AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #51779)
"Official" Audyssey thread (FAQ in post #51779) - Page 1001
post #30001 of 70890
Is a Denon mike suitable for an Onkyo?
I found a great price for an Onkyo receiver and I look forward to trying Audessey. When I noted the mike was missing, the salesman found one from a Denon. The mike looked the same as one pictured in the manual. The salesman insisted these mikes were the same.
Printed on one side the mike has the name "Denon," and on another side "Audessey." The bottom has a brass insert that fits and locks on my tripod. Maybe it looks like a duck and quacks like a duck and it's a calibrated mike.
Maybe the salesman was right? I guess a mike is better than no mike.
post #30002 of 70890
Originally Posted by audyssey View Post
One word: "two subs".
So will this render the SubEQ and SVS AS-EQ1 obsolete?
post #30003 of 70890
No, it will mean CHEAP AS-EQ1s and SubEqs for the rest of us! :-D
post #30004 of 70890
Hopefully because those devices have a significant drawback: they don't optimize the crossover region from subwoofer to mains.
post #30005 of 70890
In Audyssey's Facebook you can see the SUB EQ HT feature is a dual sub eq.
''Audyssey Denon 4311 hits the stores. 9.2 channels, MultEQ XT32 (not 21 as the article states), 7 HDMI outputs, "Pre Amp Mode" and Audyssey's new Sub EQ HT which equalizes two discrete subs. ''
post #30006 of 70890
Overlaying MultEQ XT or Pro is the recommended procedure for these devices, so that takes care of sub/mains integration.
post #30007 of 70890
Or are we going to see a 32x upgrade to these units, now with 16k filters (32x512)
post #30008 of 70890
The last firmware doubled the filter resolution to, I think, 32x.
post #30009 of 70890
Last firmware did double but took these units from 256x to 512x.
The algorithm for XT32 has allowed filters to go from 16x to 512x (32x)
So the question could this new algorithm in the standalone units increase them 32x (16k) or is it just making them obsolete?
post #30010 of 70890
I know the wisdom is to follow Pro's recommendations for crossovers...but I just want to understand a little better.
My speakers install guide says they should be used with an 80hz crossover. The subwoofer says the same thing. Now, I have heard that this is only a recommendation and that the in room performance as measured by Pro is more important...... and I have heard that if the manufacturer says to use 80hz, then you should. But I don't know of anything in the spekear itself that would neccesitate an 80 hz cross. They are rated at -3db at 70hz, and that is what Pro recommended as the first choice for all satellites, except the center....for that it recommends 100hz.
I intend to try some listening tests with all crossed at 80hz and then with Pro's recommendations---all at 70hz except the center at 100hz. Any recommendations as to what to listen for and what type of material to use for the AB demo?
But just to be sure....my THX Ultra 2 certified Integra 9.9 will still use a 2nd order filter if I select 70hz as a cross. Then the speaker applies another 2nd order filter....so you get a 4th order filter in total. I know with 80 hz (THX) it will follow that procedure, but I want to be sure that it won't do something differnt if I select a non THX crossover.
Also, I have heard that Blu rays are mastered with 80hz crossover in mind. I can't figure how this would make a difference, or if it is even true.
post #30011 of 70890
Maybe this new algorithm was developed on the SubEQ and is what allowed the recent increase.
Obsolete? Not for people who aren't going to drop $2k on a receiver, and certainly not for anyone who already owns one.
post #30012 of 70890
Interesting point on the development.
Maybe obsolete is the wrong word, redundant might be better, baring in mind that we are only talking with reference to the processing in the new AVRs
post #30013 of 70890
.. in the new high-end AVRs
The manufacturers will be very shrewd in what they put this in. I've already heard people grousing about it. I've groused about it.
post #30014 of 70890
Might help to understand where this questioning comes from
I have a 4810 and I just purchased an EQ1 unit. I now am hoping to see an xt32 upgrade for the 4810 or the purchase of a new unit with the xt32. So for me, and I am sure many others, will the EQ1 be a pointless unit as soon as I/we have xt32 enabled AVRs. (ultimately it's all about me)
post #30015 of 70890
Chris...Audyssey!!!
I have asked this before but there are so many posts in this forum, I have never seen the answer.
I have (or shortly will have) an Integra DHC-40.2 and a Sound Equalizer. What is the correct way to set them up.
1) setup the Sound Equalizer, then setup Audyssey in the 40.2 going thru the sound equalizer and use whatever distance/levels found by the 40.2 setup?
2) setup the sound equalizer, then setup the audyssey in the 40.2 so I can activate Dynamic EQ and volume but manually override the 40.2 eq to flat and use the distance/level settings from the Sound Equalizer Setup.
3)?????
if (2) is the answer, will dynamic volume/EQ work correctly?
post #30016 of 70890
The signal doesn't get better from being processed 2 times.
post #30017 of 70890
AFAIK, the mics are different. You should never use a mic from any other receiver (even other different model Onkyos).
post #30018 of 70890
Anyone whose system has no un-corrected problems will hear no difference with increased filter resolution.
post #30019 of 70890
The signal? How about the sound?
The sound of my system improved quite noticeably overlaying Pro onto my AS-EQ1.
post #30020 of 70890
I am in this situation as well, because I purchased an AS-EQ1 several months ago, and am strongly considering upgrading to the 4311 when it comes available. I don't think a clear description has been provided yet as to how new AVR's with Sub EQ HD will either co-exist, or replace, the stand-alone sub equalizer. For example, if Sub EQ HD provides all the functionality of the AS-EQ1, then perhaps it's time to move the AS-EQ1 to the bedroom system .
Jeff, other than purchase the Pro kit and look at the "after" graphs, it's somewhat difficult to know the number and severity of "uncorrected" problems. There is always the listening test, but that is too subjective for me. One of the main reasons I am considering upgrading to the 4311 from a 4308 is the MultEQ XT32. I am going to be disappointed if I don'tperceive any improvement in SQ. Your thoughts?
post #30021 of 70890
Your best bet at hearing the difference, if any, that the 10 Hz change in crossover point makes would be with a pink or white noise test signal. You're basically shifting three notes up or down and to find a music or movie passage that highlights the change clearly will be hit or miss. I'd go with what the in-room measurement says, but YMMV.
AFAIK, BDs are mastered, for major releases, from the PCM 5.1 channel master that was used to create the theater prints. There's nothing about them that can or should consider what the crossover might be to a subwoofer that might or might not be used to handle redirected bass in a setting different from a movie theater.
Plus, I don't know how you would master with an 80 Hz crossover in mind. You could mix or master using bass management with an 80 Hz crossover, which would make zero difference if your mastering system is "perfect" (flat, all the phase stuff a-okay) and would be skewed for the particular mastering system's idiosyncracies if that system were not perfect. Then, to match what the master-ers heard, you[d have to find a way to perfectly recreate the imperfections in the particular system used to make the particular BD, which seems a stretch.
post #30022 of 70890
Question for Chris:
We already know from a previous post that the Pro kit will support the 32x resolution enhancement, asssuming of course that it is run in conjunction with a new AVR with MultEQ XT32.
Will a software upgrade for the Pro kit be required to support this? If yes, will it be available at the same time the new AVR's are shipping, and will it be free for existing Pro users?
post #30023 of 70890
But, acting as "one"
You're killing me Chris. I am going broke keeping up with all the new Audyssey *toys*. Should I just add you to my checking account and send you a debit card?
post #30024 of 70890
How do you know how it would sound if there was only one single optimization EQ involved? The point is: the signal gets EQed two times, not a favorable situation.
post #30025 of 70890
I know because I lived with only MultEQ XT for quite a while, added the AS-EQ1 using the bypass (causing MultEQ XT to set a null filter on the sub channel) and lived with that for a while before purchasing the Pro Kit, doing a calibration "over" the AS-EQ1 and then using that ever since.
You're speaking theoretical and I've been experiencing actual. I've also read that the effects of another analog/digital/analog round trip is less likely to be noticed at subwoofer channel frequencies. Whether that's true or not, I know my system and it only got better with the application of each increment of Audyssey technology.
Jeff
post #30026 of 70890
WRT how the AS-EQ1/SubEQ will fit going forward, the "market" will sort that out. Whether or not you move the AS-EQ1 to your bedroom system and purchase a something with SubEQ HT (HD?) in it will be one buying decision that will, along with everyone else's decisions, be the market making that determination.
I honestly don't know how they can A/B lesser res filters with the higher res filters. I know that I am quite happy with my system's performance. Part of that is Audyssey and part of it is the acoustical treatments. I would not consider giving up either one. I suspect that when I do upgrade, it will be to add DSX and Wides, not to get higher filter resolution on the main channels.
Jeff
post #30027 of 70890
Jeff
So what you heard was a difference. But different doesn't equal better. Even with a proper listening test (ABX) we would not know what is better - the recording just might not be to your liking. The only way to determine what is better is to "theorize" and measure. That's what automated speaker-room optimizer like Audyssey do.
post #30028 of 70890
Chris posted about this before but I couldn't find it...
If you had 7 speakers, would using the last 2 as wides or surround backs be best? If you had 9 speakers, would using the last 4 as wides, surround backs, and/or heights be best? General speaking of course...
Some Pro and Cons of each configuration would be great, too...
post #30029 of 70890
I guess part of hearing an improvement *is* hearing a difference, but words have meaning so I'd like to characterize it as I choose.
Admittedly this is subjective and you don't know what I am hearing or anything about my ability to judge what I am hearing. Having said that, the improvements I heard were in the integration of the surrounds and the fronts and integration of the subs with the mains. Along with that, the imaging across the front improved as well as the imaging on the sides. From MultEQ XT to adding the AS-EQ1 to overlaying MultEQ XT to .. overlaying MultEQ Pro, the ringing in the LF incrementally decreased as well at each step. That, at least, was measured.
Jeff
post #30030 of 70890
according to Audyssey research:
- after the "core" 5.1 speaker setup, the greatest improvement is gained by adding "wide" speakers to create the proper sense of "auditory source width", giving the soundtrack that sense of enveloping spaciousness that you get in a big concert hall or movie theater.
- second, but far behind, is the addition of "height" speakers, and then the "surround back" speakers are considered the least important.
See the Audyssey DSX page, they explain the rationale: http://www.audyssey.com/technology/dsx.html
Where should the new channels be placed?
One key finding from the research is that first side wall reflections play a great role in determining subjective impression. The most important direction of reflected sound was found to be ±60° relative to the front. Audyssey DSX provides a pair of Wide channels (LW and RW) at ±60° with appropriate frequency response and perceptual processing to match these requirements of human hearing. These Wide channels are much more critical in the presentation of a realistic soundstage than the Back Surround channels found in traditional 7.1 systems. Adding surround channels behind the listener has a very small impact compared to the increase in envelopment and soundstage width that the Wide channels provide.
The next most important acoustical and perceptual cues come from reflections above the front stage. Audyssey DSX provides a pair of Height channels (LH and RH) that should be ideally positioned at a 45° elevation angle.
In practice, a lot will depend upon the specifics of your room. If you don't have the space to properly place "wide" speakers, then the fact that they are theoretically the "most important" doesn't do much for you
