the main reason I would set a crossover is that the sheer amount of power a speaker needs to reproduce <30Hz will suck the life out of your amp and also make the Diamonds work their a$$es off, struggling to reproduce frequencies they were never designed to do really. Crossing over to a capable sub (or preferably subs) will relieve the amps and take the strain off the Diamonds, enabling them to give of their best in the mid and higher frequencies. So a capable sub or subs won’t only benefit the bass, it will also benefit all the other frequencies too. So I think you will get the best out of your Diamonds by letting the subs do the work they were designed to do: reproducing low bass. Personally, I'd measure and then hope to cross over at about 80Hz, or maybe 60Hz and let the subs take the strain.
All of the above also ignores the fact that the Diamonds are positioned for imaging not bass, so there is no guarantee that they are even in the best place in your room for bass anyway, and you could easily find that the overall sound is much worse if you used them 'full range'. Another reason to set a crossover and use the subs in the best place for smooth bass.
If you feel you need more or better bass, the way to go is to get more or better subs IMO.
My Focal Stella Utopia front speakers are spec'ed to 22 Hz. They also have their own electromagnet powering their 13" woofers all the way up to 220 Hz. For music, I have carefully listened and to my ears, they sound at least as good "full-range" as "small" with a 40 Hz crossover. The fronts are driven by Emotiva XPA-1 monoblocks which can handle 1000 watts at 4 ohms so they don't really lack juice. Even Audyssey Pro agrees because during calibration, it recommends a "full-range" setting. Therefore, for music, I run the fronts "full-range" because otherwise, I would have wasted my investment in my fronts and amps.
For movies, however, I always run them as "small" and send the bass to 4 x SVS PB-13 Ultras and 2 x Paradigm Servo-15's.
This is also why during an Audyssey Pro calibration, I select the 40 Hz crossover but then shift to full-range when listening to music. The way Audyssey Pro works, this doesn't seem to have a detrimental effect.
Mark
- ccotenj
- Trader Feedback: +30
- offline
- 21,915 Posts. Joined 3/2005
lol...
a bit of withdrawal...
the 4520 will be here friday, though..
i'll be able to satisfy my wonk/nerd jones over the weekend...
- diptych
- offline
- 5 Posts. Joined 2/2012
- kbarnes701
- offline
Take a look at the FAQ section that covers this and see if it helps...
- kbarnes701
- offline
Why should I review my measuring technique? What made you think I should? What suggestions did I get? I feel I get none, I figured myself that
1) flutter-echo is my problem and until it is eliminated I cannot get any better result independent of what I try
2) Audyssey in presence of flutter-echo works very bad making the sound worse and introducing a kind of jitter to the high frequencies that is sounding similar to the flutter-echo of the room where it was calibrated. In no way it should add distortion to the highs, but it does. Especially apparent on how bells sound - clean and transparent without Audyssey, harsh and distorted with Audyssey, this is not the level, as single note sound cannot be so different based only on level.
If you are confident that your measurement techniques are good, and if you have read and followed all the advice in the Setup Guide and FAQ and 101, then maybe Audyssey is not for you and you need to experiment with treatments and possibly other methods of electronic room EQ. Good luck.
- kbarnes701
- offline
Please read the advice that is available here - specifically the Setup Guide and the FAQ. Maybe this FAQ answer can help you with this specific aspect of your query:
a)9. Why are my high frequencies 'bright' or 'harsh' since running Audyssey?
- kbarnes701
- offline
Mark
Yes, music can be a different ballgame I agree. I don't use my HT for (serious) music listening and I always forget that so many members here do use their systems for both music and movies. I ought to perhaps add a comment in my sig along the lines "Anything I comment on refers to *movie* use of the system *only* :) I have a separate music system in a different room and the speakers there can manage about 40Hz with some help from the room, and I find that is plenty for my music listening - but it would be absolutely, totally inadequate for my movies.
- batpig
- terrorist and rioter
- offline
- 21,142 Posts. Joined 2/2007
When I set my Dynamic Volume to "Heavy", I find that my audio signal will cut out momentarily. The volume drops to zero then quickly rebuilds to whatever it was at before. This happens at all levels of Dynamic Volume, for a variety of input sources on my receiver. This does not happen when I turn off Dynamic Volume. Any thoughts? I am quite perplexed.
Nothing to worry about... when Dyn Vol is activated it drops the volume and then as you say "builds" back up over the course of a few seconds. Because Dyn Vol works by "looking ahead" at a buffer to evaluate changes in program loudness, I think it's a way to avoid a sudden spike in volume and give the processing time to "ease in" to what it determines to be the best average level based on its analysis of the content.
So, in other words, normal behavior. And really, why does it matter? It only lasts a few seconds when it first turns on and then it's done going forward. Once you have Dyn Vol activated to the level you desire, you just leave it there.
- Gellidius
- offline
- 532 Posts. Joined 3/2007
I have read and followed everything there, including toeing the speakers, and trying different mic (thanks to Valiheli shop here for kindly providing the mic for test). Measured and compared both mics response. Compared what Audyssey did - in Movie mode it is quite similar to the uncorrected curve for high frequencies, but high sound really harsh, moreover distorted which is obvious on the clean bells sound - turning Audyssey on/off makes so drastic change in the clarity of bells (while no significant change in level) so there is no doubts Audyssey distorts them after calibration. It is not something in the area of personal preference, it is the completely clear tone vs. heavily vibrating and dirty one. If you newer heard this I can understand why you think it is because others do something wrong, but believe me, it is a real distortion. I am just sharing my conditions and at this point I believe it is the flutter-echo that confuses Audyssey and makes it sound harsh. Other people who have harsh highs could also check their room conditions, may be we can find some similarity and finally find the reason and so the way to fix it. Currently it seems that people that have this problem are simply ignored or blamed for wrong calibrating technique, while it is clearly not calibrating technique in many cases (surely still valid for some).
I really like how Audyssey works for bass and mids, and simply used to this already and cannot listen without it, but this distorted highs problem kills all enjoyment from the music
- Selden Ball
- offline
- 4,361 Posts. Joined 1/2001
- wse
- Trader Feedback: +1
- offline
- 2,733 Posts. Joined 3/2008
This is also why during an Audyssey Pro calibration, I select the 40 Hz crossover but then shift to full-range when listening to music. The way Audyssey Pro works, this doesn't seem to have a detrimental effect. MarkI love you room +10. I will try that as well I am surprised about Emotiva amps with Focal Stella Utopia ? Why not McIntosh, Classe, Mark Levinson?
- wse
- offline
Ok since you are the Audyssey master what do you think of this basically saying Audyssey is crap! http://realtraps.com/art_audyssey.htm
And then they tell me this!
"That looks typical for a home-sized room, particularly the jagged frequency response under 100Hz. I'm sure you'd get much better results by bypassing whatever EQ or "calibration" the THX guy added, and using quality bass trapping in as many corners as possible. For more detail about why we generally don't recommend room EQ or "correction" software, see: http://realtraps.com/art_audyssey.htm
Broadly speaking there are 2 steps to start with in formulating your treatment strategy:
- First is to add as many bass traps to as many corners of the room (including wall/ceiling corners) as possible. This step will flatten out the overall frequency response of the room, making everything sound better.
- Second step is to create a Reflection-Free Zone at the listening position, as explained here: http://realtraps.com/rfz.htm This step will dramatically increase the overall clarity of your system, and the depth and detail of your stereo image and soundstage.
I'd suggest taking a look at some of our room kits to get some basic packages that give you enough traps to do both these steps. For a room your size, the Standard Room Kit ($1899.99 plus shipping) should be seen as a minimum full-room treatment package, and is definitely enough treatment to make an obvious improvement in just about any room.
The Mondo Room Kit ($2299.99 plus shipping) would be even better. If these kits are out of budget, then even our Starter Kit ($1199.99 plus shipping) will make enough improvement to show that you are on the right track, and can be expanded down the road if even better results are desired.
At the higher-end of the spectrum, you can achieve world-class sound using our Modular Kit approach outlined in this video: http://www.realtraps.com/video_hearing.htm This strategy would probably be between $10k and $15k for a room your size.
You can find our room kits here: http://realtraps.com/p_roomkits.htm"
It sounds to me like all they are saying is buy $15K of bass traps from us and your room will sound great, unlivable but great
- batpig
- offline
Also, if you read that article they set up somewhat of a "false choice" about Room EQ vs. acoustic treatments. These are not mutually exclusive approaches and everyone on this thread will always encourage people to create the best acoustic situation possible BEFORE applying electronic room correction. The better the starting point, the better the results.
It's also worth noting that (1) they admitted that they found MultEQ improved the sound and (2) the article refers to a much older version of MultEQ.
- kbarnes701
- offline
<munch>
I think someone selling traps is going to say traps are what you need ;) The reality is this: the room is the most important component in your system and the one that has the most impact on the sound you hear, so it is always going to be worthwhile to get the room right. Treatments and traps are ideal for this because they will improve the response of the entire room, whereas electronic EQ tends to improve the response for a given area only. Also, traps are the only way to deal with room nulls. Electronic EQ won't really help there.
So the prioritisation is this: measure the room/speakers and discover where the problems are. Install treatments and traps as required, within the limitations of budget and WAF. Make sure the speakers and the sub(s) are in their optimum places wrt to the MLP. Then run your electronic EQ, such as Audyssey. If the latter is XT32, then you will now have an absolutely terrific sounding room.
Many people are forced to compromise some of these areas mentioned. Only you can decide which compromises to make in your own room. Some people run just Audyssey alone and are very happy - it will certainly be potentially better for most people than no EQ at all. Others are able to treat their rooms 100% with treatments and traps and so have far less need of Audyssey. Many use both.
FWIW, I have relied solely on Audyssey (Pro) for some time (although my room has plenty of 'natural' treatments like heavy drapes, thick carpeting, big theatre chairs in upholstered material (not leather) and it sounds remarkably good. But this weekend I will be installing the traps etc that will be delivered during the week and I expect the sound quality to audibly improve.
Bottom line: only you can decide where the compromises will fall, how much budget you have and how much you can do without alienating the rest of your family. This thread is primarily about Audyssey so you'd expect most of the posts to be on that topic and not on the topic of room treatments - but equally most of the experienced people here will appreciate the benefits of treatments too.
BTW, I'm not the "Audyssey Master" (but thanks for the compliment) - just a regular Audyssey user who has learned everything I know thanks to this thread and the help of the guys who hang out here. The FAQ I compiled is just the distillation of all that into one central location.
- kbarnes701
- offline
There is something clearly wrong. I am not sure what it might be. I assume it is not the source that is clipping. It could be a faulty Audyssey mic, a faulty speaker or any number of things. You are not being ignored or blamed for poor calibration techniques, but unfortunately it is not always easy to diagnose problems at a distance. Audyssey cannot, when working normally, create the circumstances you describe (highlighted by me in red above) so this tends to make me think that something else is the problem, but I admit I have no idea what it might be - sorry.
EDIT: Selden makes a good suggestion - can you point us to the source for the bells - maybe we can hear for ourselves what they sound like.
- kbarnes701
- offline
Because they will make absolutely no difference to the sound quality?
- wse
- offline
- wse
- offline
The reality is this: the room is the most important component in your system and the one that has the most impact on the sound you hear, so it is always going to be worthwhile to get the room right. Treatments and traps are ideal for this because they will improve the response of the entire room, whereas electronic EQ tends to improve the response for a given area only. Also, traps are the only way to deal with room nulls. Electronic EQ won't really help there.....So the prioritisation is this: measure the room/speakers and discover where the problems are. Install treatments and traps as required, within the limitations of budget and WAF. Make sure the speakers and the sub(s) are in their optimum places wrt to the MLP. Then run your electronic EQ, such as Audyssey. If the latter is XT32, then you will now have an absolutely terrific sounding room. ... BTW, I'm not the "Audyssey Master" (but thanks for the compliment) - just a regular Audyssey user who has learned everything I know thanks to this thread and the help of the guys who hang out here. The FAQ I compiled is just the distillation of all that into one central location.Thank you for your response, I agree the room is key, but it just bugs me that they are pushing so hard on their "Bass traps". I could just build my own for probably a 10th of the cost. Do you have any good link as to building bass traps. Also why in the corners I thought I could just take 12 inches of Corning board stack them together that would be as effective? Then apply Audyssey
- wse
- offline
Your research? Published papers!
So what do I need for Bass?
- lamonsasa
- offline
- 3,554 Posts. Joined 1/2007
g)3. What is Reference Level Offset in Dynamic EQ?
i did but it says nothing about XBOX 360, what should i set the reference level for the xbox 360 source? or should i leave it at 0? and should i defintley change the reference level from 0 to 10 for my cable tv source? what is changing it from 0 to 10 going to benefit me?
- kbarnes701
- offline
I did have a Mark Levinson once in the days when I knew so little that I believed that modern amplifiers working within their design parameters actually made a difference to the sound quality. Now I have Emotivas and have spent the cash I have saved on thing that actually make a difference. The B&W Diamonds are terrific speakers but I prefer my MK S150s.
- kbarnes701
- offline
I'm not surprised that people selling bass traps 'push hard' for bass traps really :) It's possible to build your own but you need to understand the physics - it's not, AFAIK, as simple as taking some thick stuff and slapping it all over the room. I'd imagine there is a thread for it on AVS - DIY Room Treatments or similar?
- kbarnes701
- offline
Ah right, sorry. Games, like music, are not mixed to any industry standard (unlike movies) so there is no 'reference level' for games. So all you can do is experiment with the RLO that gives you the best result. Similar with TV - again no reference standard so all you can do is experiment. Start with 5, listen and evaluate and then try 10 or even 15 and see which gives the best sound to your ears. Changing from 0 to 10 will shift the point at which Dynamic EQ ceases to have any effect. This is usually (for movies) reference level or 0dB. If you set RLO of 10, then DEQ ceases to have an effect at -10dB instead of 0dB. There are no right and wrong settings for DEQ for music, games or TV - all you can do is experiment and go with what sounds best to you in your room, at your listening levels, with your source material.
- pepar
- Wireless Member
- offline
- 23,639 Posts. Joined 7/2002
http://forum.studiotips.com/
Specifically, here. SuperChunks are what I have made/installed and documented here.
- "Official" Audyssey thread (FAQ in post #1)
Recent Discussions
- › Do You Prefer Tube-Based or Solid-State Audio Gear? 1 minute ago
- › Match input to output type on NR509 2 minutes ago
- › Buying Open Box,or older Pre-Owned Plasmas? A viable option? 4 minutes ago
- › denon 3313 ps3 5 minutes ago
- › Official Panasonic VT60/VT65 Series Discussion Thread [No Street... 10 minutes ago
- › Jamo THX One LCR 12 minutes ago
- › *Official* Denon AVR-1911/791 & AVR-2311CI/891 Owner's Thread 12 minutes ago
- › Japan's NHK: iOLED Solves Longevity Problem 13 minutes ago
- › Multichannel music server hardware/software 13 minutes ago
- › ML Dynamo 700W vs. SVS SB-1000 15 minutes ago
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
