that's fine. you're really just trying to get into the right balpark so the receiver can calibrate the sub correctly. the test noise goes high enough in frequency that any deviation from absolutely correct (within whatever the RS meter's error range is) will not make asignificant difference in the end. Plus there's no way to accurately correct with a pink noise signal anyway.
Featured Stories
Topics Discussed
Related Forum Threads
- First Time Sub Owner - Quick Help On Setup Last post on 1/13/13 at 4:30pm in Subwoofers, Bass, and Transducers
- Marantz AV8801 Preamp/Processor Official Owner's thread Last post on Today at 8:19 pm in Receivers, Amps, and Processors
- Onkyo TX-NR818 "official" owner's thread discussion Last post on Today at 1:18 pm in Receivers, Amps, and Processors
- I could use some advice please Last post on 3/3/10 at 6:16pm in Speakers
- Energy Owners Thread Last post on Today at 4:18 pm in Speakers
Related Articles
Audyssey FAQ and New User '101' Help & Setup Guide
Edited on 1/20/13
- Audyssey FAQ and Beginners '101' Setup Guide
Edited on 8/22/12Related Reviews
"Official" Audyssey thread (FAQ in post #1) - Page 1982
Gear mentioned in this thread:
- kbarnes701
- Trader Feedback: 0
- offline
- 10,399 Posts. Joined 1/2008
- Select All Posts By This User
FAQ Housekeeping
I have had confirmation from Mike Lang that the AVS 'Huddler' software will choke when a post reaches a certain length. The FAQ has almost reached that length. There is nothing that can be done, but it is possible, apparently, to hyperlink to the next post in the thread. Currently that post is owned by Jeff.
Jeff - the post is just a 'banter' one between me and you - would you, if it is possible for Mike to arrange it, be able to give your permission for that post to be transferred to my name so that I can carry on the FAQ into the next post? I am not sure Mike can transfer ownership of the post, but if he can....? I have asked him and am awaiting his response. Thanks.
- kbarnes701
- offline
AFAIK, Audyssey is 'speaker agnostic', so you should just proceed with the calibration as normal. No doubt others will chime in if this view is controversial in any way ;)
- AustinJerry
- offline
- 3,321 Posts. Joined 1/2003
This topic has been discussed extensively. I believe one of the issues is whether to hook the bass drivers in the DefTech's to the sub out connection, or to treat the entire speaker as one speaker. I am not in any way knowledgeable in this area, and would recommend the OP take this question to the Definitive Technology thread, as this is not an Audyssey question per se.
- Gary J
- calculating status...
- offline
- 7,136 Posts. Joined 3/2000
- AustinJerry
- offline
Thanks for the correction, Gary.
- jlpowell84
- offline
- 676 Posts. Joined 12/2012
Originally Posted by kbarnes701
Originally Posted by BadClams
After scanning through the FAQ, wondering if there is any guidance re: Audyssey and "Power tower" type speakers (specifically my Def Tech BP2002's)? I'm wondering if there is anything special that this setup requires for a good Audyssey calibration.
T.Y.!
I recently bought Def Tech BP8060 powered towers as well as front highs, center and surrounds, but those are a mute point for this discussion. I also bought a HSU VTF-15H subwoofer. I have been experimenting as I had these same questions. I have LFE to sub only. If I didn't have a separate subwoofer I would have hooked LFE to each tower. As far as the audyssey calibration With my current setup it was just like a normal setup, 7 speakers and a sub. Initially it set my towers at 40hz but I have bumped them to 70hz (I'm still listening, 60-80 will be my final resting place). I did this because it was taking away from my hsu sub which has enormous capabilities. The subs in the towers act as good mid bass for this setup. I was able to tell especially with a good clean strong acoustic guitar strum for setting the gain level on the tower subs. I have yet to try with just LFE to the towers. I imagine if you did this with no sub audyssey would treat them as a separate subwoofer. Just as if they were sitting in a their own enclosure. audyssey doesn't know they are in the same enclosure as the towers.
- jlpowell84
- offline
- kbarnes701
- offline
AVS help a half noob out please , this weekend i wil begin the process of setting up my speakers ( 7.1 ) and my receiver wich is a onkyo tx-nr616 for the 1st time , i know the 616 does not have the full or best audyssey but it atleast has something. I am new to audyssey and will be running a polktl1900 5.1 speaker set up http://www.polkaudio.com/products/tl1900 and the sony ss-f6000 as my two front floor standing speakers http://store.sony.com/p/SS-F6000/en/p/SSF6000 . I was on a huge budget , i know everything i am starting with is not the best but it will def be a upgrade i hope from my htib pioneer system. So any tips , settings , ect. before doing this will be great for me , i have been asking around on the forums and have gotten some great help but would just like some more advice as i am new to this . I stil have no clue as for crossover settings for sub and speakers and what it all means although a super helpful member here did give me some great advice and explained some of this to me and i appreciate that allot , just trying to get as much help as i can before i jump into this all. Thanks
I'd start by reading the Audyssey 101 linked in my sig, and then read the relevant sections of the FAQ to clarify any remaining questions in your mind. The, if you are still unsure, post here.
- batpig
- terrorist and rioter
- offline
- 21,145 Posts. Joined 2/2007
OK, since you have Def Tech powered towers as well, why not actually HELP with some advice about the original question, as opposed to simply correcting others on a meta point?
This is a specialized topic that has come up many times, so I am legitimately curious what the consensus "best practice" is from Def Tech users like yourself?
- pepar
- Wireless Member
- offline
- 23,640 Posts. Joined 7/2002
FAQ Housekeeping
Sure, I'm ok with that. If transferring isn't possible, I could delete my two posts after the FAQ leaving YOU with the next post after the FAQ.
Jeff
(Soon to be in freezing weather
)- batpig
- offline
- Gary J
- offline
- sdrucker
- offline
- 1,043 Posts. Joined 2/2006
Batpig,
I'm not sure there's a 'best practice', but there's been a fair amount of discussion on the Definitive Technology Mythos thread about how to run those speakers in general, as well as with Audyssey. I'd think that conceptually, the issue is the same, whether it's a BP tower series or the Mythos supertower line.
I'll spare you the history, but I've went down this road myself over the past two years, going from a Mythos ST setup without external subs (and using LFE input from the speakers to my AVR), to my current setup (Mythos ST on speaker wire only, standalone dual ULS-15 subs handling sub duties with discrete sub output from an Audyssey XT32+Pro equipped Denon 4311). After experimentation, what I've found works best is:
a) First, verifying that the 'powered' and 'non-powered' section of each powered speaker are level-matched, so that the speaker is "full range" to start
b) Running the powered speakers on speaker wire ONLY, and letting actual subs handle LFE and redirected bass
c) Conducting an Audyssey run, and choosing a crossover in the 60 or 80 Hz region. The more capable the subs, the higher the crossover can be
d) Using external measuring equipment (e.g. OmniMic or REW), run a sine sweep with at least 1/12 smoothing, and use the 'distance tweak' to determine the optimal mains/sub crossover splice that gives the flattest response
That's the short version. Where it made a difference was that I'd see a cliff in the crossover of each Mythos St speaker+sub if I didn't do the within speaker 'level matching' when I did post-Audyssey assessment with my OmniMic. I finally figured out that the discrepancy in volume between the 'sub' and 'non-sub' sections of my towers played some role when the distance tweak appeared to be less than optimal.
If anyone wants details about how to try the level matching, here's some places to start:
http://www.avsforum.com/t/1100995/definitive-technology-mythos-series-thread/4800#post_22311549
http://www.avsforum.com/t/1100995/definitive-technology-mythos-series-thread/4830#post_22318391
The only downside to the pre-Audyssey 'level-matching' is that I found that I had to do some LFE cable swapping, disconnecting my real subs, and then connecting the LFE input of each speaker (via LFE cable) to a sub input. I then ran test tones to match that 'sub' to approximately 75 db with the speaker onboard sub trim. Disconnect LFE input, then rinse and repeat on the speaker (or speakers, if you have a powered center as well like I do). Finally, remember to reconnect the real subs prior to running Audyssey!
- batpig
- offline
So then you advocate simply using speaker wire and ignoring the LFE input? There are some complications as it's not "like any other speaker" as Stuart discusses in his helpful post. You have to be careful to make sure the powered sub portion is well integrated with the rest of the speaker no? Somebody could end up with a poor result if they aren't aware of these contingencies.
Hopefully Stuart's response is helpful to the OP.
- kbarnes701
- offline
FAQ Housekeeping
Jeff
Thanks Jeff. If it is possible Mike Lang may be in touch for your consent. If you deleted the post after mine, wouldn’t my next post just go to the end of the thread? How would I 'fill in' the gap?
WRT to freezing weather, welcome to the real world, mate! :)
- kbarnes701
- offline
- batpig
- offline
- pepar
- Wireless Member
- offline
Keith, the first and second posts after the FAQ are mine. The third is yours. With mine deleted, you own the post just after the FAQ. I am working from an iPhone, so I might have incorrectly viewed stud thread.
Jeff
- Theresa
- offline
- 2,291 Posts. Joined 11/2010
Brought over from Emotiva thread.
Audyssey finds the F3 of the speaker under test and reports it to the AVR. That's all. It's the AVR that then decides which XO to set based on that info. At no time does Audyssey 'set' the XO in the AVR. It seems like it's splitting hairs, but it is an important distinction because AVR manufacturers make the XO choice not Audyssey. This has resulted in some bizarre settings of 'Large' in Onkyos in the past, for example. HST, if Audyssey detects the F3 at 120/140Hz, the AVR will make an intelligent choice and will select the nearest XO it can to those F3s.
Well, I applied a peak filter boosting the range 4db from 40Hz to 160Hz and reran Audyssey. The crossover was then set (automatically) to 40Hz. I then increased the crossover frequency to 80Hz. I removed the peak filter afterwards and everything sounds good, even though I messed with the miniDSP filters after running Audyssey. I know I'm probably being a heretic by doing this but what works works re. sounds good, even if its not optimal.
For all intents and purposes, it's Audyssey that determines where the crossover should be according to where the -3 db point is, at least that's how it should work. I am familiar with the various versions of the mic and whether it's interchangeable. I do still have the mic from my Onkyo and used it and it resulted in a 120Hz crossover. Whats odd is that Omnimic shows the center to be flat to below 60Hz and yet the crossover gets set at either 120Hz or 140Hz.
You're much more experienced in all things speakers than me, but just in case it helps:-
Have you used the Omnimic to test all the microphone positions that are used when performing the Audyssey calibration? Could there be dips/nulls that only show up away from the MLP (where Omnimic is used?) that might be affecting the overall frequency response enough to lead to the higher crossover? Have you tried running Audyssey in just one position to see if it agrees with the Omnimic results?
Just thoughts, regards Mike.
- kbarnes701
- offline
- kbarnes701
- offline
Ah yes - thanks Jeff. I misunderstood you. That would be most gentlemanly of you...
- Theresa
- offline
Good points. No I did the Omnimic sweeps with the microphone in just one position assuming that the Audyssey measurement determined the 3db down point only from the first measurement. Got it to give me a 40Hz crossover by using a miniDSP to institute a 4db shelf filter between 40Hz and 160Hz. Then I raised the crossover frequency to 80Hz. Next time I run sweeps I'll use several locations to see if that reveals any dips around 150Hz. All is well now even though I'm an Audyssey heretic.
Edited by Theresa - 1/25/13 at 12:17pm
- kbarnes701
- offline
If it sounds good, it is good! Mike's suggestion is good too. And sometimes, the heretics are right you know :)
- jlpowell84
- offline
Yes just speaker wire to powered towers and LFE to sub. I have Def Tech 8060 powered towers and hsu sub. The towers have built in crossovers at 150-200 (thought it was weird DT couldn't give exact number). So right now as I am toying with the sound (audyssey initially set towers at 40) I have them at 70 which leaves the subs in the towers essentially as mid bass from 70-150/200. And hsu as 70 and below. Now if I had no external sub then I would LFE to towers and set AVR to 'no sub,' or whatever it's called on your AVR. Am I wrong here?
- batpig
- offline
- "Official" Audyssey thread (FAQ in post #1)
Recent Discussions
- › Help me build my home theatre!! Pleasee (I'm new here) 25 seconds ago
- › Latest Ceton InfiniTV 6 Info Thread 3 minutes ago
- › #### The ULTIMATE Bass Demo Disc #### 3 minutes ago
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 4 minutes ago
- › Doctor Who Season 7 Premiere on BBC America 5 minutes ago
- › Official Panasonic TC-PxxST60 Series thread 11 minutes ago
- › Official Samsung UNxxF8000 Owners Thread 13 minutes ago
- › Planning to rebuild my 20TB WHS Flexraid server: Information... 14 minutes ago
- › $1200 sub 17 minutes ago
- › Magnavox 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576,... 17 minutes ago
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
