I need help on how to set up a D-Vhs deck Mitsubishi hs-hd2000u to record from my new Fios hd set top box. The Ieeee 1394 connection connects well from mitsubishi hdtv crt to D- Vhs but the connections for 1394 on Fios box are larger ports than those on tv or d-vhs. The manual is worthless. I can't even get the menu to show on the tv. How many cables to you need and type and need help with connection set up. Thanks. Totally lost! fios Quip6200-2 box HD...
