Featured Stories
Topics Discussed
Related Forum Threads
- First Time Sub Owner - Quick Help On Setup Last post on 1/13/13 at 4:30pm in Subwoofers, Bass, and Transducers
- Marantz AV8801 Preamp/Processor Official Owner's thread Last post on Today at 7:35 am in Receivers, Amps, and Processors
- Onkyo TX-NR818 "official" owner's thread discussion Last post on Today at 4:03 am in Receivers, Amps, and Processors
- I could use some advice please Last post on 3/3/10 at 6:16pm in Speakers
- Energy Owners Thread Last post on Today at 6:36 am in Speakers
Related Articles
Audyssey FAQ and New User '101' Help & Setup Guide
Edited on 1/20/13
- Audyssey FAQ and Beginners '101' Setup Guide
Edited on 8/22/12Related Reviews
"Official" Audyssey thread (FAQ in post #1) - Page 2005
Gear mentioned in this thread:
- nezff
- Trader Feedback: 0
- offline
- 3,927 Posts. Joined 1/2007
- Select All Posts By This User
Im coming from a Onkyo 5508 to the Denon 4520CI. Like I said, have run multiple calibrations with xt32 without ever seeing this error before.
I’d agree with you in general SoM, but the OP has posted that the difference came about only as a result of using the boom stand instead of the tripod. He mentions no other setup changes. There may be some small differences in mic placement, but by the same token that one can argue that stand vs tripod cannot make 'dramatic' differences, so one can argue that small differences in mic placement cannot either. The OP describes the difference as 'dramatic' and this is of course an entirely subjective term and I would normally raise an eyebrow at it too. But when he also says that in the prior calibration he needed subtitles to understand certain dialogue and now he does not, then I'd say that this falls into the 'dramatic difference' camp
It is possible that the tripod was being badly used - indeed this is the main problem with using a tripod: it is not designed for the purpose under discussion so misuse is easy. And it is possible that the boom mic stand can be misused too, but it less likely to be so. And because a mic stand has been designed to hold a mic, its designers have taken steps to ensure that it does this without introducing problems caused by vibrations, mic mounting and so on. For this reason, all boom stands are essentially similar in design and do not have huge, thick legs like some tripods do, or large reflective heads under the mic, like some tripods do. I can change a tyre on my road bike using two spoons. Usually this would work. Sometimes it will rip the inner tube. A set of tyre levers costs next to nothing and gives a perfect result every time. Why would I defend the use of spoons? Yes, they can do the job. After a fashion. Ans imperfectly sometimes. But really...
It seems, as as often been so in the case of some members' recent posts, that a large mountain is being made out of a very small molehill. The only sensible advice is that one should always use a mic stand for best results if possible. A tripod can be a useful makeshift device but it is not the proper device to use. By using a mic stand one eliminates yet another variable and this can only be good.
And, for most of us, they cost 20 bucks! What is there to even discuss, really?
Ok! I'll byte
I ordered a boom mic stand and the attachment as well and I'll post my findings when I run my calibration again, being I have what I consider a good one this should be interesting, and to be completely honest I have sever case of the "tweaks "and I hear its spread like wild fire through the Audyssey thread but its to late for me save yourself
Besides my OCD wont leave me alone
- kbarnes701
- offline
- 10,416 Posts. Joined 1/2008
I noticed something very unusual. This has been discussed and discussed. I have run Audyssey XT32 multiple times with my Onkyo and never got this error. I also ran my first calibration with the Denon the other day and not received this error either. I got a phase error on my center channel. Im assuming it is the room tricking Audyssey, mainly because all my other speakers are all identical in xover build. None of my other speakers exhibiting this error on first measurement.
Odd - but I suspect you can safely ignore it if you are sure there is no basis for it:
b)1. Why is Audyssey reporting that my speakers are out of phase?
- kbarnes701
- offline
Ok! I'll byte
:) The worst that can happen is that there is no audible difference but at least you will find it much easier to take the measurements.
You also ordered the little gizmo you need to attach the Audyssey mic to the stand, right?
Use this to attach your Audyssey mic to your stand
EDIT: Yes, I see you did. Sorry - failed to spot it in your post first time around.
EDIT 2: If you have a great cal ATM, I’d suggest you save it before re-running Audyssey. Just a thought.
Edited by kbarnes701 - 2/25/13 at 1:39pm
The worst that can happen is that there is no audible difference but at least you will find it much easier to take the measurements. You also ordered the little gizmo you need to attach the Audyssey mic to the stand, right?
Yeah! I got the gizmo as well any tips for the MLP use the stand from behind or side or front?
- JasonT35
- offline
- 43 Posts. Joined 12/2008
Any tips?
- CheYC
- offline
- 184 Posts. Joined 1/2008
http://www.avsforum.com/t/1409431/the-official-denon-avr-xx13-model-owners-thread-faq/5760#post_23010262- Selden Ball
- offline
- 4,381 Posts. Joined 1/2001
I guess I'm having trouble understanding where to place the boom mic stand. If I place it in front of the couch, it's in the way of the l/c/r. If I put it behind the couch it's in the way of the side and rear surrounds. I can't put it off to the side due to furniture and the fact that the boom won't reach.
Any tips?
Boom mic stands are very thin and don't cause any appreciable calibration problems. It's not like they're constructed of large foam blocks like sofa cushions.
- djbluemax1
- offline
- 1,561 Posts. Joined 10/2004
Any tips?
The low profile stand allows the main body of the stand to be out of the way of all speakers (unless perhaps, if your center channel is sitting right on the floor).
Max
- JasonT35
- offline
I understand but I have read it's important that the boom does not get in the path of the speakers and the mic
- electricmanscott
- offline
- 155 Posts. Joined 2/2004
- Gary J
- calculating status...
- offline
- 7,136 Posts. Joined 3/2000
- bsoko2
- Trader Feedback: +2
- offline
- 4,198 Posts. Joined 4/2007
Parts Express also carry mic tripods, stands and whatyever else you need in that area. http://www.parts-express.com/cat/microphone-stands-booms/742
- kbarnes701
- offline
If you can set up the stand behind the seats then that is the best way to do it. The aim is to keep the stand from getting between the mic and any speaker (tweeter especially).
- djbluemax1
- offline
A) if you have rear surrounds, a regular mic stand behind the couch will potentially get in the way and/or be a potential source for reflections
B) the boom likely won't extend far enough to take the forward measurements in the conventional mic pattern.
The low profile mic stand solves the issue by having the main body much lower and out of the way, with the boom extended upwards to place the mic in position. It easily positions the mic at ear height in the MLP without getting in the way of any of the speakers, and can easily placed for all the other measurements as well.
Spoons and tire levers.
Max
- nezff
- offline
I checked the center channel with a multimeter set to continuity to make sure my speaker cable was shorting. I know that all my speakers have the same xover design and wiring. What is weird is that none of the other speakers are giving me this issue. I got a continuity tone when I touched the positive and negative speaker terminals, which tells me the xovers are wired this way. Im just assuming reflections on the center channels is the problem. It is inside of a cabinet which might cause the Denon to pick this up. Weird that I have run multiple calibrations with the 5508 and never go this error.
hmm, the fact that all your speakers are in the negative range and that your center is the only exception to this (it being in the positive range), we can only deduce from this that the audessy is compensating for a non-efficient center speaker (the least sensitive speaker among all your speakers). there may also be other factors (such as defective or out of phase/wrong polarity) involved that renders your center speaker under power (as evidenced by it being in the positive range compared to the rest). of course, you can always raise the center channel (or any channel) volume thru your avr. i know, i know it is frustrating when our aim is to realign all our speakers so they don't drown each other.
my center speaker's highest range is -8 even after repeated calibration. right now (after my last calibration), it is -11. but i don't have any problem with low center channel dialogue (my center speaker is rated at up to 500 watts). it keeps up with the rest of my system (main channels are huge--100 lbs each--as you can see, my main channel range are in the -12 and -11 which is not that far from my center). the rest of my system are all in the negatives (see attached picture) except for the sub which i carefully calibrated so it is in the middle range (0). thanks.
DSC_8956.JPG 1391k .JPG file
Edited by beat1 - 2/25/13 at 10:10pm
- kbarnes701
- offline
Max
Yes good point - not having surround speakers, I forget that many others do. I keep meaning to get a low profile stand - must add it to my to-do.
- kbarnes701
- offline
If the system sounds good after calibration, I wouldn't sweat it.
- SoundofMind
- (IMHO)
- offline
- 7,226 Posts. Joined 9/2008
I guess I'm having trouble understanding where to place the boom mic stand. If I place it in front of the couch, it's in the way of the l/c/r. If I put it behind the couch it's in the way of the side and rear surrounds. I can't put it off to the side due to furniture and the fact that the boom won't reach. Any tips?
Yup like I mentioned about a page ago, this one
http://www.amazon.com/Stage-Rocker-Hamilton-SR610121B-Lo-Profile/dp/B0087UPZ1Y/ref=sr_1_1?ie=UTF8&qid=1361872499&sr=8-1&keywords=low+profile+mic+stand
Edited by SoundofMind - 2/26/13 at 8:28am
- djbluemax1
- offline
The reason I emphasized the 'IF' is because I've seen several low profile stands where the boom doesn't extend very far. They're only made for mic'ing kick drums.
This is the one I have
http://www.musiciansfriend.com/accessories/dr-pro-dr259-ms1500bk-low-profile-mic-boom-stand
As can be seen in the photo, the boom has 3 sections, allowing it to be extended long enough to place the mic where your ears would be at the MLP, with the base/body sitting on the ground in front of the seat. With some of the low profile mics that can't extend far enough, placing the stand on the ground in front of the seat would only get the mic to the bellybutton of a person in the seat. As I said though, if you personally own or have used the stands in your links and have confirmed that they can extend far enough, they would be a GREAT buy. ***edited to add* Never mind. The stands you linked to are EXACTLY what I described as NOT to get. I read the description and the boom is not extendable and is only 15.75" long. Between that and the fact that the base has a maximum height of 17.75" means it would only reach the bellybutton of a very fat person in the seat if the stand was placed on the ground. No way it will reach ear height unless it's placed on the seat itself.
The Dr Pro DR259 stand I have (and provided a link to) has a height range of 9-17" and a boom range of 19" - 31".
Max
P.S. Not sure about the quality, but this stand at this price appears to be a steal.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=233-020
Height range of 19.5" - 27.5" and a boom range of 17.75" - 32.5". The dimensions are even better than the one I have as the extra height allows for seating with thicker cushions AND it's under $20 vs ~$50.
Edited by djbluemax1 - 2/26/13 at 3:57am
If it isn't a glitch, then I would be most curious to know whether DSX2 has taken up more of a Neo:X direction or not as to how it interprets the sound. If it is still more or less conceived as an ambience generator but this time starting from a stereo source then I'm not that interested either way...
Max
I bought a stand (similar to the Talent) at first due to price. After noticing the boom arm drooping over time due to a poor design for clamping the pivot point, I bought the DR259 per Max's recommendation. Let's just say I've only got one low profile stand now...the other went in the garbage! There is still some merit to the old adage you get what you pay for!
- batpig
- terrorist and rioter
- offline
- 21,184 Posts. Joined 2/2007
Didn't someone (Markus?) find that the newer Onkyos do NOT EVER report polarity errors? I seem to remember people intentionally flipping the speaker wire polarity and the Onks still didn't report an error.
- SoundofMind
- (IMHO)
- offline
Excellent point. The models you link to are the right way to go. I edited my post.
Of course if someone already has a full-size stand they may well be able to mod it like I did to the Pro kit mic stand. Hacksaw and file shortened the inner vertical tube.
- batpig
- offline
UPDATE: I think it was joehonest, Markus just confirmed it. I did some searching and found a link to this Ask Audyssey thread where Chris confirmed that Onkyo dropped the polarity check: https://audyssey.zendesk.com/entries/270385-speaker-polarity
So, nezff, the reason you didn't get it with the Onkyo and now get it with the Denon is that Onkyo dropped the feature!
- asere
- offline
- 501 Posts. Joined 12/2011
- "Official" Audyssey thread (FAQ in post #1)
Recent Discussions
- › Calling all Polkies:Official Polk thread 13 seconds ago
- › Official Epson Problem Thread 14 seconds ago
- › Which display wins the shootout? Let's have some fun. Make your... 25 seconds ago
- › *Official* Pioneer SC-1522 9.2 Network ready AV receiver owners thread 48 seconds ago
- › Titan 1080P 3D Dual Ultra Thread 2 minutes ago
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 2 minutes ago
- › Official Vizio M-Series Razor Mxx1i thread 3 minutes ago
- › The Official AVS TiVo "Series4" Premiere topic 3 minutes ago
- › I need help selecting best material for my setup. 4 minutes ago
- › The *** Official Marantz NR1604 *** Owners Thread 4 minutes ago
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
