I have a Denon 2311ci and I run Audyssey several times before without issues. About 2 months ago we had to put a some additional furniture in our living room and I decided to re-run Audyssey. I run all 6 measurements and the analysis froze on 96%. I waited for more than 1/2 hour and I stopped it (got back to the menu). I reset the microporcessor - didn't work; I unplugged the receiver for 10+ min. and I tried again with 1 measurement and it did work! Thinking that the un-plugging fixed the issue, I re-run Audyssey with 6 measurements and it froze again on 96%... I tried more than 15 times that day with different combinations if re-setting, un-plugging and number of measurements and none of them worked... So, I called Denon and I brought the receiver for service. After it was serviced, I run 5 measurements and it froze again at 96%. One measurement didn't work either, so I reset the microprocessor and 1 measurement worked. I tried again with 5 measurements and the analysis again froze at 96%...
So, before I bring the receiver again for service, my question is: Is it possible that because of the amount of the furniture in my room that more than certain amount of measurements cause the "freezing" issue? How long is a reasonable amount of time to wait - 10 min.? 20 min.?
Thanks a lot!
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
