Greetings!
I have a PC with a Chaintech AV-710 sound card. I have connected a set of Logitech Z-5500 speakers using optical cable. They work great.
I also have a Sony STR-K7000 AV receiver in another room. The receiver has an optical input and also RCA inputs for 5.1 sound.
The sound card has "mini" (1/8" or 3.5mm) stereo outputs to connect to a 5.1 system in addition to the optical output mentioned above.
I want to connect the sound card output to the AV rcvr in the other room = about a 50" cable run.
1) Can I connect with such a long cable run?
2) Shall I use optical cable or mini to RCA cables?
3) Where can I obtain such long cables?
I would prefer to use the mini to RCA cables to connect to the rcvr because I have had some trouble trying to connect the "mini" cables from the sound card to the Z-5500 speakers.
Thanks in advance for your sage advice!
Doug Stewart
Doug Stewart
