AVS › AVS Forum › A/V Control & Automation › Home Automation › Motion controlled light switches?
post #1 of 2
I have installed a couple of these and want to install more but where can I find a model that works well with florescent bulbs. Specifically the florescent spiral bulbs made to replace normal bulbs ( the switches I use now cause the bulbs to flicker constantly when in the timed on mode.).
Thanks in advance.
post #2 of 2
I use an Insteon appliance switch. My ELK security system tells MainLobby software to turn the Insteon light on for X minutes unless there is further motion where it stays on.
  Back to Forum: Home Automation
