I have a Denon 2808. Anyone know if changeing the main crossover point affects the Auddyssey tune or does it self adjust everything, i.e. if it crossover over the mains at 150hz, and I change it to 120hz, will to cause a lot of issues? Will it readjust the Audyssey and Audyssey flat EQ values? Just trying to figure out what I can and can't adjust without affect the Audyssey tune much.
Changing the XOs manually does not adversely affect the Audyssey calibration. However you are advised to adjust them in an upwards direction only. This FAQ answer has the skinny on that:
c)4. Is it OK to change the Crossovers from Audyssey's recommendation?
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
Must be hard to scratch the itch when you have already taken your system to such high levels.
It ended up topping out as a 9ch DSX setup, with the guy's older S-100B's as wide speakers, and in-wall M&K surrounds along with dual M&K subs. Pretty rockin' setup that could hit reference levels without breaking a sweat.
