I thought u adjust the volume control until it read 75dbs and then continue with the rest of the calibration, I had to bypass the LFE input on my sub ( using the LFE input bypasses all controls ) and I would not have a way to adjust the volume on the sub so I use the left or right input and the volume control is set to 1.5 out of 12 to reach 75dbs and after calibration my sub trims are at -3.5. I would assume if I adjusted the sub volume control to 4-5 then my trims would be around -7 or -9 so as long as your not at -12 it really should not matter, but then again I could be wrong.
-3.5dB is perfect for the sub trims. It is high enough to ensure that auto-on works properly if your sub has it and you use it and low enough to enable you to turn the trim up a little if you prefer a 'hotter' bass. It is also very unlikely, at that level, to clip the input of your sub amp.
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
) Here is a picture of my setup, and it should give you an idea of the several placement constraints I am dealing with. The panorama shot makes the wall behind the TV look curved, but it is absolutely flat. As you can see, there is no room to place the sub to the left of the TV near the window on the top wall, without it looking like an awkward big box left around, and the sub needs at least 6" clearance from the wall
More to follow soon. Thanks for your help in getting things setup right.
