AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #51779)
"Official" Audyssey thread (FAQ in post #51779) - Page 2215
post #66421 of 70896
"Top of the line" has nothing to do with it. Do you have a user manual?
@ comfynumb -- I already suggested that, note that on Onkyo the "Flat" curve is called "Music".
See here: a)7. What are the Audyssey 'Movie' ('Reference') and 'Music' ('Flat') curves?
post #66422 of 70896
I can download one. Do I need an OSD menu for that? I don't think mine works anymore lol. But usually when I got into audessey setup, looking at the reciever desiplay, it just tells me to place Mic in position one and then click next.
post #66423 of 70896
It's not done during setup (calibration), it's a post setup setting that you can change.
post #66424 of 70896
Ahh ok. I'm about to download the manual
post #66425 of 70896
I don't see anything in the audessey section about music or flat in the manual. After I do audessey I can adjust the levels of each speaker and their crossover. But anything eq wise is done with audessey and I don't think I can change it unless I'm no longer using it. Maybe I'm missing something
post #66426 of 70896
I just read somewhere that onkyo doesn't allow me to do what we are talking about. Is there any other wag to increase the highs level? While having audessey set up?
post #66427 of 70896
Try using THX Music Mode
post #66428 of 70896
Brad if your OSD isn't working, maybe you have an android phone or iPhone. I have an app for my iPhone that allows me to adjust many things including Audyssey. The nice thing about these is your phone is now your display. Granted you can't adjust everything from your phone but you can adjust many this way. Just a thought.
post #66429 of 70896
Thanks comfy I'll try that. And primetime what's the difference between music mode and movie mode? Would it still direct different sounds the same and everything like that?
post #66430 of 70896
You should have "tone" controls in your onkyo. I have a 5 year old model that has them. tx-nr805 or something like that. It wont be an audyssey setting but should be in the audio menu of the AVR.
Movie mode rolls the higher end off where music mode goes for the flattest response up to 20khz if you have speakers capable of getting that far. What else are you working with here? Onkyo model and speaker model woulp help tremendously.
post #66431 of 70896
SO dudes, I ran some OM sweeps tonight and I have a pretty great sounding non-audyssey response with a pretty serious room curve all the way down. It ain't the flattest I have had, but I really do prefer it for music. Anyways, it got me thinking, what if I put my dual channel 31 band 1/3 octave EQ and did some serious cutting in the house curve area, say 100-1khz to get the response flat without audyssey, then ran audyssey, and then turned around and brought the low end back up so I get the killer smooth EQ of audyssey and still get the house curve that I so wish was part of the audyssey calibration? Might be fun to try out. My only issue here is the fuzzy math and where the filters are set and what manually eqing would do after the fact by adjusting the 31 band eq back to normal. I know aud has way more filters, but it just might work if done right. Could be a cool little experiment at least...
post #66432 of 70896
Thanks. So the music mode is still 7.1? I have a mythos 8 center. Studio monitor 350s for fronts and then some Sony speakers for the heights. (Upgrading soon) my surrounds are klipsch s10s.
I can adjust treble and bass. Would boosting the treble help?
post #66433 of 70896
Originally Posted by comfynumb View Post
It works really well IMO. I also adjusted the PLII and took a little of the center channel (center width) out of the mains, I went from the default of 3 to 1 and it seems like it added some bass to my LP. Why I have no idea?
So is theres feature on onkyo to boost the highs? i have the Tx Sr607. Im not super happy with PLIIz but i have heights and no room for wides or rears so thats what im stuck with
Not a tone control but you can set 3 levels of 'effect' for PLIIz with Onkyos.  From memory, it's Speaker Setup > Audio Adjust > Dolby > PLIIz > Low. Medium, High. If that menu sequence doesn't take you there, poke around and you'll find it.
BTW, all this discussion of DSPs is interesting but it's way off topic.
post #66434 of 70896
Can't believe your AVR or pre/pro won't allow you to choose between Audyssey movie and Audyssey music (a.k.a. Audyssey Flat). Well, almost can't believe it.
After Audyssey runs, and any desired changes are made in x-over, etc., my Marantz gives me a choice of "Audyssey" (variously called -- by different manufacturers -- "Audyssey Reference, Movie or Cinema"), "Audyssey Flat," "Manual," and OFF. This is on the same screen as "Dynamic EQ," and "Dynamic Volume," so look on that screen with your AVR. "Dynamic EQ" starts using Audyssey Flat as a base, so I'm betting that your AVR has "Audyssey Flat." On mine, all of this is under "Audyssey Settings," under "Audio Adjust." You can switch back and forth between Audyssey and Audyssey Flat to compare them by ear. Audyssey Flat has more very high treble. Whoever sold you the AVR (store or mail order) should have someone who can help you with this.
If you use true "tone" controls, they won't mess up the room comp Audyssey set up, and neither will Audyssey or Audyssey Flat.
If, however, you use the virtual sliders on the graphic EQ, they will turn Audyssey off as soon as you touch them. The key is whether the Audyssey light stays on. If it's off, it's off.
Edited by garygarrison - 10/31/13 at 5:30pm
post #66435 of 70896
Originally Posted by garygarrison View Post
  • Can't believe your AVR or pre/pro won't allow you to choose between Audyssey movie and Audyssey music (a.k.a. Audyssey Flat). Well, almost can't believe it.
  • If you use true "tone" controls, they won't mess up the room comp Audyssey set up, and neither will Audyssey or Audyssey Flat.
Older and lower end Onkyo's do not have the option.  Only way to get flat/music is to use THX Music mode or THX Movie with Re-Eq off.
post #66436 of 70896
False. There is no relationship whatsoever between DEQ and the target curve.
post #66437 of 70896
I'm realizing now that his Onkyo 607 probably predates the option for user selected target curve. Onkyo only allowed the music/movie curve selection with more recent models.
On these older models with thx modes you could still get there but I don't think the 607 has thx.
post #66438 of 70896
Thanks guys. My recoever is getting old. 2009. I'm going to look for the plIIz effect level and try that out.
post #66439 of 70896
Sorry, I must have misremembered something I read in Ask Audyssey or in the Marantz manual. I thought it made some sense, because then Audyssey wouldn't have to turn the treble up again for DEQ, after turning it down for Audyssey reference/movie.
post #66440 of 70896
Remember that only affects the level of the Height channels though and has no bearing on their frequency response as such. I find I leave the PLIIz setting on High all the time, and it is still fairly subtle.
post #66441 of 70896
Q: I have a Klipsch RW-12d that is a bit too loud for the neighbors on the settings that Audyssey sets it to. Should I lower the volume or make some crossover change to make the sound both improve for my neighbors while still maintaining that whole purpose of Audyssey's calibrations? Thanks for the help.
post #66442 of 70896
^No, don't mess with the crossover, simply trim down the sub ch in the AVR.  More options: if you have DEQ on then turn it off as it boosts bass, or you could be sure to use DVol with it on eve or midnight to limit the overall loudness.  It also helps to isolate the sub from the floor using a SubDude or homemade equivalent. A few new AVRs have Audyssey LFC which is supposed to work great for this.
Edited by SoundofMind - 11/1/13 at 8:34am
post #66443 of 70896
thanks, and you mean trim it down in db level in the AVR? i have a subdude also, thanks for the help.
post #66444 of 70896
^Yes.  Then you can always easily put it right back when they go on vacation.:D
this is from the FAQ- but in your case you'll trim down rather than up
http://www.avsforum.com/t/795421/official-audyssey-thread-faq-in-post-1/51750#user_f4
post #66445 of 70896
Another option -- since the Klipsch RW-12D has a digital control panel -- is to tweak at the sub itself.
Another setting to check in the receiver is the LFE volume, most receivers allow you to attenuate the LFE directly (the big rumbly stuff) up to 10dB or more.
post #66446 of 70896
Originally Posted by soundlovr View Post
We strongly recommend against holding the microphone in your hand because this can give rise to low frequency handling noise that will cause the MultEQ filters to compensate by cutting those frequencies.
Can you expand on this? It would seem to me that any "low frequency handling noise" picked up by the mic would be due to fidgeting, and an inability to keep the mic metaphorically glued to your hand. I have been running Audyssey with the mic in my hand and I hold it perfectly still, in the listening spot, for the entire setup, and I make sure the cord isn't moving around.. I don't seem to have any problems, and the low frequency sound I get after running setup doesn't seem skewed in any way.. I don't see how holding the mic with your hand would present any audible issues as long as you keep still like a statue and make sure your body isn't occupying any area between the mic and the speakers.
The only tripod I have is a full-size pro video tripod and it's too big a hassle to try and set one of those up on the seat of a couch with the tripod head at the exact height and position it needs to be at. I don't know if it's even possible to get the mic down in the right spot w/ my tripod because the legs may be too long even after collapsing them all the way.
Edited by gts007 - 11/1/13 at 10:55am
post #66447 of 70896
hey guys! when i go into audio adjust on my marantz sr5007, under audyssey settings, it should have dynamic EQ, reference offset and dynamic volume but all i'm getting is MultEQ off or manual
I use to get these settings but now they are gone!
post #66448 of 70896
It is absolutely not recommended to hold the mic in your hand, period. The resulting calibration cannot be guaranteed to be even approaching good. Yo can buy a boom mic stand for less than 20 dollars, which makes it much easier to do the calibration and gives a reliable result.
More information here:
d)1.   Do I really need to put the Audyssey mic on a tripod or stand?
Of course, you are free to do the calibration any way you choose - but if you encounter any problems you won't get any support here because the first thing people will tell you to do is use a mic stand or a tripod. Entirely up to you how you do it, but it's anyone's guess if you are even getting close to a good calibration when you hand-hold the mic.
post #66449 of 70896
That means your Audyssey calibration has been wiped out. You either need to recalibrate or load the saved config if you saved it to a networked PC.
post #66450 of 70896
thanks alot. don't know how that happened though
