Audyssey Sub Distance Tweak Procedure.pdf 1121k .pdf file
I am just venturing into the world of PEQ to be used in conjunction with Audyssey Pro. Yes, I believe there are things you can do. Audyssey is good but it is not, of course, perfect and it is possible to improve on what Audyssey does. One such easy improvement is to do the 'sub distance tweak' to improve the splice at the crossover frequency (search that term for more info or download the attached document that I compiled for another thread). In addition, I am about to experiment with using PEQ to tweak the response of my dual subs to a flatter curve than Audyssey sets. If you measure independently after Audyssey has done its work, you will see significant differences between what Audyssey predicts it will do and what it actually does. Some of this is down to the fact that in most post-Audyssey measurements one only measures one seat - but I only calibrate for one seat with Audyssey anyway, so that doesn't matter to me (I am the only critical listener). The usual advice is to run the PEQ first to give Audyssey a 'better starting point' but it depends on what you are trying to achieve. There are reports of systems with a huge 25dB peak for example that Audyssey cannot tame and in this case PEQ applied prior to Audyssey can help a lot. OTOH, if Audyssey is doing a pretty good job but you just want a better job, then you might apply a little PEQ after running Audyssey as the 'icing on the cake'.
If you do do any manual EQing, please come back and tell us how you got on!
Keith,
Here is some fun I had with a little pre-audyssey eqing
Enjoy the read:http://www.avsforum.com/t/1444885/dbx-dual-31-band-eq-deq2496-adventures-in-manually-eqing
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
