Here is my set up for my music server that I am currently using. I have about 300 cd's rip to a 160 gig hardrive in wma lossless. I use to have it on a 80 gig in wma vb but now I am doing nothing with the 80 gig. Both drives are connect via usb to my main computer in the living from and from there I steam to my dedicated theater using a roku sound bridge, which isn't bad. For my living setup I just a long analog cambles from my computer to the cd input on living room receiver.
Now I would like to do (hopefully I can get some advice) is to get a large networked hard drive where I could ripped my cd's using the wav format and find a new device to stream music to my living room receiver. Now my questions are:
1. Is there any point into converting from wma lossless to wav format? I'm Trying to just get the best sound possible.
2. I searched this forum all over but I still don't have an idea as to which networked hard drive should I use. Do you guys have any suggestions?
3 I want to ad another streaming device to my living set up so I can select my files from the couch with having to go back to the computer or set up playlists. I don't have a problem with my roku other than I would like to use my television to see my audio files. So again, do you guys have any suggestions?
4 This is somewhat another issue but I am also looking for something to transfer my files to my car. Does the Ipod or zune play wma lossless? If not I thought about using my non-used 80 gig drive to store a copy of my collection in aac or similar format for transfer to an ipod or something else. Question is it possible to convert from wav or wma lossless, to aac or wma compressed?
Thanks for the help.
