Hi Joe,
First, I'd like to say that I agreed with both what you and David recommended, that is, to go back and try to reexamine the root cause for why the original poster feels dubious before immediately adjusting the trims.
With regard to whether under MOST circumstances a 1 dB level change is audible, here's what David actually stated:
Originally Posted by David Aiken
Well, my volume control is calibrated in dB and sometimes the difference in a volume setting I like and one that is a little too soft or too loud is only 0.5 dB. A half dB change can be noticeable under some circumstances and so can a full dB. Most people can detect differences of 0.5 or 1.0 dB under the right circumstances and they don't have to be "golden ears" to do so.
He didn't say that most people can hear a 1 dB level difference under most circumstances, but rather under the right circumstances.
Here's what F. Alton Everest states on the subject in his Master Handbook of Acoustics:
Audibility of Loudness Changes
Modern faders are the composition type giving graduations in level so small as to be inaudible. Wire-wound faders of early mixing consoles produced discrete steps in level that could be audible. Steps of 5 dB were definately audible, setp of 0.5 dB were inaudible, but these steps cost too much to produce and 0.5 dB steps were not necessary. Steps of 2 dB, an economic compromise, produced changes in signal level that were barely detectable by an expert ear. Detecting difference in instensity varies somewhat with frequency and also with sound level.
At 1 kHz, for very low levels, a 3-dB change is the least detectable by ear, but at very high levels the ear can detect a 0.24-dB change. A very low level 35-Hz tone requires a 9-dB level changes to be detectable. For the important midfrequency range and for commonly used levels, the maximum detectable change in level that the ear can detect is about 2 or 3 dB. Making level changes in increaments less than these is usually unnecessary.
It should be pointed out that when Mr. Everest states that something is inaudible, he undoubtedly is discussing this in the context of a scientific experiment, that is, in a blind test. When I turn the master volume knob on my prepro by 1 dB and think I can detect the difference, at normal listening levels, I'm probably reacting to placebo effect knowing that I changed the volume, but that doesn't mean I could have detected that small change in a blind test.
Larry
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
Sorry for the confusion.
