AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #1)
"Official" Audyssey thread (FAQ in post #1) - Page 1923
post #57661 of 62195
Originally Posted by kbarnes701 View Post
Thanks for clarifying the numbers earlier.
FWIW, this is my personal take on it, based on my experience with Height channels and dipole/bipole speakers. At one stage in the development of my HT, I was not using monopoles for my height speakers because the manufacturer of my main speakers did not make a suitable (smallish) monopole for the height channels and I am of the belief that the voicing of speakers is important in creating the overall sound field in a convincing way. Consequently I used dipoles, set to the bipole mode, for my height speakers. I asked Audyssey specifically what their views were on this because they recommend direct radiators for height speakers. Chris replied that they had not evaluated dipole/bipole speakers for height channel use but thought they would "probably be OK". I used the bipoles for some time and was always satisfied with the sound, as they were a) voiced the same as my mains and b) the height 'effects' are fairly diffuse in nature anyway. Later, I changed my speakers and the manufacturer of my new speakers did indeed have a suitable direct radiator for the height channels and so this is what I currently use. I cannot say with any degree of certainty that one was better than the other - both give a useful, pleasing effect. As a result, I believe that you could use either type of speaker for height duty and be happy with the result. I cannot say the same for omnidirectional speakers as I have no experience with omnis at all.
I would say that in your room, you are unable to achieve even an approximation of Audyssey's recommended locations for the height channels, so you might prefer (as I do) to use Dolby PLIIz for your height channels, as Dolby's placement recommendations are far les stringent than Audyssey's. My height speakers are up close to the ceiling and a little outboard of my mains. Remember, it is OK to mount height speakers on the ceiling if this brings them more into line with Audyssey's recommendations, but such an arrangement has a very low WAF. PLIIz derives the height information from the surround channels whereas DSX derives it from the front L&R channels and this may be one of the reasons that the placement requirements for both differ. I also found that DSX messes with the surround channels in a way I did not like, whereas PLIIz does not - YMMV on that. Also remember that Height (and wide) speakers are not part of any recognised 'standard' so their use is going to be a matter of preference and there is no right and wrong at this time - nor will be until/unless content is specifically created for these channels. This means that, really, whatever sounds good to you IS good.
WRT to side surrounds, I have used monopoles, dipoles and (now) tripoles. Each iteration has resulted in, for me, a significant improvement in envelopment. Bear in mind that I use my HT ONLY for movies and do not do any (serious) music listening there. Some people say that for music, monopoles make the best choice for surround speakers. My own view is that dipoles/tripoles are much better for movies and provide that overall immersion in the sound field that is desired, without excessive localisation of the surround channels. The tripoles have the benefit of good localisation when the content specifically demands it, but give terrific ambiance and envelopment otherwise - the best of both worlds. My surrounds are placed at 90 degrees to the MLP, but there is some latitude with this and you can place them rearwards or even forwards of that position - in fact if I had rear surrounds I would probably move my surrounds forward a little to help create the 'bubble' more convincingly. I do not have rear surrounds because my MLP is unavoidably close to the back wall, as yours is, and I do not feel that I can position rear surrounds effectively as a result. I have toyed with rear surrounds in the ceiling above the listening positions, but not carried it through (yet) as I remain unconvinced of the efficacy of such a non-standard location. I would prefer no rear surrounds at all to rear surrunds that might mess with the 'bubble' I have worked hard to create. Again, YMMV. I would, ideally, move my current tripole surrounds to about 110%, placing them slightly behind me (in the absence of rear surrounds) but this would bring them closer to the back wall than I think is desirable. If my room was deeper, I would definitely try this and see what effect it had on overall envelopment, but then, if my room was deeper I'd have rear surrounds, so the point is circular really.
I have no direct experience with wides because my room cannot physically accommodate them, but I would say that it's important to remember that Audyssey's recommendation for positioning is just that - a recommendation. You might find that conventional direct radiating wide speakers would work well as wides if you placed them where you currently have LH/RH marked on your diagram (but obviously at ear level). If I was determined to try wides, this is where I would put them to test their efficacy.
I have no experience of omnidirectional speakers at all but personally I would avoid them on the grounds that I have never really seen them recommended for side surrounds over dipoles and for rear surrounds over direct radiators.
I don't know if the above has served to help or to confuse, sorry. But my comments are based on actual experience (except where stated) and in a small, difficult room similar, conceptually to yours, sharing many of the placement difficulties. If I had to come down hard with a recommendation, it would be monopoles for the heights, dipole/tripole for the surrounds, monopoles for the wides and monopoles or bipoles for the rear surrounds - but there is no right and wrong answer here and I am sure others will have different views. Some of it will be pure preference (as I have for dipole/tripole surrounds - albeit a preference that is supported by various 'standards' such as THX etc) so given that, the only way to be sure to get what YOU want is to try different things. Problem with that is that experience is a great teacher, but the lessons are very expensive wink.gif
If I can help any more (if I have helped at all!) then don't hesitate to follow up with more questions.
I'll need to digest all of that after Thanksgiving, but it is helpful. Thanks.
post #57662 of 62195
Originally Posted by jkasanic View Post
Originally Posted by jdsmoothie View Post
Nope. It's not possible on any recent model Denon or Marantz AVRs (in fact the only units it's ever been accomplised on are the Denon 5308CI ($5000) and AVP ($7500) with the upgrade costing $1000). eek.gif
Wouldn't you also consider the NAD receivers with their MDC modules in this category? I believe all units can be upgraded to XT while next year there is speculation of an MDC module to upgrade these same receivers to XT32 (although not confirmed TTBOMK...for Keith!).
TTBOMK you are right, BICEBW of course.... ;)
post #57663 of 62195
BICEBW?
post #57664 of 62195
Guessing it's a typo for bicbw..."But I could be wrong"
post #57665 of 62195
I used to be fairly well versed in decoding such but lately am seeing ones that I cannot decipher.
post #57666 of 62195
Originally Posted by Theresa View Post
BICEBW?
But I could easily be wrong.... :)
post #57667 of 62195
My left, center, and right front settings for "flat" and "audyssey" are almost identical...with a huge slope up at higher frequencies. My surrounds, heights, and wides, don't have the same curve. All the speakers are infinity Primus line. I thought it was because the fronts are actually three centers on the floor, well below the mic. I moved them to mic height however get the same curve. It's way to bright for me. Would it help if the speakers were way higher than the mic...like my other speakers? Need to tame the harshness.
post #57668 of 62195
1. What did you measure the FR with?  2. Can you post the graphs please so we can have a look. 3. Also, please describe your measuring technique - 4. what did you use to make the measurements, 5. mic position, 6. number of positions tested, 7. settings in the AVR during testing, 8. testing source material etc.
9. Why are you using three 'centre' speakers?  10. Can you post a link to the specs of the speakers? 11. When you say the speakers are 'on the floor' do you mean that literally?  12. They are not on stands - they are on the floor?  If so then they will probably sound pretty bad regardless of what Audyssey does. 13. Can you upload a photo of the room showing the speaker positions for all speakers?
Audyssey requires the tweeters to be at the same height as the mic if possible and the mic should be at ear height. If this is not possible the speakers need to be angled toward the MLP.
14. Can you confirm that you have run Audyssey in accordance with the Setup Guide, the '101' and the FAQ (all linked in my sig)? It is essential to use the proper practice wrt to mic positioning etc when running Audyssey. 15. Which AVR do you have and 16. what is the version of Audyssey you are using?
Sorry for all the questions (I have numbered them in red so you don't miss any when you reply) but without the answers it is impossible to help you.
Edit: 17. Have you tried turning Audyssey on and off and observing if the harshness is still there?
Edited by kbarnes701 - 11/24/12 at 3:23am
post #57669 of 62195
I'd guess MS has a Denon or clone, which have a graph for the (I assume) EQ changes.
I've had MEQ/XT/XT32, in that order. Going from MEQ to XT required a mic stand, but no other issues. With XT32, I have to be very careful with tweeter height matching and possibly near reflections (improved by positioning for tweeter height, but I also throw a blanket over the back of the couch.)
If MS has XT32, that could be the basic problem - in my room at least, you really need to play with it ... off say 2" could make a big difference.
post #57670 of 62195
Ah yes - good catch. I agree that mic positioning is important, but he shouldn't be getting all the harshness he describes. Let's see what he says to the other questions - but he might have a faulty mic. His massively off-axis speaker position (on the floor!) is also a prime suspect The FAQ answer on this issue isn't all that satisfactory as it is a very difficult problem to diagnose and solve from long range. I also forgot to ask him if the effect is the same with Audyssey off as with it on - if so, then it's not an Audyssey issue - he hasn't seen the post yet so I will edit that in.
a)9.   Why are my high frequencies 'bright' or 'harsh' since running Audyssey?
post #57671 of 62195
Keith, FJ....Yes, I am referring to the graph with EQ changes my 4311 shows.
Center graph is almost the same. Two reasons I am using Primus PC351's across the front is I wanted identical speakers and the screen goes from floor to ceiling. The fronts are angled up. I am using 153's for the other 8 speakers. Here is shot of the side, surround and rear placement with accompanying graph. No issues there.
You can see the right front height below and accompanying graph. Even with it way above the mic, no issue.
I use a tripod at listening height, tight clusters evenly spaced around mlp. I pretty much clear the floor of everything when running it. Also, I remove the rug in front as well...thought being I can "trick" the program into thinking the room is "brighter' than it is. MJ, from your comment maybe I should be doing the opposite and adding treatments? When I realized I could see the graphs I then raised the three fronts up about two feet...not quite at mic level. It didn't help. I have to check if the harshness is there with it off though.
post #57672 of 62195
Hi Michael - thanks for the additional information. Assuming the front speakers have a reasonable off-axis response, they should be OK even low down. My S150s are mounted low down (aimed at the MLP) and I get no harshness. On thought that occurs is wrt to the response pattern of the main speakers as they are all dedicated centre speakers from what I gather. Are these speakers purpose-designed as centre speakers and may therefore have a different axial response to 'normal' L&R speakers?  What it is about them that makes the manufacturer describe them as 'centre speakers'?  I am not sure it matters, but it would be useful to know. Best practice is for everything that is in the room for listening, to be in the room for measuring. Your room does look as thought it might be a bit 'lively' but even so, it should not cause harshness from the Audyssey calibration.
Is this the first Audyssey cal you have done with the same gear in the same room?  I am trying to see if you have ever gotten a good result and suddenly it has changed. Also, when did you buy the Denon?  Was it in the summer?  If so, see the last paragraph of the FAQ answer linked above. You may have a faulty mic.
Finally, for now, try the system with Audyssey turned off in the main menu - does it still sound harsh? We need to be sure Audyssey is actually inducing the harshness. If the harshness is there without Audyssey, then it may be the room or something with the speakers themselves.
post #57673 of 62195
Do I need to worry about the mic supplied with the 4311CI that I just ordered?
post #57674 of 62195
If by "worry", you mean what is the probability that it is defective, I think the odds are extremely low. There have not been that many owners who have reported problems that turned out to be a defective mic. And, IIRC, there have been more defective Onkyo mic's than Denon mic's, BICBW. After your first calibration, if there is a defective mic, it will reveal itself immediately.
post #57675 of 62195
Thank you for the kind reply. That's a relief!
post #57676 of 62195
@ Michaelscott73,
There is definitely something peculiar with the graph for the LR speakers. I have a Denon as well, and my calibrations always result in graphs that show a tapering off of the high frequencies, consistent with the Audyssey target curve. Having the highs increased at the top end is an indication that something is amiss. BTW, as Keith says, you should never alter a room's contents for a calibration. Moving furniture, and especially removing the rug, is a bad practice.
I am not familiar with the type of surround speakers you have, but I assume that they are not "center channel" speakers. To test if the front LR speakers are causing the issue with high frequencies, replace them temporarily with two of the surrounds placed high enough that the tweeters are at the same height as your ears, and re-run the calibration. If the HF frequency response is more normal, then you have isolated the problem, and may need to re-think your choice of front speakers.
post #57677 of 62195
I don't think so, Theresa. The reported problem, as outlined in the FAQ, was due to the extremely hot temperatures the USA enjoyed/endured this summer and the understanding was that this type of mic can be damaged if it is exposed to high temperatures for too long, as they might be, for example, when sitting in the back of a truck for a day or so, in the middle of a heatwave. I am not even sure if this is more of a theory than anything else, but certainly there was a small spate of damaged mics over the summer than one might expect to be typical. I think the chances of this affecting you are very small, and in any case, the mic for your Denon is the same as the mic for the Onkyo is it not?  (Please check the FAQ for more info on that, as I am not sure myself without checking). So if it is, and you suspect a problem, then you can interchange the mics.
d)4.   Do I have to use the mic that came with my AVR or PrePro?
post #57678 of 62195
Originally Posted by AustinJerry View Post
@ Michaelscott73,
Good call, Jerry. I am also thinking that the prime suspect so far is the use of three 'centre' speakers. I've had a look at the manufacturer's website and the centre speaker in Michael's setup is very different to the L&R speakers of the same set. Using this speaker as a Left and a Right may be the problem and your suggested test may well show it to be so. I am also interested to learn if the harshness is still present even with Audyssey switched off.
post #57679 of 62195
Yes, I went for several months hardly using my a/v system at all both because I was afraid heat might damage it and my only air conditioning was in the bedroom. I spent months sitting in the bedroom with my laptop and headphones on just because of the heat.
The mic has no model number on it.
post #57680 of 62195
FAQ UPDATE!
New Question added following user feedback:
a)13. Will Audyssey work if I am using external amplification?
post #57681 of 62195
Is the Denon mic the new 'Eiffel Tower' black one?  IIRC the serial/model number is on the little white box not the mic BICBW ;)
post #57682 of 62195
AFAIK its the EIffel Tower mic. I won't get it for a couple of weeks. The Onkyo one is the Eiffel Tower style. I doubt if I could turn up the box for the Onkyo one.
post #57683 of 62195
So with Audyssey off the sound is much smoother at reference level. I would almost agree with your assessment , however here is the graph for the center, when I raised it about two feet, but still below mic level. I use a very tight cluster...never going wider than the actual speaker. With this being said the center shouldn't have the same characteristics as the left and right. Next up is the swap with the surrounds.
post #57684 of 62195
FAQ UPDATE!
I guess it wasn't a dumb question. Thanks for the help
post #57685 of 62195
What do you mean, never going wider than the actual speaker? Your first measurement point should be on the exact center line between the left and right speakers, where you sit, and with the mic at exactly ear height. Subsequent measurements should be within 1-2 feet on either side of the MLP, in parallel with the MLP, also 12-18 inches in front of the MLP, and finally (if not too close to the back wall) 12-18 inches behind the MLP. You should take all 8 measurments. Is this approximately how you are measuring?
post #57686 of 62195
The speaker is 2 feet wide. I go from center, to right edge, to left edge, up 1 foot, left edge center right edge, the the back two locations....same as the chart for 8 locations.
post #57687 of 62195
two things...
- all of your measurements should be taken from "inside" the main speakers...
- cluster your positions closer to the "first measuring position"... keep in mind that after the first measurement, you aren't measuring "seating positions", you are merely providing audyssey with more data about your room...
post #57688 of 62195
ITYF that the two mics are interchangeable.
post #57689 of 62195
Are you putting the mic up near the speaker or are these measurements from the listening position?
post #57690 of 62195
FAQ UPDATE!
It was a good question IMO and I can see why it was asked. Also the point about the gain matching is a good one, although not directly relevant to your question. Who knows how many others might wonder the same thing and not ask?
