AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #51779)
"Official" Audyssey thread (FAQ in post #51779) - Page 1896
post #56851 of 70896
Originally Posted by AustinJerry View Post
Sorry, I did not know that.
You wouldn't know till you try it, its not like its in the manual, or batpigs "try this" for that problem, but maybe it should, I know it works with onkyo, but not denon... But the list could be longer.
post #56852 of 70896
Something else was obviously wrong. The recommended course of action is to find out what's wrong not game the system in a way that ignores the problem.
Jeff
post #56853 of 70896
Jeff
Honest advice, Jeff.
post #56854 of 70896
Jeff
I know what I like, and now I got it, whats wrong with that? There really wasn't any audible problems before, only with audyssey on caused the audible discomfort. Sure I know theres something in my HT mix that needed to be corrected and that can be done in many different ways.. I found a fix / patch that is cost effective and I feel that really works for my needs. I think I should get a little credit for my ingenuity. In this game its not your way or the highway... My way didn't ignore the problem, it hit it straight on like a shot gun blast at point blank range.
If I said it took $1500 in room treatments to fix this, would I of gotten the nod of approval?
Most people who have used audyssey have bitched about it in one way or another at sometime.. For me, any fix that works is a good fix, and if it didn't cost me anything than its that much better !
I'm just passing my findings on to others who are in the same boat as I, use at your own risk..
Edited by joehonest - 10/4/12 at 7:20am
post #56855 of 70896
Originally Posted by joehonest View Post
I know what I like, and now I got it, whats wrong with that? There really wasn't any audible problems before, only with audyssey on caused the audible discomfort. Sure I know theres something in this HT mix that needed to be corrected and that can be done in many different ways.. I found a fix / patch that is cost effective and I feel that really works for my needs. I think I should get a little credit for my ingenuity. In this game its not your way or the highway... My way didn't ignore the problem, it hit it straight on like a shot gun blast at point blank range.
If I said it took $1500 of room treatments to fix this, would I of gotten the nod of approval?
What you did to "resolve" the issue is the equivalent of cutting off your arm to cure a hangnail. No credit due.
post #56856 of 70896
Originally Posted by splatee View Post
Thanks for all the fast replies everyone.
I am going to give it a few days of listening and give myself a chance to adjust. I only spent a few minutes listening to it after running Audyssey.
Once againg thanks to everyone for the help and all the great info on this site.
Could also try the "music" curve which is flat and does not have high freq roll-off.  Maybe that is more to your liking.
post #56857 of 70896
Music surround modes also spead the center or vocales differently than movie surround modes. The mains will have more to do with what you hear in many music modes, which is a good thing, if the center is doing more harm than good... This is very clear with 2.0 inputs.
Edited by joehonest - 10/4/12 at 8:41am
post #56858 of 70896
Originally Posted by Colmo View Post
Originally Posted by kbarnes701 View Post
It's not super critical to get the level at exactly 75dB on that first Audyssey screen. The idea is to get it to 75dB so Audyssey can set the trim later to something appropriate - between -3.5dB and +3.5dB is the usual range suggested.
I would set the sub to about 78/79dB initially and then run Audyssey and see what trims it gives - if the sub is in that -3.5dB to +3.dB range, you're done.
You can do a quick 'n dirty test by putting the Audyssy mic at the MLP, running the minimum number of positions (3) without moving the mic and then seeing the trim for the bass. If it;'s OK, then run Audyssey using all positions as normal.
Please report back your findings and if necessary we can dig a little deeper. I suspect you will be OK.
Thanks - I adjusted the B&W PVD1 by it's max volume trim by -6db - this allowed Audyssey to run as it showed a level of around 77db or just a little less. I checked the Denon channel levels and it showed that all the M-1s had been increased between 3db to .5db while the subwoofer had been decreased by 4db. The -4db is just outside the parameters you mentioned of + or - 3.5db. Do I need to try any other adjustments and re-run Audyssey to try to get the subwoofer adjustment from -4db down to 3.5db or less or the - 4db is ok?
Hi - sorry for late reply - I have been away for a few days without a net connection. No need to do anything - -4dB is just fine. You are good to go!
post #56859 of 70896
I wasn't referring to the Music Surround Modes, but rather the chosen Audyssey curve.  I believe in most Onkyo's where you have a choice the flat curve is called Music and the reference curve with high freq roll-off is called Movie.
post #56860 of 70896
Only if you want it that way. If not, you can adjust the centre spread so that all the centre imaged content comes from the centre speaker. PLIIx, for example, has a Centre Spread parameter that gives you 7 steps of adjustment, from full centre extraction (like movie surround modes) to no extraction (centre imaged info comes from L/R speakers), or somewhere in between (spread to all 3 front speakers).
Besides, PTG already mentioned that his comment was about the music EQ curve, not music surround mode, so no need for me to go further into that.
post #56861 of 70896
The onkyo has RE-EQ on/off in most movie modes. The Audyssey curve music / movie are tied to the sound modes with the 5007, The newer onkyos / Audyssey do offer that feature in its self. I tried them all.. But still for me no Audyssey curve/ fitlers for only the center sounds the clearest, but the subs, mains and rears all do benefit from Audyssey. I'm happy onkyo allows me this tweak.. I see the new Audyssey software suite now has a "Dialogue Enhancer" feature, Its good to see Audyssey listens to the needs and crys from there users... A good reason to upgrade, If I haven't found this tweak, it would of been well worth the cost just for the new "Dialogue Enhancer" feature..
post #56862 of 70896
I'm glad you're happy, but don't kid yourself. You did not fix the problem, you fixed the symptom. And my deja vu tells me that this will be my last comment on your "fix." Unless you bring it up yet again in another six months.
post #56863 of 70896
Hey Joe,
I have the new Onkyo 818 and I would like to explore this 'Dialogue Enhancer' feature that you've found. Could you point me to it as I don't see it offered in any of the Audyssey menus.
post #56864 of 70896
Originally Posted by Patrick Murphy View Post
Hey Joe,
Not Joe (thank goodness), but he may have been referring to a feature on the new Denon 4520 AVR. I think this is a Denon technology, not an Audyssey technology. If it were from Audyssey, their marketing department would have made us well aware of it.
post #56865 of 70896
Its the best I can do for now with what I have and it seems to do the trick, like I said, this has bugged me for years....
Hey Joe,
I saw the new denon 4520ci has it along with other Audyssey menu goodies,,
check it out @
http://www.avsforum.com/t/1430049/the-official-denon-avr-4520ci-thread
post #56866 of 70896
Maybe their "Dialog Enhancer" just turns Audyssey off for the CC?
J
post #56867 of 70896
Had you ever tried determining the problem, or maybe took measurements to post so others could help?
Jeff
post #56868 of 70896
J
I like this guy;)
post #56869 of 70896
Jeff
I wish I could post some techy print out to be analyzed.
I believe its some phasing cancellation, but not at all frequencies, due to being 3way speakers for mains and cc.
post #56870 of 70896
Since dialog is 99% in the center channel I don't think it is a problem with interactions with the mains.
Sent from my SPH-D700 using Tapatalk 2
post #56871 of 70896
Have you had the problem with more than one speaker/speaker system?
post #56872 of 70896
Jeff
That would be a relatively simple assessment with an OmniMic or REW measurement kit, and a frequency sweep on a Frequency Response graph:
a) Run test tones wirh the center channel with PLII Cinema and Ausyssey Off (other speakers off)
b) Repeat with Audyssey on, and Dialog Enhancer, DEQ and DOL off
c) Repeat with above, but Dialog Enhancer on, DEQ and DVOL off
If you overlay these three graphs, you'll see what Audyssey and/or Dialog Enhancer is or isn't doing, and whether Dialog Enhancer is effectively turning off center channel Audyssey.
post #56873 of 70896
I was joking. I doubt that any licensee has implemented a "Dialog Enhancer" that disables Audyssey on the center channel. smile.gif
post #56874 of 70896
That's a relief. For a second I thought you had a personality shift:eek:
post #56875 of 70896
That is not correct.  Re-EQ is always off unless you are in a THX mode. If you use THX and therefore Re-EQ, you need to ensure that the Audyssey Music/Flat curve is used in order to avoid a double roll off at the HF end. In all other (non-THX modes) the music/movie curves have nothing at all to do with the sound modes (and they are not really "tied to" them ever).
I'd prefer to find out what is causing the problem rather than have no room correction on the all-important centre channel.
What is the "new Audyssey software suite"? ITYF that the Dialogue Enhancer is something in your particular AVR.
post #56876 of 70896
Wow, i never expected the definition for ITYF would be on the Net, but it is.
see here: http://www.internetslang.com/ITYF-meaning-definition.asp
post #56877 of 70896
LOL. Good find, that site.
post #56878 of 70896
Great, you just gave Keith more ammo...
Max
post #56879 of 70896
+1
Neither the new "Dialogue Level" on the Denon XX13 models nor the "Dialogue Enhancer" setting on the 4520CI appear to be related to Audyssey in any fashion.
post #56880 of 70896
Max
LOL! IMHO IDK if I need more ammo to use TLAs! :)
