The dish feed is only 480i and I wanted to use the gadget to upscale the signal to 720p for my projector,That was my original idea,as for spending $1,900 well I don't have that kind of coin since I live on a fixed budget .
So my last and final question will be ,will the gadget I descirbed above improve the picture quality coming out of my projector since it accepts 480i,480p,730p,768p and 1080i but does not upconvert.
http://www.mwave.com/mwave/viewspec....iteria=3694038
Convert between resolutions and video formats with StarTech.com's VID2VGATV, a composite/s-video/YCbCr/RGB component to VGA/HDTV scaler. The VID2VGATV automatically detects your source's input resolution and allows you to customize its output resolution and refresh rate through an easy to use on-screen-display menu.
Great for home theatre peripherals like DVD players, the VID2VGATV lets you connect non-VGA/HDTV enabled equipment to VGA or HDTV display devices like CRT monitors, projectors and HDTV sets.
Features:
Applications and Solutions
Display video feeds from DVD players, VCRs and more on VGA monitors, plasma displays, VGA input projectors and HDTV sets
Home Theatre
Security
Education
Medical
Conference Room
The StarTech.com Advantage
Automatically detects the input resolution of the signal while allowing you to customize the output resolution and refresh rate using the on-screen-display menu and front panel buttons
Convert video signals into VGA/HDTV output for computer displays or HDTVs
Pure hardware design, no software or drivers required
Features
Adjust picture brightness, contrast, color, RGB level and horizontal/vertical positioning
Output is analog RGBHV or YPbPr via the HD-15 VGA connector
Compatible with input from broadcast formats worldwide, including NTSC and PAL
A 48 MByte frame buffer eliminates image tear/video hiccupping
Includes a memory recall feature that automatically reinstates the setting last used
Technical Information:
Color Black
Connector Types
1 - DB15 High Density Female
1 - S-Video Female
4 - RCA Female
Input Formats Composite, S-Video, YCbCr component or RGB interlaced
Input Signal Levels
Video @ 1V p-p, 75 ohm
Y @ 1 V p-p, 75 ohm
Color @ 0.7V p-p, 75 ohm
YcbCr
RGBH
Output Format YPbPr/HDTV
Power Adapter Specifications 5V DC @ 2A, center positive
Output PC Resolution Support
VGA 640 x 480 @ 50/60/72/75/85 Hz, RGBHV, progressive scan
SVGA 800 x 600 @ 50/56/60/72/75/85 Hz, RGBHV, progressive scan
XGA 1024 x 768 @ 50/60/70/75/85 Hz, RGBHV, progressive scan
WXGA 1280 x 768 @ 50/60 Hz, RGBHV, progressive scan
SXGA 1280 x 1024 @ 50/60 Hz, RGBHV, progressive scan
Output HDTV Resolution Support
480p 720 x 480, 50/60 Hz, YPbPr/RGBHV, progressive scan
576p 720 x 576, 50/60 Hz, YPbPr/RGBHV, progressive scan
720p 1280 x 720, 50/60 Hz, YPbPr/RGBHV, progressive scan
1080i 1920 x 1080, 50/60 Hz, YPbPr/RGBHV, pseudo-interlaced
Product Length 5.75 in [146 mm]
Product Width 3.03 in [77 mm]
Product Height 1.18 in [30 mm]
Product Weight 0.53 lb [0.24 kg
