AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #1)
"Official" Audyssey thread (FAQ in post #1) - Page 202
post #6031 of 62221
Chris,
In another thread on the Subwoofer Forum, there is a discussion about the "Equal Loudness Curve(s)). One poster stated that the Equal Loudness Curves are "irrelevant" in sound reproduction:
I hate to keep repeating myself, but it seems that the obvious escapes most everyone where these =loudness curves are concerned.
First, those curves are to 20Hz. I'm sure 1956 was a great year for playback hardware that offered a clean 20Hz at 130dB, never mind lower frequencies.
If you're a live venue sound mixer, the =loudness curves have value in properly adjusting the in-house FR of the PA. If you're a sound mixer of recorded music or movie sound tracks, the =loudness curves have value in adjusting the relative levels of various events by frequency.
If you're talking instead of reproduction of recorded source in a home environment, the =loudness curves are irrelevant.
A flat in-room FR is all that's required.
Bosso
To which, I then asked:
"If that's the case, then what does Audyssey's Dynamic Loudness and Dynamic EQ do?"
The reply:
Apparently, Dynamic Volume acts as a sort of compressor/expander to equalize the disparity in volume between a TV program and the commercials. It also is designed to act in concert with its other enhancement programs to attempt to make a poor playback system sound less annoying.
It's said to be based on terabytes of data involving people changing the volume by remote control, blah, blah.
The words 'TVs', 'commercials', 'HTIB' should be a dead giveaway that it's a mass market approach and has little to do with a capable playback system.
Dynamic EQ is a loudness button, on-the-fly. It distorts the FR for very low volume listening. Again, this is a mass market gadget aimed at poor playback systems. It's a variation on a theme that's as old as audio.
What I'm talking about is the fact that recorded sound has the =loudness curve built in, based on an average listening level of 75-85dB. If your listening level varies from that, adjustments may be made accordingly, which Mr. Holman is attempting to do for you through software.
One most certainly does not have to boost 20Hz by 40dB when watching a movie or listening to music. I think that should be painfully obvious, but the subject just keeps popping up.
Bosso
http://www.avsforum.com/avs-vb/showt...6#post14510086
I am sure that Dynamic Volume and Dynamic EQ are much more sophisticated than Booso is giving them credit for. However, I don't have any experience with either, (my Onkyo 885 doesn't have them.) Since I don't have the background to discuss these features intelligently, I would like to bring that discussion over here.
Do DV and DEQ use the Fletcher/Munson Curve, the Robinson-Dadson Curve, ISO Standard 226 or some other "in-house" Equal Loudness Curve to compensate for volume and FR? If it's an "in-house" curve, how did you determine the curve you use?
Craig
post #6032 of 62221
OK, I am on 61st page of this thread, and probably it will take me another week to read all. Meanwhile I would like to get some advice.
My setup:
AVR-5308ci.
Speakers: Front Paradigm Studio 100 V.4, 44 Hz - 22 kHz
Center Paradigm Studio CC690, 53 Hz – 20 kHz
Surround Paradigm Studio ADP590, 85 – 20 kHz
SW Paradigm PDR12.
I run Audissey calibrations several times and got mixed results.
Front and Center Speakers found as Large as crossover set to 40Hz,
Surround - 80Hz.
All distances found correctly, but SW.
My front speakers are 13,3 and 13.2 feet, Center 12.6 but SW shows 24.1 feet.It should be about 13 feet as it close to the Right Speaker.
ON SW I have 2 knobs: Crossover and Sensitivity. I put crossover around 100HZ and hope that Denon will adjust it properly where it supposed to be.
Sencitivity set about 1/2 scale gives me 24 feet on SW.
When knob adjusted to MAX - I got 7.7 feet on SW distance and sound pretty boomy with some delay.
Tried decrease it slightly and got 23 feet.
Denon SW Level check shows "-12.5db"
What's the proper way to got SW adjustment?
As far I undestand Audissey doesn't care how I did setup for the speakers.
So I finished Audissey, set up SW distance manually to 13 feet, changed Front and Center speakers to small, crossover to 80Hz for the front. Should I go and change SW level from "-12db" to "0" ?
If any Manual adjustment done, will it overight Audissey room corrections parameters?
Thank you
post #6033 of 62221
Originally Posted by audyssey View Post
Hi JJ,
The correction resolution varies continuously as a function of frequency. It starts with the highest resolution in the low frequencies where most of the problems occur and then gradually relaxes as it gets to higher frequencies.
Chris
So, your filters are, effectively, shorter at high frequencies.
How is this different that the Vista (tm) room correction system, I wonder.
(you knew I was going to say that, didn't you?)
post #6034 of 62221
Chris,
I'm having a similar problem as sterryo, except I'm using HSU MBM and HSU HO Turbo.
MBM nearfield, and HO farfield. Any more advice on running Audyssey with a multiple sub placement like this?
Nick
post #6035 of 62221
Some need to put this in the first post of the thread.
post #6036 of 62221
Hi Rob,
MultEQ uses fuzzy logic in the following way: Multiple room measurements are taken and then a set of pattern recognition rules is applied to group them into clusters. After each cluster is formed the membership functions are calculated (these assign a probability of membership to each measurement and how "well" it fits within each cluster) and then a representative response is created for each cluster. The benefit of this approach is that the representative responses in each cluster contain the appropriate weighting based on the similarity of the acoustical problems--the assumption being that more common problems are more serious. The representative responses are then clustered again to produce a single room representation for each speaker and then an FIR filter is created that inverts that weighted representation.
Coming up with this method took about 5 years of research at my lab in the USC Electrical Engineering Dept. What we found very early in this work was that a single position measurement is hopeless in providing enough information to a room correction system. There is a common misconception that if you have one listener (e.g. a mixer) then you should put the mic next to them. Our work showed that this may provide some smoothness in the high frequencies (some times), but often makes things worse in the low frequencies. So we focused on methods that allow us to combine multiple measurements and our algorithms are based on these findings.
Simple averaging of measurements can offer some improvement over the single position case, but can also get you into trouble for two reasons: (1) it is an RMS average of the magnitude responses and thus ignores any time domain effects and (2) it assumes, by definition, that each response is weighted the same when in fact certain problems are clearly more important than others.
After figuring out how to combine measurements, we worked on the measurement process itself. Pink noise and other stationary signals are limited to frequency response results only. They are basically time blind. So, we decided to focus on an impulse response method using a deterministic signal that has the same spectrum as pink noise, but is based on a time domain representation. Once the signal is collected from each measurement, an analysis is performed to separate the minimum phase components from the excess phase components and each are treated differently for the exact reasons you mention in your message. Mourjopoulos and others have shown that the contribution of the excess phase is directly related to the reverberant field and requires different methods from what the minimum phase components need.
Chris
PS. I have read your AES papers (and JJ's) and I think there is great overlap in our research interests.
Hi Chris,
I don't encounter very many fans of Lotfi Zadeh (the fuzzy father), it is refreshing. Weighted commonality is a method that works.
Regarding stimulus, I agree, using seeded noise with a reference is appropriate (the longer you run it, the more you reject measurement artifacts) and you can extrapolate time with high certainty.
I'm very interested in the application of perceptual weighting within the construct of the Audyssey algorithm. jj is most expert in this. We should perhaps generate an NDA and conference?
rob r.
post #6037 of 62221
Originally Posted by aaranddeeman View Post
Thought, it would be helpful for folks getting their mic lined up correctly.
the tripod allways works best . easyer to use and setup
post #6038 of 62221
Audyssey is not measuring distance, it is measuring elapsed time including any delays from processing. Does your sub have some sort of filtering?
post #6039 of 62221
Well, I purchased the Denon 4308ci a few weeks ago, ran the Audyssey setup and after running it a few things, my first experience is that I am not impressed. I had a Pioneer 56txi previously that was calibrated using Sencore equipment (RTA's and stuff) and the difference is almost night and day.
I will be spending the next few days calibrating my Audio with my Sencore equipment, but I must admit, with all the talk about Audyssey, I thought the results would of been a bit better. Maybe I was expecting too much.
Also, I noticed that I can't EQ my Sub. I also believe that there is a way to use the pro version of Audyssey with the 4308? Anyone know how this can be done? I would love to get rid of my parametric EQ in my system and have everything running from the Denon.
Any help is appreciated.
Brian
post #6040 of 62221
Well, when Audissey cal's finished I can review the measurements.
It does show distance to all my speakers - and show it very accurate.
Since I didn't enter any distance manually, how come I got distance right for all 5 speakers (besides SW). So it does measure it.
Regarding SW - I don't know if it has any filter inside. Paradigm 12 is 6 year old SW and I don't have any reference material for it.
Thank you
post #6041 of 62221
Brian
I am on the same boat with Audissey impression, but I hope I just don't have enough experience and trying last 2 weeks various settings with crossover on my 5308 and SW settings.
post #6042 of 62221
The Paradigm website says it has a "Subwoofer Cut-Off" that is Variable 50 Hz - 150 Hz. Where do you have that set?
post #6043 of 62221
Per 5308ci manual SW Crossover should be set to Max and Sensitivity to 1/2 scale. On SW it's called Crossover Dial.
Tried that - getting 24 feet distance with level check for SW at "-12db".
post #6044 of 62221
New to Audyssey? Read through this. There will be a quiz later.
post #6045 of 62221
Yep, that is the correct setup. Nothing alarming there with the "distance" measurement in and of itself. How does it sound?
post #6046 of 62221
Here are alarming list
1. SW distance is wrong
2. SW level shows "-12db"
3. Front and Center Speaker set to 40Hz crossover as Large, when Freq is 44-22khz.
4. SW almost not noticible.
When I change crossover to 80Hz have a lot of SW.
I just want to undestand what the right way to acompish cal's and make sure it's right.
post #6047 of 62221
OK, I should have said "nothing alarming to me."
1. It may not be wrong, if your sub has circuits that are introducing delays. An LPF could certainly do that.
2. Yeah, OK, why does that alarm you?
3. Audyssey is measuring in-room response and passing that info along to the AVR. The manufacture determines the point at which a speaker is considered LARGE. Simply raise the crossover to 80Hz. I did on mine. A sub is nearly always the best to reproduce those frequencies anyway.
4. Chris (audyssey) can best address that.
Read the "document" I linked here.
post #6048 of 62221
Thanks Tocaje..
So if I understand it right, what you have done is first ran Audyssey so as to get sub trim as "0 db" on Denon. Marked this position on the sub for its volume knob. Then you turned back (to lower side) this physical volume knob on the sub to your liking.
Could you please confirm this? I am about to re-run the Audyssey and would like to follow the steps towards "Audio Heaven"
Sorry to not post sooner, been gone. The answer is 'no, Audyssey set my sub to +3.5 db but according to Audyssey(Chris), turning up or down the sub's volume will merely turn up or down the trim level in the menu (which translates to me that getting a setting of Odb isn't all that necessary).
post #6049 of 62221
Originally Posted by EricScott View Post
Curious as well. I re-ran Auto Setup on my 1909 to get the sub as close to 0 as possible. Then I thought people said the best way to reduce the bass is to manually adjust the sub trim through the Denon (which you can set separately for each input). However, whenever I get really boomy bass, even tweaking the SW trim to -12.0 db (the minimum) doesn't seem to help much (if at all). So I settled on basically leaving the SW at -4.0 (vs. the Auto Setup level of +1.0), which seemed somewhere in the middle of the range. But it definitely hasn't fixed the boomy bass.
Otherwise I love the sound - amazing surround sound details.
I tried the -12db thing and it was still too much bass. The solution, as posted above, was to grab hold of the sub's volume knob and physically turn it down (I marked it though, just in case.)
post #6050 of 62221
Yes. You do not need the boom.
The steps I mentioned are mainly useful for the couch/sofa seating. Because it's almost impossible to keep the tripod on couch and make it leveled at exact ear position (not height-wise, but horizontally). It invariably be in the middel of the seat.
Ok cool.
now i have a question about listening position's( for you or chris) how many should i really run? i know chris says to run all 8 but accoring to this poster he says the more you run the worse it will sound? what? http://www.avsforum.com/avs-vb/showt...1#post13562221
i have a 10x12 room, its small so how many should i run? as of right now i have 6 positions saved. also when i get my tripod should i place it on top of my bed? or should i move the bed out the way? and is it a good idea to cover up reflection points? i was thinking of covering up my tables and drawer's with blankets.
sorry for all the questions but this thing can drive you crazy
EDIT....also forgot to ask does the mic have to be at the same level of the speakers tweeters?
before when i ran it i had it way higher.
post #6051 of 62221
Also can somebody give a link to a simple tripod from radio shack or best buy.
i cant seem to find the right one.
post #6052 of 62221
Ok. That makes sense. Because after reducing the trim level on the AVR the effect was minimal to negligible. I should try the sub volume trick.
Just to get a sense, approximately how much backward turn is needed? The knob of my sub is at around 2 o'clock position (with trim level set by Audyssey as +0.5 db). Should this be turned to about 12 o'clock?
post #6053 of 62221
Go to wally world for a $18 or such..
post #6054 of 62221
Ok, I will read this, it looks like a lot of info there.
I am still in page 68 of this thread, you gave me link to page 191
post #6055 of 62221
FWIW, when I join a new thread, I read the first page and then the last two weeks worth of posts. Usually, everything gets repeated every week or so anyway. I would still try the thread search function before asking something that had not come up in the last two weeks' posts.
The document boils down all of the wisdom in this thread,
- Jeff
post #6056 of 62221
No, they are not shorter at all. The filters are always the same length. The trick is to redistribute the taps along the frequency axis.
Regarding Vista, I'd be happy to comment if you gave me some details of the inner workings
Chris
post #6057 of 62221
Originally Posted by craig john View Post
Chris,
Sorry, but we can't let science stop because of one uninformed poster...He has no idea what he is talking about, particularly when he tries to explain Dynamic EQ.
The curves (not curve--it is a family of curves that vary with level) is based on a combination of all of the above and modified based on extensive listening evaluations in calibrated rooms and systems.
In addition to monitoring the volume control, Dynamic EQ also estimates the perceived loudness of each channel in real time. That's because a soft passage and a loud passage need different amounts of loudness correction as the master volume is turned down and this changes moment-by-moment.
One of the key enablers was actually MultEQ. You can have the world's best curves, but if you don't have knowledge of the absolute SPL level then you don't know what curve to be on!
Finally, part of our listening panels involved professional mixers. We found that when the volume was being turned down they were turning up the surround levels. It turns out that loudness has a spatial dependence and it actually rolls off faster from the rear hemisphere. So Dynamic EQ adjusts the surround channel levels as the master volume is turned down. It uses a model that we derived from recording the actions of professional mixers.
Chris
post #6058 of 62221
Thank you
You mentioned that you set your subwoofer to 100 Hz. That's a filter. It adds electrical delay to the signal and MultEQ is measuring it and correcting for it. The reported "distance" is the sum of the acoustical distance and the electrical delay. If you don't do that your sub will not blend properly in time with the other speakers.
Also, the fact that the reported trim is -12 dB means that you have your sub knob turned up too high. I would suggest turning it down as you are at the limit of the trim correction allowed in the Denon.
Chris
post #6059 of 62221
Originally Posted by n737nc View Post
Chris,
Nick
Unless you have a way of adjusting the delay between the two subs, the best you can do is run MultEQ and hope that it corrects whatever problems may arise from the displaced subs. Some AVR products give you independent delay control of subwoofers and MultEQ can use that effectively to time align boxes that are at different distances.
Chris
post #6060 of 62221
Brian
Hi Brian,
You can most certainly EQ the sub using MultEQ XT in the 4308. In fact, the sub filter created is 8x the resolution of the main channel. Are you not hearing the chirps from the sub when you run MultEQ XT? And yes, the 4308 CI is enabled to run MultEQ Pro.
How many mic positions did you use and where did you place the mic?
Chris
