The entryway to Gollum's Cave Theater (LOTR style) currently under design and construction. The entryway construction was suggested by Gonzo. Thanks Gonzo. We have enjoyed the old design and are looking forward to the remodel when the budget allows. The remodel design is still carefully being considered and any suggestions are welcome. A thread such as this was on my list of things to do so I am glad it's being covered.
Looking at the door to the entryway from inside the home. The future snack area (old kitchen with remodel too) is off to the right.
The candy counter is being moved out. The plan is to put a counter top with lamps beginning above the lower outlet on the far wall. Holes in the top of the counter run ac to lamps. There needs to be an access panel located above where the wooden signs are now to get to the conduit. That will run into the equipment closet on the other side of the far wall. A back lit sign with the theaters name will replace the clock that is on a switch. Installed in the counter will be a cool-cube to draw heat out of the equipment closet and allow ventilation to the theater. (acoustic treatments also in the equipment closet) The television is also being removed from the room.
Door to the theater.
Exit of the entryway. (under design)
Media storage and collectibles will go in the equipment closet as well I think. It all should look great by this time next year if things go as planned.
