Featured Stories
Topics Discussed
Related Forum Threads
- First Time Sub Owner - Quick Help On Setup Last post on 1/13/13 at 4:30pm in Subwoofers, Bass, and Transducers
- Marantz AV8801 Preamp/Processor Official Owner's thread Last post on Today at 8:33 pm in Receivers, Amps, and Processors
- Onkyo TX-NR818 "official" owner's thread discussion Last post on Today at 9:05 pm in Receivers, Amps, and Processors
- I could use some advice please Last post on 3/3/10 at 6:16pm in Speakers
- Energy Owners Thread Last post on Today at 11:32 pm in Speakers
Related Articles
Audyssey FAQ and New User '101' Help & Setup Guide
Edited on 1/20/13
- Audyssey FAQ and Beginners '101' Setup Guide
Edited on 8/22/12Related Reviews
"Official" Audyssey thread (FAQ in post #1) - Page 1932
Gear mentioned in this thread:
- djbluemax1
- Trader Feedback: 0
- offline
- 1,561 Posts. Joined 10/2004
- Select All Posts By This User
Max
the FAQ doesn't talk about changing the low pass because you SHOULDN'T. Leave it max'd out -- the point is to get it out of the way because bass management is handled digitally in the processor (receiver).
The thing about raising but not lowering refers to the crossovers in the RECEIVER. That's the part you are missing
ah ok. thanks to both.
i didn't realize that the receiver could override the sub-woofer physical dial setting. so leave it at max permanently even after calibration and being used day to day. check!
- mogorf
- offline
- 3,095 Posts. Joined 5/2009
Here's another tip for Ya. Many subwoofers have separate inputs (sometimes called LFE, or maybe something else) that bypass the internal LPF (Low Pass Filter) and the phase adjustment circuitry but the gain control is still available. Refer to your sub's Manual to check out the above (or you may advise the brand/model no. for further help). Then you won't have to worry about accidental mis-adjustment, like during dust cleaning, etc. Some even put a little Scotch tape on the gain control knob to avoid same mishap.
Hope this helps.
There is no LFE input. The only things are:
Input L and R. I connected to the receiver using L. Was told its digital and wont matter which you connect to and dont need both L and R inputs, just use either one.
Speaker inputs which are not used as they speakers are hooked up to the receiver.
Phase flip switch, 0 and 180. Set to 0.
Low pass 80 to 150, now set to 150.
Volume, currently set to middle.
I will probably try to calibrate tomorrow now as kids are home.
Thanks again for the help.
Edited by aliaskary77 - 12/7/12 at 1:14pm
A bit of semantics but, your receiver cannot override anything on the subwoofer. All your receiver is doing is limiting the signal that is going to the subwoofer. The reason people suggest you leave the subwoofer crossover on the highest setting is because this gives the receiver the flexibility to control the entire signal w/o the potential of losing signal (accidentally).
- kbarnes701
- offline
- 10,416 Posts. Joined 1/2008
quick question before doing an audyssey calibration on a denon 1612 with polk 5.1 system.
I have read the FAQ few times but something still not clear to me.
When starting off, bass phase should be 0 degrees, volume about half way, and low pass (I assume is crossover) is set to max, which is 150 on my unit. (goes from 80 to 150)
I am then supposed to do the first position, then hit calculate. if need be, adjust volume and repeat to be within +-3db.
At no point does the faq talk about changing the low pass setting again. can anyone clarify if i should be doing something with that at any point please. The only thing i read is that you can raise it if i like, but not to lower it. Sounds like i am missing something in the middle.
That's right if you don't have a defeat switch on your sub set the low pass to the highest setting and always leave it there after calibration. That also applies to Audysssey once it is calibrated do not lower but you can raise. Of course in the end it is preference vs reference and how it sounds to you.
It's right to set the LPF on the sub to the highest setting (or to disable it if that is offered) but the advice to raise but not lower wrt to Audyssey is about the crossover in the AVR and has nothing to do with the physical controls on the sub. The controls on the sub should NOT be touched after running Audyssey (unless it is for the purpose of running Audyssey again with, for example, a higher or lower gain setting on the sub.
- kbarnes701
- offline
I did - it's in here - referred to as the 'gadget you need'
d)1. Do I really need to put the Audyssey mic on a tripod or stand?
- kbarnes701
- offline
It's not that it overrides it so much as you need to get it out of the way - if you have a crossover set on the sub and another in the AVR then they will not work together properly - you will in effect be using two crossovers. By defeating the XO on the sub (if it has a defeat switch) or raising it to the maximum you effectively bypass it altogether and this means you are setting the XO in the AVR, and just once.
- kbarnes701
- offline
This is the RM6750 5.1 set. The sub also says RM6750.
Yes, you have it!
- Gary J
- calculating status...
- offline
- 7,136 Posts. Joined 3/2000
A crossover means part of the signal to one speaker is sent to another speaker instead. What two speakers are involved here?
- djbluemax1
- offline
The settings you listed are correct, but just to be 100% sure, you ARE connecting the LFE out from the receiver to the L input of the sub right? Don't connect only the L out from the avr to the L input on the sub.
Max
- sullivt5
- offline
- 4 Posts. Joined 2/2012
Hi All ,
I have had my 818 for a little over a week and I need some help with my sub set up. I have a dual sub set up fed by a single amp that is all ultra 2 rated, with that being said the manual for the amp says that if I have a THX rated receiver that I need to turn the THX setting on the amp to yes this disables the gain control and boundry gain control on the amp and the receiver will control everything when I turn the U2 setting on for the sub control. The issue I am having when you run the Audyssey set up I cant set the db level for the subs because the gain control is disabled and after I run the set up my sub distance is .5 feet and have a -12.5 offset when they are about 13.5 away. If I shut the THX stuff off I get a distance of 24 feet and a -5.5 offset. I would just go with which one sounds better but I want to make sure my set up is right and I am not feeling it right now. Any ideas on how I can get it where it needs to be?
- kbarnes701
- offline
I posted this over in the Onkyo TX-NR818 thread and have not got a responce and thought I could get some help here.
Hi All ,
Odd. Audyssey usually ignores any settings in the AVR when it does its measurements. The result with the sub at 0.5 feet is clearly wrong, so there's no point pursuing that. I'd run it with the THX thing shut off on the amp and let Audyssey and the AVR take control. Distance of 24 feet and trim of -5.5 all sounds fine to me.
What is it you are not feeling? The bass? Check this out:
f)5. Since I ran Audyssey everything sounds great - but where has my bass gone?
Edited by kbarnes701 - 12/8/12 at 5:36am
- jdsmoothie
- AVS Addicted Member
- offline
- 34,437 Posts. Joined 9/2007
- kbarnes701
- offline
Ah yes, I did realise that but still gave the usual advice that Audyssey ignores the settings in the AVR :) True, but useless info in this case :) I'll strike it through on my post.
- Mike Butny
- offline
- 353 Posts. Joined 10/2004
Today I was able to only measure Front Left channel, had no time for others, but still some interesting results...
So. The picture number 1. REW sweep to HDMI in of Onkyo TX-NR818 in "Stereo" mode, taking signal from the speaker wires to the external ADC.
(REW is calibrated in advance with this loop as ADC have roll-offs at 20Hz and 20kHz by about 3dB). Audyssey mode is Movie.
The picture number 2 is the measurements done by Audyssey microphone of the same left front speaker but with my Dell Latitude E6500 mic. input (the external ADC didn't work with the mic.).
Three measurements - with the mic pointing vertically to ceiling at the height of tweeter and at the ear height (ears are above tweeters ~10cm, there is difference in responce, but not where I expected), also one measurement from the same position (arount 1m from speaker) with mic pointing directly to the tweeter, not the proper placement, but just in case, simply was interesting, what is the difference...
The speakers are MonitorAudio RX6.
Any thoughts...?
- SoundofMind
- (IMHO)
- offline
- 7,226 Posts. Joined 9/2008
Hi. I can think of two simple solutions for tonight. If using the LFX input produces exactly the level of bass you want then you're done. Don't be concerned that the sub output it is likely above reference, as when it is set to reference using the L or R input, it sounds weak to you anyway.
If on the other hand using the LFX input produces too much bass, then continue using the L or R input, simply trim up the sub ch trim in the AVR until you're happy with the sound.
- AustinJerry
- offline
- 3,335 Posts. Joined 1/2003
Searching for a reason of excessive brightness of Audyssey calibration did some measurements today. First I have discovered there is a bug in REW affecting my previous measurements, so if anyone looked at them - they are compete crap, forget about them.
Any thoughts...?
I use REW all the time to measure my audio response. To be honest, I'm not following how you are taking your REW measurements, so it is difficult to interpret your graphs. What do you mean, "...taking signal from the speaker wires to the external ADC"? And are you using the Audyssey mic with REW? This won't work very well, because there is no microphone calibration file for the Audyssey mic.
Here is the REW procedure I use. Please tell me how your procedure is different.
- I connect a mic (EMM-6, with calibration file) to a mixer (Xenyx 502), which in turn feeds a USB external soundcard (SoundBlaster X-Fi), which is connected to a laptop running REW.
- I place the mic at ear level at the MLP, with the mic facing the ceiling.
- After calibrating the mic level, I run sweeps and generate response graphs. A typical response graph (1/12 smoothing) looks like this:
Both your graph and my graph show the gentle high-frequency roll-off, which corresponds to the Audyssey target curve. BTW, forget the graph where the mic is pointed at the speaker--it is meaningless. I don't see any indication why your speakers should sound excessively bright.
Your graph looks significantly different at the lower frequencies (partly because you use a different vertical scale). Not sure why there are such large variances there. Are you using a sub?
The first graph is measuring the receiver only, not speakers. It is what Audyssey calibration done to the receiver (in Movie curve). It clearly shows why it is so bright after calibration, with Music/Flat curve it will be even worse.
The measurement with Audyssey mis is done not to get the response of speakers, but the Audyssey mic. itself as there is suspect that it is faulty. I have no other mic. at the moment to properly measure accoustical response, but even now it is clear that high frequencies are over amplified.
Yes, I am using a sub.
- AustinJerry
- offline
If you want to measure the receiver only, you need to measure the AVR's pre-out connection, not the speaker wires.
- AustinJerry
- offline
I'm just saying, if you want to measure what Audyssey is doing to the signal, you measure the pre-outs. If you want to know how the Audyssey filters affect the sound in your listening room, you measure the frequency response using a calibrated microphone at various listening spots.
If you observe that the Audyssey signal, measured at the pre-out, is excessively boosting the high frequencies, this can mean several things:
- Audyssey is compensating for a deficiency in the speakers' high-frequency output.
- Audyssey is compensating for an unusually dead listening room.
- There is something wrong with the Audyssey mic.
Only the frequency response measurement at the MLP will reveal whether the mic is bad. Just my opinion...
OR the outs, i.e. - speaker wires. As my speakers are powered by speaker outs and not pre-outs I measure them. Receiver could even have no any pre-outs, but in my case it is simply more convenient to access the speaker wires than pre-outs. If you think there is a difference - argument it.
I will do it when it arrives. Unfortunately waiting for it more than 2 weeks already
There are measurement done by some well trusted parties such as Stereophile and some others, all show those speakers have no such deficiencies in high frequencies. And I am fully satisfied with them when listening without Audyssey - the HF sounds exactly right then.
The room is very bright, concrete walls, no special treatments, very reflective at HF, so it is not my case.
This is what I suspect... But want to be sure, so asking opinions here. Would be good to hear from people who had issues with the mic. and actually measured something...
- "Official" Audyssey thread (FAQ in post #1)
Recent Discussions
- › Should I wait for Haswell? 33 seconds ago
- › Pinball Arcade - the ultimate pinball simulator! 41 seconds ago
- › Another DIY poster/marquee light-box 46 seconds ago
- › Marantz AV8801 Preamp/Processor Official Owner's thread 51 seconds ago
- › Projector hereTomorrow! 1 minute ago
- › The Official "I dont have dish or cable" anymore thread 2 minutes ago
- › Primus Cheese in 5.1! 2 minutes ago
- › HDMI Over Cat6 Issues 3 minutes ago
- › Official 2013 Sony R550A series TVs (KDL-xxR550A) --- 50", 60", and... 3 minutes ago
- › Xbox One 3 minutes ago
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
