Featured Stories
Topics Discussed
Related Forum Threads
- First Time Sub Owner - Quick Help On Setup Last post on 1/13/13 at 4:30pm in Subwoofers, Bass, and Transducers
- Marantz AV8801 Preamp/Processor Official Owner's thread Last post on Today at 4:56 pm in Receivers, Amps, and Processors
- Onkyo TX-NR818 "official" owner's thread discussion Last post on Today at 5:30 pm in Receivers, Amps, and Processors
- I could use some advice please Last post on 3/3/10 at 6:16pm in Speakers
- Energy Owners Thread Last post on Today at 5:08 pm in Speakers
Related Articles
Audyssey FAQ and New User '101' Help & Setup Guide
Edited on 1/20/13
- Audyssey FAQ and Beginners '101' Setup Guide
Edited on 8/22/12Related Reviews
"Official" Audyssey thread (FAQ in post #1) - Page 1998
Gear mentioned in this thread:
If you re-read Igor's posting, the measurement is taken from the pre-outs. By toggling Audyssey off and on, you can see exactly what is happening without the influence of the listening room. For example, here is a pre-out measurement of my left speaker, one without Audyssey and one with XT32 applied.
In this example, you see Audyssey correction down all the way to 20Hz because Audyssey sets my speakers to "Large", i.e. the F3 point is probably below 30Hz. (Actually 30Hz, +/- 3dB on axis, according to the manufacturer)
Jerry, how exactly do you take a pre-out measurement? I'm curious to figure out why Audyssey XT32 is setting the crossovers of my surrounds to 40Hz? I suppose it could be room effects but I guess I would've expected the opposite (i.e. a higher crossover setting)?
- AustinJerry
- Trader Feedback: 0
- offline
- 3,350 Posts. Joined 1/2003
- Select All Posts By This User
Well, I haven't tried this since we started experimenting with USB mics for REW. With the legacy REW setup, you would connect an audio cable from the Pre-out connection on the back of the AVR and connect it to the Input side of the sound card in place of the mic.
For the new REW setup, I don't know how this would work. I'll post a question on HTS.
- pbarach
- offline
- 1,982 Posts. Joined 7/2005
- jmschnur
- offline
- 2,626 Posts. Joined 12/2001
Unfortunately it seems the Audyssey's point of view has changed at some point (silently) and now they think it should correct the slope under F3 to achieve 4th order roll off there. It still doen't explain my case as it still boosts considerably more than is needed to get 4th order roll-off at the detected frequency. And once they start doing the correction below F3 they should take into account the original natural roll off also when estimating F3 as any room mode extending the F3 down the frequency will require boosting heavily everything below it to build a roll off from lower frequency than the natural one.
I understand your feelings after you had so mush experience with Audyssey and it newer happened before, it might sound to you anecdotal, but it is same feeling for me, when I see the measurements, the contradiction with a FAQ, which claims are totally logical and rational, while the measurements are totally out of place. It is completely repeatable on any of my speakers detected starting from 40Hz for fronts, ending at 60Hz for surrounds, or even 120Hz when the bi-pole surrounds are free-standing and not on their usual places. I asked to measure a new owner of 818 on russian forum to measure his pre-outs to compare, his unit bought half a year later than mine, in different country (mine was bought is Germany), and he confirmed he also have this one-and-a-half octave +10dB boost. The only similarity between our setups is the room sizes - 3m*5.6m (sorry I am bad in American units) - quite common room size here and our walls are from concrete. So, after that it really feels anecdotal to me there are so many admiring reports about SQ of the 818, especially with XT32, and nobody notice the increased distortion... I can believe that it is not noticeable to everyone, but really there should be more users who are affected and disappointed as it reduces the headroom of the amps/speakers by 10dB basically in many setups, and the IM distortion is also bigger, as high frequencies are modulated by higher amplitude low frequency signal... If I didn't hear this myself I wouldn't start investigating it further and finally get to those measurements that pretty much confirm everything I hear with my ears.
Yes, this is exactly what I expected. The wording could be something like "There is an evidence that Audyssey XT32 can boost bellow F3, sometimes very heavily (+10dB), that might create problems for some users limiting headroom of their setups. The problem is only confirmed by some user measurements of Onkyo TX-NR818 at the moment, but there was no any evidence if it can happen to other receivers with XT32. The problem is happening for satellite channels and doesn't happen to the subwoofer channel and not related to the old normalization bug." I remember there also was a footnote about normalization bug in sub channel somewhere in FAQ, at that time many users here complained... Surely you can correct my crappy English wording
What is your first language Igor? In English a lie is the deliberate telling of the opposite of the truth. In the case we are discussing, it would perhaps be an 'error' or a 'mistake'.No offence taken BTW - I know how difficult it can be to have in-depth technical discussions in a foreign language.
And... it is not error or mistake either, I believe it is the right way, how it should work
But it just appears that it works differently in real life, so, while it is right it is not true. At least sometimes, or with some specific receivers... There is no enough statistics to tell precisely when and where, the only we can tell at the moment is that it works differently on Onkyo 818 that may lead to inferior calibration.You may be the only one who cares about it, but do others acknowledge that it exists? Do Onkyo or Audyssey say it exists?
After some talk with Chris at AskAudyssey here, he replied "We have been unable to reproduce this." and AskAudyssey is closed for comments now
But the fact is - the first independent person agreed to measure his 818 in his not so ideal room was able to reproduce this immediately...
- kbarnes701
- offline
- 10,427 Posts. Joined 1/2008
Igor - thanks for the detailed explanation and for your continuing efforts to get to the bottom of the problem you describe. Also, thank you for the suggested wording for a footnote in the FAQ. I will add such a footnote later in connection with the 818, with the caveat that Audyssey say they cannot reproduce the problem, but also with the comment that you are still trying to pursue them for an answer.
- SoundofMind
- (IMHO)
- offline
- 7,228 Posts. Joined 9/2008
Lots more great info in the Pro Kit FAQ that Keith assembled in the Pro Kit thread (FAQ also linked in his sig).
edit-corrected
Edited by SoundofMind - 2/16/13 at 9:04am
- pepar
- Wireless Member
- offline
- 23,650 Posts. Joined 7/2002
Jeff
- djbluemax1
- offline
- 1,562 Posts. Joined 10/2004
If there are many peaks in the FR, Audyssey may need to apply a lot of cuts to EQ the FR, and in order to normalize the levels back to the calibrated levels, the normalization is applied with a boost across the spectrum and occasionally results in up to a 10db boost below the F3, which can bottom out the subs.
Max
I believe the issue Igor is talking about is the level normalization. This has been discussed and documented in this thread and occurs only under specific circumstances.
Max
It's probably worth stressing that normalization and equalization are independent: norm sets the intended dB level (which eq'ing respects), and many peaks "fool" the norm process into setting too high a level.
Your belief is wrong. It is not normalization, as the frequency response drops back down under this one-and-a-half octave under F3. Also if you think small untreated room with concrete walls at home is something very specific - you are wrong, only a small fraction of those receivers are used in large rooms with proper treatments, and nowhere in the docs it is mentioned the calibration can only work correctly in properly treated rooms, quite the contrary to that. That one problem with subwoofers and normalization also was quite frequent. Only small portion was complaining just because most are not measuring their systems. This normalization problem for subwoofer channel was solved and fixed on that receivers long time ago, and I verified it is not present on my setup with my subwoofer.
The problem I am describing is with satellite channels, it leads basically to the same sonic problems, and more as it is with full-range channel and bottoming out / distorting also affects how high frequencies sound, but the reason of this boost is different. I am too was thinking about returning of normalization problem but to main channels, but measurements on lower frequencies show it is not the case.
- djbluemax1
- offline
If that's the case, Audyssey would see the cuts in that region and boost everything to normalize. This could explain why the region below 50Hz 'appears' to have been boosted, because it is un'EQd as it is below the detected F3 and thus has no cut applied, but the normalization boost has increased their levels relatively.
If that's a pre-out graph, it looks similar to the pre-out graphs of systems suffering the normalization boost below F3 problem.
Keep us posted on what Audyssey or Onkyo has to say.
Max
Whatever it is, the word 'appears' is not right there as it tries to excuse this boost, when there could be no excuses for it. The way how it was treated with normalization of sub channel - i.e. the fix was made to the firmwares of affected units to take normalization process under control so it doen't cause the boost was the right solution to the problem from which all won. Now we have another problem, but again with the effect of heavy boosting under F3, seems Audyssey is not learning from their mistakes
Also, if you think this +10dB is the base level to what EQ cuts/boosts was applied then try to point to something above F3 in my graph that wasn't cut... There will be nothing, obviously.
- djbluemax1
- offline
Whatever the case may be, I've said my piece. Feel free to rail away.
Max
- pepar
- Wireless Member
- offline
- AustinJerry
- offline
- kbarnes701
- offline
Igor - I have added a Technical Note to the FAQ answer we discussed above, using your wording as the basis.
c)2. Why do I often see advice to raise the Crossovers to 80Hz?
- kbarnes701
- offline
- kbarnes701
- offline
You are welcome. Thanks for bringing the issue to our attention.
I forgot to credit you with raising the issue - I have done so now at the end of the Technical Note.
This quote is from Audyssey Zendesk . I about fell off my couch when I saw this quote. He also says that your sub volume should be turned up to 50% and should only be turned down if you get a -12 level on your sub. He suggest keeping your volume on your sub the same, even if you get a -11db level on the sub. So, is the +/-3db subwoofer level a myth?
- Selden Ball
- offline
- 4,390 Posts. Joined 1/2001
- Mike Butny
- offline
- 353 Posts. Joined 10/2004
- kbarnes701
- offline
The Technical Note in this FAQ answer has some additional insights:
f)3. How do I set the controls on my subwoofer before running MultEQ?
- "Official" Audyssey thread (FAQ in post #1)
Recent Discussions
- › GoldenEar Technologies Anticipation Thread 2 minutes ago
- › Software-based subharmonic synthesizers? 4 minutes ago
- › Mini Split / HVAC advice 4 minutes ago
- › The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread 6 minutes ago
- › NE Spring Speaker Shootout results thread - April 13, 2013 6 minutes ago
- › Higher end avr vs lower end avr. 8 minutes ago
- › Just wanted to introduce myself and show you my Media room. 12 minutes ago
- › Energy Take Classic 5.1 for $299 12 minutes ago
- › Pioneer Elite VSX-42 Owner's Thread 13 minutes ago
- › Hey guys...we need a little rallying here... 15 minutes ago
Recent Reviews
- › VIZIO 55 inch Class LED - M3D550KDE by indept
- › Optoma GT700 3D Game Time Projector by paul65000
- › InFocus X1A DLP Multimedia Video Projector by coastercard
- › BenQ W1070 1080P 3D Projector by arjjr
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
